Нет звука на ноуте Asus
MOPTTEX
14 фев 2024, 23:36
Всем привет, поставил mint на ноутбук asus и что то нет звука. Как лечить?
ystem:
  Kernel: 5.15.0-94-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
    base: Ubuntu 22.04 jammy
  Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop K6500ZC_K6500ZC
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: K6500ZC v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: K6500ZC.301 date: 08/30/2022
  ID-1: BAT0 charge: 36.8 Wh (53.2%) condition: 69.2/70.0 Wh (98.9%)
    volts: 11.3 min: 11.9 model: ASUSTeK ASUS Battery status: Discharging
  Info: 10-core (6-mt/4-st) model: 12th Gen Intel Core i7-12650H bits: 64
    type: MST AMCP arch: Alder Lake rev: 3 cache: L1: 864 KiB L2: 9.5 MiB
    L3: 24 MiB
  Speed (MHz): avg: 740 high: 1016 min/max: 400/4600:4700:3500 cores:
    1: 669 2: 699 3: 461 4: 594 5: 612 6: 1016 7: 922 8: 977 9: 659 10: 740
    11: 672 12: 898 13: 689 14: 852 15: 737 16: 654 bogomips: 86016
  Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: ASUSTeK
    driver: i915 v: kernel bus-ID: 0000:00:02.0
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
    driver: N/A bus-ID: 0000:01:00.0
  Device-3: Sonix USB2.0 FHD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 3-9:4
    unloaded: fbdev,vesa gpu: i915 resolution: 2880x1620~120Hz
  OpenGL: renderer: Mesa Intel Graphics (ADL GT2)
    v: 4.6 Mesa 23.0.4-0ubuntu1~22.04.1 direct render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 0000:00:1f.3
  Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
    bus-ID: 0000:01:00.1
  Sound Server-1: ALSA v: k5.15.0-94-generic running: yes
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 0000:00:14.3
Bluetooth:
  Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:5
RAID:
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 bus-ID: 0000:00:0e.0
  Local Storage: total: 953.87 GiB used: 26.74 GiB (2.8%)
  ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW010T8 size: 953.87 GiB
    temp: 44.9 C
  ID-1: / size: 320.51 GiB used: 26.71 GiB (8.3%) fs: ext4
    dev: /dev/nvme0n1p4
  ID-2: /boot/efi size: 96 MiB used: 32.6 MiB (33.9%) fs: vfat
    dev: /dev/nvme0n1p1
Swap:
  System Temperatures: cpu: 41.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 1900
  Processes: 373 Uptime: 1h 30m Memory: 15.31 GiB used: 3.48 GiB (22.7%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2272 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
15 фев 2024, 00:23
М.б. что-то поможет: ссылка 1, ссылка 2, ссылка 3.
15 фев 2024, 01:00
... А еще на машине не только со звуком проблема, но и с видео - гибрид (nvidia) не работает, только видеоядро интела.
MOPTTEX
15 фев 2024, 20:28
slant, мне показалось будто все работает. Хотя я глубоко не тестировал. По крайней мере у меня есть переключалка какую карточку использовать и когда подрубаю nvidia то куллер начинает гудет, откуда и предполагаю что она всетаки работает.
MOPTTEX
16 фев 2024, 10:36
Подскажите, решение нашел! Но, теперь каждый раз приходится при старте писать bash script.sh чтоб появился звук. Как сделать чтоб на автомате запускалось?
16 фев 2024, 10:44
Благодарил (а): 1223 раза
16 фев 2024, 11:46
MOPTTEX писал(а):
16 фев 2024, 10:36
чтоб появился звук
У меня пришлось снести дрова nvidia и установить nouveau
Вернуться в «Звуковые карты»
