Подключается и сразу же идет на рестарт..Параллельно установлен windows, там есть OpenVPN.exe, может несовместимость какая та..Я новенький в Линуксе.
2024-01-28 12:35:47 DEPRECATED OPTION: --cipher set to 'AES-256-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-256-CBC' to --data-ciphers or change --cipher 'AES-256-CBC' to --data-ciphers-fallback 'AES-256-CBC' to silence this warning.
2024-01-28 12:35:47 OpenVPN 2.5.9 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Sep 29 2023
2024-01-28 12:35:47 library versions: OpenSSL 3.0.2 15 Mar 2022, LZO 2.10
Enter Auth Username: z4hqqQRkbhXaAFKhQhKtCK85
2024-01-28 12:36:15 WARNING: --ping should normally be used with --ping-restart or --ping-exit
2024-01-28 12:36:15 NOTE: --fast-io is disabled since we are not using UDP
2024-01-28 12:36:15 Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
2024-01-28 12:36:15 Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
2024-01-28 12:36:15 TCP/UDP: Preserving recently used remote address: [AF_INET]62.197.149.66:1443
2024-01-28 12:36:15 Socket Buffers: R=[131072->131072] S=[16384->16384]
2024-01-28 12:36:15 Attempting to establish TCP connection with [AF_INET]62.197.149.66:1443 [nonblock]
2024-01-28 12:36:15 TCP connection established with [AF_INET]62.197.149.66:1443
2024-01-28 12:36:15 TCP_CLIENT link local: (not bound)
2024-01-28 12:36:15 TCP_CLIENT link remote: [AF_INET]62.197.149.66:1443
2024-01-28 12:36:15 TLS: Initial packet from [AF_INET]62.197.149.66:1443, sid=9ac0d21b 0daa6e69
2024-01-28 12:36:15 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
2024-01-28 12:36:16 VERIFY OK: depth=2, C=VG, O=Surfshark, CN=Surfshark Root CA
2024-01-28 12:36:16 VERIFY OK: depth=1, C=VG, O=Surfshark, CN=Surfshark Intermediate CA
2024-01-28 12:36:16 VERIFY KU OK
2024-01-28 12:36:16 Validating certificate extended key usage
2024-01-28 12:36:16 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
2024-01-28 12:36:16 VERIFY EKU OK
2024-01-28 12:36:16 VERIFY OK: depth=0, CN=lt-vno-v009.prod.surfshark.com
2024-01-28 12:36:16 WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1603', remote='link-mtu 1583'
2024-01-28 12:36:16 WARNING: 'tun-mtu' is used inconsistently, local='tun-mtu 1500', remote='tun-mtu 1532'
2024-01-28 12:36:16 WARNING: 'auth' is used inconsistently, local='auth SHA512', remote='auth [null-digest]'
2024-01-28 12:36:16 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 2048 bit RSA, signature: RSA-SHA256
2024-01-28 12:36:16 [lt-vno-v009.prod.surfshark.com] Peer Connection Initiated with [AF_INET]62.197.149.66:1443
2024-01-28 12:36:17 SENT CONTROL [lt-vno-v009.prod.surfshark.com]: 'PUSH_REQUEST' (status=1)
2024-01-28 12:36:17 PUSH: Received control message: 'PUSH_REPLY,dhcp-option DNS 162.252.172.57,dhcp-option DNS 149.154.159.92,redirect-gateway def1,sndbuf 524288,rcvbuf 524288,explicit-exit-notify,block-outside-dns,route-gateway 10.7.7.1,topology subnet,ping 60,ping-restart 180,ifconfig 10.7.7.6 255.255.255.0,peer-id 0,cipher AES-256-GCM'
2024-01-28 12:36:17 Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:7: block-outside-dns (2.5.9)
2024-01-28 12:36:17 OPTIONS IMPORT: timers and/or timeouts modified
2024-01-28 12:36:17 OPTIONS IMPORT: --explicit-exit-notify can only be used with --proto udp
2024-01-28 12:36:17 OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
2024-01-28 12:36:17 Socket Buffers: R=[131072->425984] S=[46080->425984]
2024-01-28 12:36:17 OPTIONS IMPORT: --ifconfig/up options modified
2024-01-28 12:36:17 OPTIONS IMPORT: route options modified
2024-01-28 12:36:17 OPTIONS IMPORT: route-related options modified
2024-01-28 12:36:17 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2024-01-28 12:36:17 OPTIONS IMPORT: peer-id set
2024-01-28 12:36:17 OPTIONS IMPORT: adjusting link_mtu to 1626
2024-01-28 12:36:17 OPTIONS IMPORT: data channel crypto options modified
2024-01-28 12:36:17 Data Channel: using negotiated cipher 'AES-256-GCM'
2024-01-28 12:36:17 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
2024-01-28 12:36:17 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
2024-01-28 12:36:17 net_route_v4_best_gw query: dst 0.0.0.0
2024-01-28 12:36:17 net_route_v4_best_gw result: via 192.168.183.247 dev wlo1
2024-01-28 12:36:17 ROUTE_GATEWAY 192.168.183.247/255.255.255.0 IFACE=wlo1 HWADDR=00:41:0e:3f:e8:73
2024-01-28 12:36:17 TUN/TAP device tun0 opened
2024-01-28 12:36:17 net_iface_mtu_set: mtu 1500 for tun0
2024-01-28 12:36:17 net_iface_up: set tun0 up
2024-01-28 12:36:17 net_addr_v4_add: 10.7.7.6/24 dev tun0
2024-01-28 12:36:17 net_route_v4_add: 62.197.149.66/32 via 192.168.183.247 dev [NULL] table 0 metric -1
2024-01-28 12:36:17 net_route_v4_add: 0.0.0.0/1 via 10.7.7.1 dev [NULL] table 0 metric -1
2024-01-28 12:36:17 net_route_v4_add: 128.0.0.0/1 via 10.7.7.1 dev [NULL] table 0 metric -1
2024-01-28 12:36:17 Initialization Sequence Completed
2024-01-28 12:36:18 Connection reset, restarting [-1]
2024-01-28 12:36:18 net_route_v4_del: 62.197.149.66/32 via 192.168.183.247 dev [NULL] table 0 metric -1
2024-01-28 12:36:18 net_route_v4_del: 0.0.0.0/1 via 10.7.7.1 dev [NULL] table 0 metric -1
2024-01-28 12:36:18 net_route_v4_del: 128.0.0.0/1 via 10.7.7.1 dev [NULL] table 0 metric -1
2024-01-28 12:36:18 Closing TUN/TAP interface
2024-01-28 12:36:18 net_addr_v4_del: 10.7.7.6 dev tun0
2024-01-28 12:36:18 SIGUSR1[soft,connection-reset] received, process restarting
2024-01-28 12:36:18 Restart pause, 5 second(s)
2024-01-28 12:36:23 NOTE: --fast-io is disabled since we are not using UDP
2024-01-28 12:36:23 Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
2024-01-28 12:36:23 Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
2024-01-28 12:36:23 TCP/UDP: Preserving recently used remote address: [AF_INET]62.197.149.66:1443
2024-01-28 12:36:23 Socket Buffers: R=[131072->425984] S=[16384->425984]
2024-01-28 12:36:23 Attempting to establish TCP connection with [AF_INET]62.197.149.66:1443 [nonblock]
2024-01-28 12:36:24 TCP connection established with [AF_INET]62.197.149.66:1443
2024-01-28 12:36:24 TCP_CLIENT link local: (not bound)
2024-01-28 12:36:24 TCP_CLIENT link remote: [AF_INET]62.197.149.66:1443
2024-01-28 12:36:24 TLS: Initial packet from [AF_INET]62.197.149.66:1443, sid=ee4729cf 3374c943
2024-01-28 12:36:24 VERIFY OK: depth=2, C=VG, O=Surfshark, CN=Surfshark Root CA
2024-01-28 12:36:24 VERIFY OK: depth=1, C=VG, O=Surfshark, CN=Surfshark Intermediate CA
2024-01-28 12:36:24 VERIFY KU OK
2024-01-28 12:36:24 Validating certificate extended key usage
2024-01-28 12:36:24 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
2024-01-28 12:36:24 VERIFY EKU OK
2024-01-28 12:36:24 VERIFY OK: depth=0, CN=lt-vno-v009.prod.surfshark.com
2024-01-28 12:36:24 WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1603', remote='link-mtu 1583'
2024-01-28 12:36:24 WARNING: 'tun-mtu' is used inconsistently, local='tun-mtu 1500', remote='tun-mtu 1532'
2024-01-28 12:36:24 WARNING: 'auth' is used inconsistently, local='auth SHA512', remote='auth [null-digest]'
2024-01-28 12:36:24 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 2048 bit RSA, signature: RSA-SHA256
2024-01-28 12:36:24 [lt-vno-v009.prod.surfshark.com] Peer Connection Initiated with [AF_INET]62.197.149.66:1443
2024-01-28 12:36:25 SENT CONTROL [lt-vno-v009.prod.surfshark.com]: 'PUSH_REQUEST' (status=1)
2024-01-28 12:36:25 PUSH: Received control message: 'PUSH_REPLY,dhcp-option DNS 162.252.172.57,dhcp-option DNS 149.154.159.92,redirect-gateway def1,sndbuf 524288,rcvbuf 524288,explicit-exit-notify,block-outside-dns,route-gateway 10.7.7.1,topology subnet,ping 60,ping-restart 180,ifconfig 10.7.7.9 255.255.255.0,peer-id 0,cipher AES-256-GCM'
2024-01-28 12:36:25 Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:7: block-outside-dns (2.5.9)
2024-01-28 12:36:25 OPTIONS IMPORT: timers and/or timeouts modified
2024-01-28 12:36:25 OPTIONS IMPORT: --explicit-exit-notify can only be used with --proto udp
2024-01-28 12:36:25 OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
2024-01-28 12:36:25 Socket Buffers: R=[425984->425984] S=[425984->425984]
2024-01-28 12:36:25 OPTIONS IMPORT: --ifconfig/up options modified
2024-01-28 12:36:25 OPTIONS IMPORT: route options modified
2024-01-28 12:36:25 OPTIONS IMPORT: route-related options modified
2024-01-28 12:36:25 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2024-01-28 12:36:25 OPTIONS IMPORT: peer-id set
2024-01-28 12:36:25 OPTIONS IMPORT: adjusting link_mtu to 1626
2024-01-28 12:36:25 OPTIONS IMPORT: data channel crypto options modified
2024-01-28 12:36:25 Data Channel: using negotiated cipher 'AES-256-GCM'
2024-01-28 12:36:25 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
2024-01-28 12:36:25 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
2024-01-28 12:36:25 net_route_v4_best_gw query: dst 0.0.0.0
2024-01-28 12:36:25 net_route_v4_best_gw result: via 192.168.183.247 dev wlo1
2024-01-28 12:36:25 ROUTE_GATEWAY 192.168.183.247/255.255.255.0 IFACE=wlo1 HWADDR=00:41:0e:3f:e8:73
2024-01-28 12:36:25 TUN/TAP device tun0 opened
2024-01-28 12:36:25 net_iface_mtu_set: mtu 1500 for tun0
2024-01-28 12:36:25 net_iface_up: set tun0 up
2024-01-28 12:36:25 net_addr_v4_add: 10.7.7.9/24 dev tun0
2024-01-28 12:36:25 net_route_v4_add: 62.197.149.66/32 via 192.168.183.247 dev [NULL] table 0 metric -1
2024-01-28 12:36:25 net_route_v4_add: 0.0.0.0/1 via 10.7.7.1 dev [NULL] table 0 metric -1
2024-01-28 12:36:25 net_route_v4_add: 128.0.0.0/1 via 10.7.7.1 dev [NULL] table 0 metric -1
2024-01-28 12:36:25 Initialization Sequence Completed
2024-01-28 12:36:26 Connection reset, restarting [-1]
2024-01-28 12:36:26 net_route_v4_del: 62.197.149.66/32 via 192.168.183.247 dev [NULL] table 0 metric -1
2024-01-28 12:36:26 net_route_v4_del: 0.0.0.0/1 via 10.7.7.1 dev [NULL] table 0 metric -1
2024-01-28 12:36:26 net_route_v4_del: 128.0.0.0/1 via 10.7.7.1 dev [NULL] table 0 metric -1
2024-01-28 12:36:26 Closing TUN/TAP interface
2024-01-28 12:36:26 net_addr_v4_del: 10.7.7.9 dev tun0
2024-01-28 12:36:26 SIGUSR1[soft,connection-reset] received, process restarting
2024-01-28 12:36:26 Restart pause, 5 second(s)
2024-01-28 12:36:31 NOTE: --fast-io is disabled since we are not using UDP
2024-01-28 12:36:31 Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
2024-01-28 12:36:31 Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
2024-01-28 12:36:31 TCP/UDP: Preserving recently used remote address: [AF_INET]62.197.149.66:1443
2024-01-28 12:36:31 Socket Buffers: R=[131072->425984] S=[16384->425984]
2024-01-28 12:36:31 Attempting to establish TCP connection with [AF_INET]62.197.149.66:1443 [nonblock]
2024-01-28 12:36:32 TCP connection established with [AF_INET]62.197.149.66:1443
2024-01-28 12:36:32 TCP_CLIENT link local: (not bound)
2024-01-28 12:36:32 TCP_CLIENT link remote: [AF_INET]62.197.149.66:1443
2024-01-28 12:36:32 TLS: Initial packet from [AF_INET]62.197.149.66:1443, sid=2440ced2 31f8e4ba
2024-01-28 12:36:33 VERIFY OK: depth=2, C=VG, O=Surfshark, CN=Surfshark Root CA
2024-01-28 12:36:33 VERIFY OK: depth=1, C=VG, O=Surfshark, CN=Surfshark Intermediate CA
2024-01-28 12:36:33 VERIFY KU OK
2024-01-28 12:36:33 Validating certificate extended key usage
2024-01-28 12:36:33 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
2024-01-28 12:36:33 VERIFY EKU OK
2024-01-28 12:36:33 VERIFY OK: depth=0, CN=lt-vno-v009.prod.surfshark.com
2024-01-28 12:36:33 WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1603', remote='link-mtu 1583'
2024-01-28 12:36:33 WARNING: 'tun-mtu' is used inconsistently, local='tun-mtu 1500', remote='tun-mtu 1532'
2024-01-28 12:36:33 WARNING: 'auth' is used inconsistently, local='auth SHA512', remote='auth [null-digest]'
2024-01-28 12:36:33 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 2048 bit RSA, signature: RSA-SHA256
2024-01-28 12:36:33 [lt-vno-v009.prod.surfshark.com] Peer Connection Initiated with [AF_INET]62.197.149.66:1443
2024-01-28 12:36:34 SENT CONTROL [lt-vno-v009.prod.surfshark.com]: 'PUSH_REQUEST' (status=1)
2024-01-28 12:36:34 PUSH: Received control message: 'PUSH_REPLY,dhcp-option DNS 162.252.172.57,dhcp-option DNS 149.154.159.92,redirect-gateway def1,sndbuf 524288,rcvbuf 524288,explicit-exit-notify,block-outside-dns,route-gateway 10.7.7.1,topology subnet,ping 60,ping-restart 180,ifconfig 10.7.7.10 255.255.255.0,peer-id 0,cipher AES-256-GCM'
2024-01-28 12:36:34 Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:7: block-outside-dns (2.5.9)
2024-01-28 12:36:34 OPTIONS IMPORT: timers and/or timeouts modified
2024-01-28 12:36:34 OPTIONS IMPORT: --explicit-exit-notify can only be used with --proto udp
2024-01-28 12:36:34 OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
2024-01-28 12:36:34 Socket Buffers: R=[425984->425984] S=[425984->425984]
2024-01-28 12:36:34 OPTIONS IMPORT: --ifconfig/up options modified
2024-01-28 12:36:34 OPTIONS IMPORT: route options modified
2024-01-28 12:36:34 OPTIONS IMPORT: route-related options modified
2024-01-28 12:36:34 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2024-01-28 12:36:34 OPTIONS IMPORT: peer-id set
2024-01-28 12:36:34 OPTIONS IMPORT: adjusting link_mtu to 1626
2024-01-28 12:36:34 OPTIONS IMPORT: data channel crypto options modified
2024-01-28 12:36:34 Data Channel: using negotiated cipher 'AES-256-GCM'
2024-01-28 12:36:34 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
2024-01-28 12:36:34 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
2024-01-28 12:36:34 net_route_v4_best_gw query: dst 0.0.0.0
2024-01-28 12:36:34 net_route_v4_best_gw result: via 192.168.183.247 dev wlo1
2024-01-28 12:36:34 ROUTE_GATEWAY 192.168.183.247/255.255.255.0 IFACE=wlo1 HWADDR=00:41:0e:3f:e8:73
2024-01-28 12:36:34 TUN/TAP device tun0 opened
2024-01-28 12:36:34 net_iface_mtu_set: mtu 1500 for tun0
2024-01-28 12:36:34 net_iface_up: set tun0 up
2024-01-28 12:36:34 net_addr_v4_add: 10.7.7.10/24 dev tun0
2024-01-28 12:36:34 net_route_v4_add: 62.197.149.66/32 via 192.168.183.247 dev [NULL] table 0 metric -1
2024-01-28 12:36:34 net_route_v4_add: 0.0.0.0/1 via 10.7.7.1 dev [NULL] table 0 metric -1
2024-01-28 12:36:34 net_route_v4_add: 128.0.0.0/1 via 10.7.7.1 dev [NULL] table 0 metric -1
2024-01-28 12:36:34 Initialization Sequence Completed
2024-01-28 12:36:36 Connection reset, restarting [-1]
2024-01-28 12:36:36 net_route_v4_del: 62.197.149.66/32 via 192.168.183.247 dev [NULL] table 0 metric -1
2024-01-28 12:36:36 net_route_v4_del: 0.0.0.0/1 via 10.7.7.1 dev [NULL] table 0 metric -1
2024-01-28 12:36:36 net_route_v4_del: 128.0.0.0/1 via 10.7.7.1 dev [NULL] table 0 metric -1
2024-01-28 12:36:36 Closing TUN/TAP interface
2024-01-28 12:36:36 net_addr_v4_del: 10.7.7.10 dev tun0
2024-01-28 12:36:36 SIGUSR1[soft,connection-reset] received, process restarting
2024-01-28 12:36:36 Restart pause, 5 second(s)
2024-01-28 12:36:41 NOTE: --fast-io is disabled since we are not using UDP
2024-01-28 12:36:41 Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
2024-01-28 12:36:41 Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
2024-01-28 12:36:41 TCP/UDP: Preserving recently used remote address: [AF_INET]62.197.149.66:1443
2024-01-28 12:36:41 Socket Buffers: R=[131072->425984] S=[16384->425984]
2024-01-28 12:36:41 Attempting to establish TCP connection with [AF_INET]62.197.149.66:1443 [nonblock]
^C2024-01-28 12:36:41 SIGINT[hard,init_instance] received, process exiting
morta@morta-HP-250-15-6-inch-G9-Notebook-PC:/etc/openvpn$ ^C
И еще вопросик:почему через приложение Wine не могу запустить SilverBullet?
