Linux Mint 21.3 успешное обновление
1o4ka
Благодарил (а): 23 раза
13 янв 2024, 21:09
Появилась новая версия LM:
cat /etc/lsb-release; arch; cinnamon --version
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=21.3
DISTRIB_CODENAME=virginia
DISTRIB_DESCRIPTION="Linux Mint 21.3 Virginia"
x86_64
Cinnamon 6.0.4
На моё железо:
$ inxi -Fxz
Kernel: 5.15.0-91-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP Laptop 15s-eq1xxx v: N/A
serial: <superuser required>
Mobo: HP model: 8706 v: 99.42 serial: <superuser required> UEFI: AMI
v: F.67 date: 12/29/2022
ID-1: BAT0 charge: 41.0 Wh (100.0%) condition: 41.0/41.0 Wh (100.0%)
volts: 12.6 min: 11.3 model: Hewlett-Packard Primary status: Full
Info: dual core model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 192 KiB
L2: 1024 KiB L3: 4 MiB
Speed (MHz): avg: 1308 high: 1392 min/max: 1400/2600 boost: enabled
cores: 1: 1213 2: 1306 3: 1392 4: 1324 bogomips: 20759
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 04:00.0
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5.2:5
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon Vega 3 Graphics (raven2 LLVM 15.0.7 DRM 3.42
5.15.0-91-generic)
v: 4.6 Mesa 23.0.4-0ubuntu1~22.04.1 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.1
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.6
Sound Server-1: ALSA v: k5.15.0-91-generic running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: f000
bus-ID: 02:00.0
IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth:
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-4:3
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter>
bt-v: 2.1 lmp-v: 4.2
Local Storage: total: 238.47 GiB used: 86.2 GiB (36.1%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC711 HFM256GD3JX013N
size: 238.47 GiB temp: 27.9 C
ID-1: / size: 74.34 GiB used: 62.22 GiB (83.7%) fs: ext4
dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 96 MiB used: 55.4 MiB (57.7%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 89.05 GiB used: 23.93 GiB (26.9%) fs: ext4
dev: /dev/nvme0n1p5
Swap:
ID-1: swap-1 type: file size: 1.82 GiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 45.0 C mobo: N/A gpu: amdgpu temp: 53.0 C
Processes: 261 Uptime: 8m Memory: 5.7 GiB used: 2.18 GiB (38.3%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2995 Shell: Bash
v: 5.1.16 inxi: 3.3.13
встала отлично.
Не сразу, но как-то всё наладилось. Для начала отвалились зеркала:
Пришлось выбрать вручную.
Сама загрузка длилась довольно долго:
Оно и понятно. Загружал - с мобильника, через точку доступа.
После загрузки новой версии, перезагрузил ноут.
Всё работает.
Как говорится, желаю чтобы все... Все, кому это надо, сумели успешно обновить дистрибутив Linux Mint Cinnamon.
...bis dat qui cito dat
Еринат
24 мар 2025, 10:32
:-D :blink2:
Благодарил (а): 1225 раз
24 мар 2025, 11:06
Еринат, Дык больше года уже прошло
1o4ka
24 мар 2025, 11:09
Господа, вы ещё лет через пять в эту тему загляните.
