Новый стационарный ПК "AMD Gaming PCG028/Ryzen", установлена Linux Mate 21.2 не опознаёт монитор 28', 3840x2160, 60гц
konstantin
Благодарил (а): 33 раза
22 дек 2023, 18:18
konstantin@bkl-B550M-K:~$ inxi -Fxz
Kernel: 5.15.0-91-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
Desktop: MATE 1.26.0 Distro: Linux Mint 21.2 Victoria
base: Ubuntu 22.04 jammy
Type: Desktop System: Gigabyte product: B550M K v: -CF
serial: <superuser required>
Mobo: Gigabyte model: B550M K v: x.x serial: <superuser required>
UEFI: American Megatrends LLC. v: F2 date: 03/01/2023
Info: 6-core model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 1396 high: 1397 min/max: 1400/3900 boost: enabled
cores: 1: 1397 2: 1397 3: 1396 4: 1386 5: 1397 6: 1397 7: 1397 8: 1397
9: 1397 10: 1397 11: 1397 12: 1397 bogomips: 93419
Device-1: AMD vendor: ASRock driver: N/A bus-ID: 03:00.0
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: ati,vesa
unloaded: fbdev,modesetting,radeon gpu: N/A resolution: 1024x768~76Hz
OpenGL: renderer: llvmpipe (LLVM 15.0.7 256 bits)
v: 4.5 Mesa 23.0.4-0ubuntu1~22.04.1 direct render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 03:00.1
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 08:00.1
Device-3: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 08:00.6
Sound Server-1: ALSA v: k5.15.0-91-generic running: yes
vendor: Gigabyte driver: r8169 v: kernel port: e000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: r8188eu bus-ID: 1-7:4
IF: wlx7cdd90bcbbeb state: up mac: <filter>
Local Storage: total: 1.82 TiB used: 20.71 GiB (1.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO with Heatsink 2TB
size: 1.82 TiB temp: 30.9 C
ID-1: / size: 154.78 GiB used: 10.46 GiB (6.8%) fs: ext4
dev: /dev/nvme0n1p1
ID-2: /boot/efi size: 952.1 MiB used: 6.1 MiB (0.6%) fs: vfat
dev: /dev/nvme0n1p4
ID-3: /home size: 640.99 GiB used: 10.24 GiB (1.6%) fs: ext4
dev: /dev/nvme0n1p2
Swap:
ID-1: swap-1 type: partition size: 14.9 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 16.8 C mobo: 16.8 C
Processes: 300 Uptime: 2h 15m Memory: 15.48 GiB used: 1.89 GiB (12.2%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2125 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Как решить? Linux Mate 21.2 искаженно даёт картинку на монитор 28' BenQ EL2870U 3840x2160 60гц. Новый только приобретённый стационарный ПК. На только что установленном Linux Mate 21.2 не работает утилита меню--параметры--ЭКРАНЫ. Снимок прилагаю. Разрешение монитора 3840x2160, но есть только один вариант выбора 1024x768 , и без выбора частота, то есть другого варианта в выпадающем меню нет. Вид на дисплее всегда растянут и при запуске и далее всегда. Драйверы по утверждению Менеджера драйверов все установлены. Оборудование: Монитор 28' BenQ EL2870U 3840x2160 HDR , AMD Free Sync, 60гц. Подключение к системному блоку через HDMI. Компьютер AMD Gaming PC028/Ryzen с видеокартой Radeon, 8GB, поддерживающей такие мониторы. В меню монитора есть информация об используемом разрешении -- 2560x1440, 60гц , а оптимальное разрешение указано как 3840x2160, 60гц. Изменить, то есть перенастроить, это в меню монитора нет возможности. До этого монитор работал от старого ноутбука в качестве основного монитора с оптимальным разрешением 3840x2160, и даже только в Windows 10 хорошо показывал во весь экран он-лайн телевидение с включенным AMD Free Sync. Тогда и в Linux Mint и в Windows был выбор разрешения в соответствующих утилитах и марка монитора определялась. Также есть вопрос и с аудио. Так как колонки подключены к монитору, как было и прежде со старым ноутбуком. Теперь звука нет и только фиктивный выход в настройках звука. Прилагаю и снимки о настройках звука.
22 дек 2023, 18:42
Драйвер на видео не загружен, отсюда первопричина косяков.
konstantin писал(а):
22 дек 2023, 18:18
Нужно искать почему. Ядро теоретически достаточно новое чтобы драйвер там был. Но не факт (я с AMD не особо дружу - не очень в курсе дела по номерам версий). Вообще, обычное направление куда копать в таких случаях - установка максимально возможно свежего ядра, или скачивание и установка Edge версии дистрибутива.
22 дек 2023, 19:22
Как выше предложено пробуй более свежее ядро из ветки 6.2/6.5.
Менеджер обновлений, вид, ядра линукс
Ну монитор должен быть подключен без всяких переходников
ilikethat
Решено: 10
Благодарил (а): 129 раз
22 дек 2023, 20:31
konstantin, добрый вечер.
А кроме встройки AMD, в системе есть другая, отдельная видеокарта? Если есть, куда воткнут HDMI кабель? В материнку или в видеокарту?
konstantin
22 дек 2023, 21:46
Разьём HDMI подключен к видеокарте и к монитору. Я при первом включении подсоединял монитор по HDMI к разьёму на материнской плате и при попытке включить системный блок монитор никак не захотел хоть что-то показать -- тёмный экран и всё. Так что это единственно правильно подключать к видеокарте.
Тут вот выписку о компьютере представлю, может важно будет :
Процессор: AMD Ryzen 5 5600G
Кулер процессора: Wraith Stealth
Материнская плата: Gigabyte B550M K
SSD диск: Samsung 990 PRO 2TB M.2 NVMe SSD
RAM: Kingston Fury Beast DDR4 2x8GB
Модель видеокарты: Radeon RX 6600XT
Корпус: Gembird CCC-FC-1000R
Блок питания: Seasonic B12 550W
Из характеристик материнской платы :
Графический интерфейс:
*Встроенное графическое ядро в составе процессора
1 порт DisplayPort, максимальное экранное разрешение 5120x2880@60 Гц
* Поддержка DisplayPort версии 1.4, HDCP 2.3 и HDR
1 порт HDMI, максимальное экранное разрешение 4096x2160@60 Гц
* Совместимость со стандартами HDMI 2.1, HDCP 2.3 и HDR
Максимальный объем разделяемой памяти 16 Гбайт
sheridan
Решено: 14
Благодарил (а): 900 раз
22 дек 2023, 21:56
konstantin, попробуйте отключить встройку в bios и удалите конфиг /etc/X11/имя.conf, может находится по этому пути /etc/X11/xorg.conf.d
затем перезагрузка
konstantin
22 дек 2023, 22:01
Ядро у меня стоит свежее. Прилагаю скриншот :
sheridan
Решено: 14
22 дек 2023, 22:04
konstantin, для вашего железа свежее
22 дек 2023, 22:15
22 дек 2023, 22:01
22 дек 2023, 21:46
Похоже вы вывод Inxi вписали левый (или старый) в первом посте. И на какую помощь вы в таком случае рассчитываете, давая некорректные исходные данные?
konstantin
22 дек 2023, 22:35
Вывод ещё раз делаю:
Local Storage: total: 1.82 TiB used: 20.82 GiB (1.1%)
ID-1: / size: 154.78 GiB used: 10.55 GiB (6.8%) fs: ext4
dev: /dev/nvme0n1p1
dev: /dev/nvme0n1p4
ID-3: /home size: 640.99 GiB used: 10.27 GiB (1.6%) fs: ext4
dev: /dev/nvme0n1p2
Swap:
dev: /dev/nvme0n1p3
Processes: 287 Uptime: 14m Memory: 15.48 GiB used: 1.57 GiB (10.2%)
22 дек 2023, 22:38
В этот раз оно вообще обрезанное.
konstantin
22 дек 2023, 22:40
Я тут прилагаю два изображения экрана при запуске может важно. К компьютеру ещё подключен usb адаптор Wi-Fi, и клавиатура, и мышь тоже по usb - 2.0 .
konstantin
22 дек 2023, 22:45
Ещё раз :
Speed (MHz): avg: 1396 high: 1399 min/max: 1400/3900 boost: enabled
cores: 1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1394 8: 1397
9: 1397 10: 1399 11: 1397 12: 1397 bogomips: 93431
dev: /dev/nvme0n1p1
dev: /dev/nvme0n1p4
dev: /dev/nvme0n1p2
Swap:
dev: /dev/nvme0n1p3
konstantin
22 дек 2023, 22:48
Я делал копирование из меню терминала и оказалось , что копируется только часть вывода. Теперь вручную скопировал. Извиняюсь за это.
konstantin
22 дек 2023, 22:52
Я пока даже не знаю ещё какая клавиша для входа в биос и в меню загрузки boot menu.
konstantin
22 дек 2023, 22:55
Что такое встройка в BIOS ?
Благодарил (а): 1223 раза
22 дек 2023, 22:59
22 дек 2023, 22:55
Встроенное видеоядро в процессор или в материнскую плату - выход для подключения к монитору расположен на материнской плате. Сам же писал:
22 дек 2023, 21:46
22 дек 2023, 23:07
22 дек 2023, 22:52
перезагрузить компьютер и нажать определенную клавишу (обычно Del или F2) до загрузки операционной системы. После входа в биос вы увидите основное меню, где можно настраивать различные параметры системы
Последний раз редактировалось пользователем 1 hellonet; всего редактировалось раз: 22
22 дек 2023, 23:11
22 дек 2023, 22:52
У матплаты Gigabyte это клавиша F12
Всё это можно узнать и без выхода на форум - просто погуглив
Вернуться в «Mate»
