Steam крашится при верификации клиента.
Нативные и в Wine - настройка, обсуждение, решение проблем
ShadowWisp
Сообщение ShadowWisp » 09 ноя 2023, 06:12
<r>сразу чеклист:
Форум листал, но единственное что вообще трогает Nouveau драйвера датировано 2017 годом. Недавние краши идут в другом направлении.
<URL url="https://forums.linuxmint.com/viewtopic. ... 00307</URL> не помог, хотя там и близкая ошибка
Перезапуск не помог, снос не помог.
Активный драйвер Proprietary-535
</s>Х:~$ steam<br/>
steam.sh[23252]: Running Steam on linuxmint 21.2 64-bit<br/>
steam.sh[23252]: STEAM_RUNTIME is enabled automatically<br/>
setup.sh[23367]: Steam runtime environment up-to-date!<br/>
steam.sh[23252]: Steam client's requirements are satisfied<br/>
[2023-11-09 10:29:43] Startup - updater built Oct 31 2023 02:08:17<br/>
[2023-11-09 10:29:43] Startup - Steam Client launched with: '/home/shadowwisp/.steam/debian-installation/ubuntu12_32/steam'<br/>
11/09 10:29:43 Init: Installing breakpad exception handler for appid(steam)/version(1698777785)/tid(23432)<br/>
libGL error: MESA-LOADER: failed to open nouveau: /usr/lib/dri/nouveau_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/i386-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)<br/>
libGL error: failed to load driver: nouveau<br/>
libGL error: MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/i386-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)<br/>
libGL error: failed to load driver: swrast<br/>
SteamUpdateUI: An X Error occurred<br/>
X Error of failed request: BadValue (integer parameter out of range for operation)<br/>
Major opcode of failed request: 152 (GLX)<br/>
Minor opcode of failed request: 3 (X_GLXCreateContext)<br/>
Value in failed request: 0x0<br/>
Serial number of failed request: 49<br/>
xerror_handler: X failed, continuing<br/>
Looks like steam didn't shutdown cleanly, scheduling immediate update check<br/>
[2023-11-09 10:29:43] Loading cached metrics from disk (/home/shadowwisp/.steam/debian-installation/package/steam_client_metrics.bin)<br/>
[2023-11-09 10:29:43] Failed to load cached hosts file (File 'update_hosts_cached.vdf' not found), using defaults<br/>
[2023-11-09 10:29:43] Using the following download hosts for Public, Realm steamglobal<br/>
[2023-11-09 10:29:43] 1. <URL url="https://cdn.steamstatic.com">https://cdn.steamstatic.com</URL>, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'<br/>
[2023-11-09 10:29:43] Checking for update on startup<br/>
[2023-11-09 10:29:43] Checking for available updates...<br/>
[2023-11-09 10:29:43] Downloading manifest: <URL url="https://cdn.steamstatic.com/client/stea ... <LINK_TEXT text="https://cdn.steamstatic.com/client/stea ... t_ubuntu12">https://cdn.steamstatic.com/client/stea ... </URL><br/>
[2023-11-09 10:29:43] Manifest download: send request<br/>
[2023-11-09 10:29:43] Manifest download: waiting for download to finish<br/>
[2023-11-09 10:29:43] Manifest download: finished<br/>
[2023-11-09 10:29:43] Download skipped: /client/steam_client_ubuntu12 version 1698777785, installed version 1698777785, existing pending version 0<br/>
[2023-11-09 10:29:43] Nothing to do<br/>
[2023-11-09 10:29:43] Verifying installation...<br/>
[2023-11-09 10:29:43] Performing checksum verification of executable files<br/>
[2023-11-09 10:29:44] Verification complete<br/>
<br/>
Steam logging initialized: directory: /home/shadowwisp/.steam/debian-installation/logs<br/>
<br/>
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf6279370<br/>
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf6277cc0<br/>
crash_20231109102944_5.dmp[23442]: Uploading dump (out-of-process)<br/>
/tmp/dumps/crash_20231109102944_5.dmp<br/>
/home/shadowwisp/.steam/debian-installation/steam.sh: line 798: 23432 Segmentation fault (core dumped) "$STEAMROOT/$STEAMEXEPATH" "$@"
Насколько я понял, стим пытается обратиться не к Нвидиевским а к открытым драйверам? Хотя выбраны как раз проприетарные?
Probe URL: https://linux-hardware.org/?probe=92f4499514
сейчас бы понять где именно подпись, или она только после первого сообщения добавляется?</r>
Решение ShadowWisp » 09 ноя 2023, 14:17
Еще страннее ситуёвина... После установки 525го драйвера я таки поймал на фото ошибку, смотри фото.
После провала поймать вторую стадию ошибок я решил поставить 535ю версию и бац кабац,
Мои мозги кипятъ
Добавляю свежую пробку Probe URL: https://linux-hardware.org/?probe=b748728f16
Стим запустился.
Благодарил (а): 802 раза
Сообщение rogoznik » 09 ноя 2023, 06:49
ShadowWisp писал(а):
09 ноя 2023, 06:12
Что-то при установке пошло не так
Device-1: NVIDIA TU116 [GeForce GTX 1660] driver: nouveau
Драйвер у тебя используется nouveau.
Пробуй так.
1. Вот там в "Менеджере драйверов" переключись на nouveau.
2. Перезагрузка.
3. Переключиться на драйвер nvidia
4. Перезагрузка.
Проверить какой драйвер используется можно так Если там все так же красуется nouveau будем думать дальше
sheridan
Решено: 14
Благодарил (а): 914 раз
Сообщение sheridan » 09 ноя 2023, 07:53
ShadowWisp, Возможно что Вы установили сначало steam а затем прориетарный драйвер nvidia
Genek
Благодарил (а): 6 раз
Сообщение Genek » 09 ноя 2023, 11:39
Была похожая проблема Проблема с драйвером на nvidia . Кстати новые драйвера так и не могу поставить, сижу на старых (работает, и слава Богу). Единственное наблюдение какое сделал: сейчас есть пакеты драйверов nvidia с 386 архитектурой, после установки любого драйвера они пропадают. А steam, видимо, нужны 32-х разрядные пакеты. Так что если найдете вариант решения Вашей проблемы, отпишитесь, пожалуйста - может и мне поможет.
ShadowWisp
Сообщение ShadowWisp » 09 ноя 2023, 13:37
09 ноя 2023, 06:49
09 ноя 2023, 06:12
Пробуй так.
2. Перезагрузка.
4. Перезагрузка.
Окей... наконецто вернулся. При первой перезагрузке комп перезагрзился нормально
При второй он выдал сначала что то вроде Nvidia callout wasn't done for 1 device
Потом куча текста ошибок и хард ресет после котого пришлось восстанваливать с таймшифта
Genek писал(а):
09 ноя 2023, 11:39
сижу на старых
каких именно старых?
Ах да. свежий линукс юзер, начинаю переезд на линукс
Последний раз редактировалось пользователем 1 ShadowWisp; всего редактировалось раз: 9
Сообщение rogoznik » 09 ноя 2023, 13:38
ShadowWisp, какую версию драйвера пробовал?
ShadowWisp
Сообщение ShadowWisp » 09 ноя 2023, 13:49
09 ноя 2023, 13:38
535ю, которая в скриншоте. Сейчас перезагружу на нво, попробую 25ю
ShadowWisp
Сообщение ShadowWisp » 09 ноя 2023, 14:17
Мои мозги кипятъ
Стим запустился.
Сообщение rogoznik » 09 ноя 2023, 15:56
09 ноя 2023, 14:17
Драйвер установился
Genek
Сообщение Genek » 10 ноя 2023, 05:04
09 ноя 2023, 13:37
На 525-ых. 535 так и не смог поставить. Ну или точнее поставить-то смог, конечно, но steam на них игры не запускал. Steam определял модель видеокарты не NVIDIA GeForce GTX 1050, а Mesa/X.org llvmpipe (LLVM 15.0.6, 256 bits).
Вернуться в «Игры»
