LXDM
SemenSinchenko
LXDM
15 мар 2017, 00:14
lxdm установлен, но не стартует.
Вывод journalctl | greo lxdm:
мар 14 23:55:47 semen-HP-255-G3 sudo[2881]: semen : TTY=tty1 ; PWD=/home/semen ; USER=root ; COMMAND=/usr/sbin/service lxdm start
мар 14 23:55:53 semen-HP-255-G3 systemd[1]: lxdm.service: Main process exited, code=exited, status=1/FAILURE
мар 14 23:55:53 semen-HP-255-G3 systemd[1]: lxdm.service: Unit entered failed state.
мар 14 23:55:53 semen-HP-255-G3 systemd[1]: lxdm.service: Failed with result 'exit-code'.
мар 14 23:55:53 semen-HP-255-G3 systemd[1]: lxdm.service: Service hold-off time over, scheduling restart.
мар 14 23:55:58 semen-HP-255-G3 systemd[1]: lxdm.service: Main process exited, code=exited, status=1/FAILURE
мар 14 23:55:58 semen-HP-255-G3 systemd[1]: lxdm.service: Unit entered failed state.
мар 14 23:55:58 semen-HP-255-G3 systemd[1]: lxdm.service: Failed with result 'exit-code'.
мар 14 23:55:59 semen-HP-255-G3 systemd[1]: lxdm.service: Service hold-off time over, scheduling restart.
мар 14 23:56:04 semen-HP-255-G3 systemd[1]: lxdm.service: Main process exited, code=exited, status=1/FAILURE
мар 14 23:56:04 semen-HP-255-G3 systemd[1]: lxdm.service: Unit entered failed state.
мар 14 23:56:04 semen-HP-255-G3 systemd[1]: lxdm.service: Failed with result 'exit-code'.
мар 14 23:56:04 semen-HP-255-G3 systemd[1]: lxdm.service: Service hold-off time over, scheduling restart.
мар 14 23:56:09 semen-HP-255-G3 sudo[3060]: semen : TTY=tty1 ; PWD=/home/semen ; USER=root ; COMMAND=/usr/sbin/service lxdm stop
systemctl status -l lxdm.service
● lxdm.service - LXDE Display Manager
Loaded: loaded (/lib/systemd/system/lxdm.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Вт 2017-03-14 23:56:09 MSK; 17min ago
Docs: man:lxdm(1)
Process: 3043 ExecStart=/usr/sbin/lxdm (code=exited, status=1/FAILURE)
Process: 3038 ExecStartPre=/bin/sh -c [ ! -f /etc/X11/default-display-manager -o "$(cat /etc/X11/default-display-manager 2>/dev/null)" = "/usr/sbin/lxdm" ] (code=exit
Main PID: 3043 (code=exited, status=1/FAILURE)
мар 14 23:56:04 semen-HP-255-G3 systemd[1]: Starting LXDE Display Manager...
мар 14 23:56:04 semen-HP-255-G3 systemd[1]: Started LXDE Display Manager.
мар 14 23:56:09 semen-HP-255-G3 systemd[1]: Stopping LXDE Display Manager...
мар 14 23:56:09 semen-HP-255-G3 systemd[1]: lxdm.service: Main process exited, code=exited, status=1/FAILURE
мар 14 23:56:09 semen-HP-255-G3 systemd[1]: Stopped LXDE Display Manager.
мар 14 23:56:09 semen-HP-255-G3 systemd[1]: lxdm.service: Unit entered failed state.
мар 14 23:56:09 semen-HP-255-G3 systemd[1]: lxdm.service: Failed with result 'exit-code'.
Решение Chocobo » 15 мар 2017, 00:42
apt спросил, а умеет ли он дизейблить сервисы - кто его знает.
sudo systemctl disable mdm; sudo systemctl stop mdm; sudo systemctl start lxdm
lxdm
15 мар 2017, 00:20
Странно, у меня в корице 18.1 все взлетело даже в рамках лайв сессии.
Смотри наверное в /var/log/lxdm.log тогда
SemenSinchenko
lxdm
15 мар 2017, 00:23
lxdm.log
** Message: find greeter (nil)
** Message: find idle (nil)
** Message: 1489524964: add xserver watch
Invalid MIT-MAGIC-COOKIE-1 key(EE)
Fatal server error:
(EE) Server is already active for display 0
If this server is no longer running, remove /tmp/.X0-lock
and start again.
(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE)
Invalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 key** Message: 1489524969: start xserver in 99 retry
** Message: exit cb
** Message: free session
Я не программист...Я ни в жизнь не разберусь что есть MIT-MAGIC-COOKIE-1...
lxdm
15 мар 2017, 00:27
SemenSinchenko писал(а): Server is already active for display 0
Вот сюда лучше внимание обратить.
Перезагружался после установки, стопал ли mdm?
может mdm.service поднят еще
SemenSinchenko
lxdm
15 мар 2017, 00:29
Chocobo, при sudo dpkg-reconfigure еще раз выбрал lxdm - эффект тот же.
Или я чего то не понимаю? Всю жизнь dm автоматом менялся...
lxdm
15 мар 2017, 00:33
SemenSinchenko, systemctl status mdm ?
SemenSinchenko
lxdm
15 мар 2017, 00:40
Да, он тут как тут скотина.
Но
а) Я не понимаю как его убрать.
б) А какого он вообще не убрался сам, автоматом, ведь apt меня спросил какой менеджер я выбираю и я выбрал lxdm!
lxdm
15 мар 2017, 00:42
SemenSinchenko
lxdm
15 мар 2017, 00:59
Chocobo, теперь никто не стартует... Приветствие tty1
lxdm
15 мар 2017, 01:34
SemenSinchenko, значит еще и автозапуск до кучи sudo systemctl enable lxdm
На sudo systemctl start lxdm что отвечает?
SemenSinchenko
lxdm
15 мар 2017, 08:07
Chocobo, вопрос решился ещё одним dpkg-reconfigure lxdm
colonel
Решено: 21
lxdm
15 мар 2017, 14:34
а можно узнать , зачем "янепрограммистам" lxdm и чем mdm не устраивает?
SemenSinchenko
lxdm
15 мар 2017, 15:02
colonel писал(а): чем mdm не устраивает
Вот сейчас не могу найти ссылку, но на одном из убунту форумов случайно попадалась тема следующего характера:
"При старте Cinnamon задержка 7-10 сек, просто черный экран и мышка по середине"
В общем-то у меня то же самое наблюдается.
Там у юзера проблема решилась сменой mdm на lightdm.
Но меня lightdm (из пакетов xenial) не устраивает своими значками ubuntu (вероятно из-за ubuntu-greeter)
Соответственно gdm не устраивает своими дикими зависимостями.
xdm слишком вырвиглазный.
Из того что помню - выбор пал на lxdm.
lxdm
15 мар 2017, 15:09
SemenSinchenko писал(а): Но меня lightdm (из пакетов xenial) не устраивает своими значками ubuntu
Там, если не ошибаюсь, при помощи UbuntuTweak можно лого менять.
SemenSinchenko
lxdm
15 мар 2017, 15:11
di_mok, еще и ubuntu tweak с его зависимостями мне не хватало)
Кстати нашел - http://forum.ubuntu.ru/index.php?topic=251997.0
lxdm
15 мар 2017, 15:16
только вот корневая проблема черного квадрата от смены dm вряд ли нивелируется, можно узреть например тут, как mdm дергает cinnamon-session менее секунды, а дальше уже кухня DE
SemenSinchenko
lxdm
15 мар 2017, 15:24
Chocobo, вчера уже поздно было проводить тесты, но по ощущениям корица стартовала быстрее - после lxdm был синий (что логично) экран пару секунд, супротив обычного черного секунд на 10.
Домой приду - замерю секундомером -)
colonel
Решено: 21
lxdm
15 мар 2017, 17:33
.... "При старте Cinnamon задержка 7-10 сек, просто черный экран и мышка по середине"
так понимаю что когда "черный экран и мышка по середине" это значится уже после авторизации когда начинает грузиться всякая всячина из того чему положено загружаться (типа и служб, и сервисов , и подключения всякоразного ) и всего того что установлено в "автозагрузку"
SemenSinchenko
lxdm
15 мар 2017, 17:39
colonel, в теории да.
Но каждый DM немного по своему обрабатывает данные из xinitrc. Исходя из приведенного Выше поста с убунту-форума, проблема может быть не в автозагрузке корицы (потому что очистка автозагрузки проблему не решает).
В любом случае мысль из поста с форума бубунты, что "Оказалось нужно было поставить lightdm" показалась мне интересной.
colonel
Решено: 21
lxdm
15 мар 2017, 17:57
в автозагрузке что у юзера в "папочке" autostart в хомяке и что настраивается в "загружаемых приложениях" это ведь наверняка далеко не всё чему предписано загружаться и в тч согласно данным "из xinitrc"
Вернуться в «Другие среды рабочего стола»
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 14 гостей
