Не определяется видеокарта АМД и драйвера
Gears
24 сен 2023, 11:14
Привет, нужна помощь не определяется видеокарта или точнее драйвер для нее.
igor@Gears:~$ inxi -Fxz
  Kernel: 5.15.0-76-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
    Desktop: Cinnamon 5.8.4 Distro: Linux Mint 21.2 Victoria
    base: Ubuntu 22.04 jammy
  Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
  Mobo: ASUSTeK model: TUF GAMING B650-PLUS WIFI v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 0823
    date: 11/21/2022
  Info: 8-core model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 3
    rev: 2 cache: L1: 512 KiB L2: 8 MiB L3: 32 MiB
  Speed (MHz): avg: 2993 high: 2996 min/max: 3000/5572 boost: enabled
    cores: 1: 2994 2: 2996 3: 2994 4: 2994 5: 2994 6: 2994 7: 2993 8: 2994
    9: 2994 10: 2993 11: 2994 12: 2994 13: 2994 14: 2994 15: 2991 16: 2993
    bogomips: 143722
  Device-1: AMD vendor: ASUSTeK driver: N/A bus-ID: 03:00.0
  Device-2: AMD vendor: ASUSTeK driver: N/A bus-ID: 0e:00.0
  Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: ati,vesa
    unloaded: fbdev,modesetting,radeon gpu: N/A resolution: 2560x1440~93Hz
  OpenGL: renderer: llvmpipe (LLVM 15.0.6 256 bits) v: 4.5 Mesa 22.2.5
  Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 03:00.1
  Device-2: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel
    bus-ID: 0e:00.1
  Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 0e:00.6
  Sound Server-1: ALSA v: k5.15.0-76-generic running: yes
  Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    port: d000 bus-ID: 0a:00.0
  Device-2: Realtek vendor: AzureWave driver: N/A port: c000
    bus-ID: 0b:00.0
Bluetooth:
  Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 1-5:2
    bt-v: 3.0 lmp-v: 5.2
  Local Storage: total: 1.86 TiB used: 17.98 GiB (0.9%)
  ID-1: /dev/nvme0n1 vendor: A-Data model: LEGEND 960 size: 953.87 GiB
    temp: 35.9 C
  ID-2: /dev/nvme1n1 vendor: A-Data model: LEGEND 960 size: 953.87 GiB
    temp: 25.9 C
  ID-1: / size: 864.49 GiB used: 8.99 GiB (1.0%) fs: ext4 dev: /dev/nvme0n1p3
  ID-2: /boot/efi size: 27.93 GiB used: 6.2 MiB (0.0%) fs: vfat
    dev: /dev/nvme0n1p2
Swap:
  ID-1: swap-1 type: partition size: 46.57 GiB used: 0 KiB (0.0%)
    dev: /dev/nvme0n1p1
  Message: No sensor data found. Is lm-sensors configured?
  Processes: 326 Uptime: 6m Memory: 30.49 GiB used: 2.26 GiB (7.4%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2096 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
lspci | grep -E "VGA|3D"
03:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900 XTX] (rev cc)
0e:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Raphael (rev c3)
Менеджер загрузки драйверов говорит что все загружено ве ОК.
Пробовал разные сбопосы с разных сайтов, пробовал ставить драйвера с сайта амд, пишет что уже установлены, несколько раз переустанавливал систему, даже попробовал качать с разных зеркал
24 сен 2023, 12:18
Gears, Вангую. Судя по выводу inxi после установки ты не делал обновления системы. А ещё возможно что и во время установки не ставил нужную галочку.
ilikethat
Решено: 10
Благодарил (а): 129 раз
24 сен 2023, 12:53
Gears, обновите версию ядра. 7000-е радеоны поддерживаются примерно с 6 версии ядра.
Менеджер обновления / Меню / Вид / Ядра линукс. Установите последнее ядро 6.2.
Gears
24 сен 2023, 13:28
symon2014, галоку при установке я ставил, там было что-то про обновление кодеков, и обновление системы сделал, все что менеджер обновлений предолжил обновить, все обновил
Gears
24 сен 2023, 13:30
ilikethat, это помогло мне, не знал что обновление ядра руками надо делать, большое спасибо вам. Я новы йпользователь линукса, еще учусь, винда совсем достала.
ilikethat
Решено: 10
24 сен 2023, 14:58
Gears писал(а):
24 сен 2023, 13:30
:thumbs:
В отличии отNVidia, которая никому исходный код драйверов не дает и потому их нужно ставить отдельно, драйвера от Амд идут в комплекте с ядром линукс. Поскольку железяка относительно свежая, то и ядра должны быть свежими.
ЗЫ В начале лета обновил монитор на 4к модель. Теперь думаю над покупкой новой видюхи. :hoho:
Смотрел модели 7900xt, но цен не радуют и пока внутренняя жаба побеждает. :-D Может "согласится" на 7800xt.
25 сен 2023, 07:12
ilikethat писал(а):
24 сен 2023, 14:58
А я свою уломал и с марта у меня трудится 7900XT
sheridan
Решено: 14
Благодарил (а): 900 раз
25 сен 2023, 08:46
rogoznik, я тоже глядя на тебя :-D
Вернуться в «Видеокарты»
