Слетело разрешение экрана
Isemann
Благодарил (а): 2 раза
18 сен 2023, 16:07
После обновления слетело разрешение экрана, в настройках дисплей помечен как неизвестный и не активен выбор разрешения.
LM 21 Cinnamon
Kernel: 6.5.3-2-liquorix-amd64 x86_64 bits: 64 compiler: gcc v: 11.4.0
Desktop: Cinnamon 5.4.12 Distro: Linux Mint 21 Vanessa
base: Ubuntu 22.04 jammy
Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: PRIME H510M-K v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1203
date: 10/27/2021
Info: 6-core model: 11th Gen Intel Core i5-11400F bits: 64 type: MT MCP
arch: Rocket Lake rev: 1 cache: L1: 480 KiB L2: 3 MiB L3: 12 MiB
Speed (MHz): avg: 1976 high: 4345 min/max: 800/4400 cores: 1: 4345 2: 800
3: 4317 4: 4314 5: 800 6: 4344 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
bogomips: 62208
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Gigabyte driver: N/A
bus-ID: 01:00.0
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: nouveau,vesa
unloaded: fbdev,modesetting gpu: N/A resolution: 1024x768~76Hz
OpenGL: renderer: llvmpipe (LLVM 15.0.7 256 bits)
v: 4.5 Mesa 23.0.4-0ubuntu1~22.04.1 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Sound Server-1: ALSA v: k6.5.3-2-liquorix-amd64 running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6
Local Storage: total: 1.14 TiB used: 704.25 GiB (60.5%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SWORDFISH size: 232.89 GiB
temp: 40.9 C
ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-00BBHA0
ID-1: / size: 93.31 GiB used: 57.96 GiB (62.1%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 486 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 117.43 GiB used: 28.11 GiB (23.9%) fs: ext4
dev: /dev/nvme0n1p5
Swap:
ID-1: swap-1 type: partition size: 15.26 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p4
System Temperatures: cpu: 27.8 C mobo: N/A
Processes: 274 Uptime: 8m Memory: 15.47 GiB used: 2.17 GiB (14.0%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2950 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Разрешение 2.png (5.04 КБ) 1547 просмотров
Благодарил (а): 794 раза
18 сен 2023, 16:34
Isemann писал(а):
18 сен 2023, 16:07
Драйвер на невидию слетел. Попробуй удалить, перезагрузиться, установить, перезагрузиться
Isemann
18 сен 2023, 16:36
Помогла смена на другой, но там была ошибка.
