Ошибки обновления пакетов
1o4ka
Благодарил (а): 23 раза
04 сен 2023, 13:59
LM 21.2 Cinnamon x64
$ inxi -Fxz
Kernel: 5.15.0-82-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
Desktop: Cinnamon 5.8.4 Distro: Linux Mint 21.2 Victoria
base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP Laptop 15s-eq1xxx v: N/A
serial: <superuser required>
Mobo: HP model: 8706 v: 99.42 serial: <superuser required> UEFI: AMI
v: F.67 date: 12/29/2022
ID-1: BAT0 charge: 41.0 Wh (100.0%) condition: 41.0/41.0 Wh (100.0%)
volts: 12.3 min: 11.3 model: Hewlett-Packard Primary status: Full
Info: dual core model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 192 KiB
L2: 1024 KiB L3: 4 MiB
Speed (MHz): avg: 2267 high: 2654 min/max: 1400/2600 boost: enabled
cores: 1: 1781 2: 2654 3: 2508 4: 2125 bogomips: 20760
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 04:00.0
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5.2:5
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon Vega 3 Graphics (raven2 LLVM 15.0.7 DRM 3.42
5.15.0-82-generic)
v: 4.6 Mesa 23.0.4-0ubuntu1~22.04.1 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.1
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.6
Sound Server-1: ALSA v: k5.15.0-82-generic running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: f000
bus-ID: 02:00.0
Bluetooth:
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-4:3
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter>
bt-v: 2.1 lmp-v: 4.2
Local Storage: total: 238.47 GiB used: 120.66 GiB (50.6%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC711 HFM256GD3JX013N
size: 238.47 GiB temp: 26.9 C
ID-1: / size: 38.32 GiB used: 21.56 GiB (56.2%) fs: ext4
dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 96 MiB used: 55.4 MiB (57.7%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 157.36 GiB used: 99.05 GiB (62.9%) fs: ext4
dev: /dev/nvme0n1p5
Swap:
ID-1: swap-1 type: file size: 1.82 GiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 48.0 C mobo: N/A gpu: amdgpu temp: 57.0 C
Processes: 261 Uptime: 4h 0m Memory: 5.7 GiB used: 3.56 GiB (62.5%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2832 Shell: Bash
v: 5.1.16 inxi: 3.3.13
В связи с плохим интернетом, обновления Wine загрузились с ошибками. При загрузке очередных обновлений система сигнализирует:
Подскажите, как зайти, собственно, в этот фильтр "С ошибками"? И как исправить ошибки?
Дело в том, что после загрузки обновлений с ошибками, приложения под Wine перестали запускаться. (в частности, очень востребованный Word 2003).
...bis dat qui cito dat
04 сен 2023, 14:01
Пробегитесь по нужным вам кнопочкам
Можно так же попробовать
sudo apt install -f
04 сен 2023, 14:03
1o4ka писал(а):
04 сен 2023, 13:59
synaptic
1o4ka
05 сен 2023, 05:37
Dja,
sudo apt install -f сработало. Приложения из-под Wine стали запускаться. Но вот, дёрнуло меня пробежаться по "нужным" кнопочкам... Пропали источники обновлений:
Попытка восстановить по умолчанию:
Заканчивается не тем, чем хотелось бы:
Что можно предпринять?
05 сен 2023, 06:12
1o4ka писал(а):
05 сен 2023, 05:37
Погуглить.
https://dzen.ru/a/ZJALFwLql3Mu-fon
1o4ka
05 сен 2023, 07:58
symon2014, из погуглить ничего не вышло. Ссылка предлагаемая автором статьи, не работает. При запуске в терминале появляется сообщение:
Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
машинный перевод:
Предупреждение: apt-key устарел. Вместо этого управляйте файлами наборов ключей в файлеtrusted.gpg.d (см. apt-key(8)).
Дабы долго не мучиться, удалил Яндекс браузер. Но всё равно, Менеджер обновлений предлагает переключиться на другое зеркало. При попытке переключится выскакивает сообщение:
Интернет есть. Пусть не такой хороший, но - всё таки.
Что ещё можно предпринять?
05 сен 2023, 08:47
1o4ka писал(а):
05 сен 2023, 07:58
машинный перевод:
Не нужен перевод. Лучше показывайте весь вывод терминала , начиная с ввода команды.
1o4ka
05 сен 2023, 08:58
symon2014, так нет уже Яндекса (удалил всё; в synaptic'e).
Сейчас вот что пишет:
gpg: не найдено данных формата OpenPGP.
sveta13
Благодарил (а): 47 раз
05 сен 2023, 09:06
Может так попробовать:
sudo apt -f install --reinstall xfce4-panel
sudo dpkg-reconfigure $(sudo dpkg -l | grep xfce | awk '{print $2}' | tr '\n' ' ')
sudo update-initramfs -u
reboot
или так проще
Alt+f2 -> xfce4-panel -> run
Вместо xfce4 вводишь Cinnamon (какой там он у тебя). :smile:
reboot
Debian 12 xfce:LM-22.1 xfce:
05 сен 2023, 09:11
1o4ka писал(а):
05 сен 2023, 08:58
Я наверно плохо пишу на русском.
05 сен 2023, 08:47
05 сен 2023, 09:12
sveta13 писал(а):
05 сен 2023, 09:06
Не советую.
sveta13
05 сен 2023, 09:21
Почему??? Хуже ИХМО не будет :smile: .
1o4ka
05 сен 2023, 09:24
05 сен 2023, 09:11
Может так понятнее:
sveta13
05 сен 2023, 09:45
1o4ka. Я не поняла у тебя проблема с обновлениями на панели или в системе???
sudo apt update && sudo apt upgrade
1o4ka
05 сен 2023, 10:00
sveta13 писал(а):
05 сен 2023, 09:45
Вот моя проблема:
При попытке исправить положение дел (в источниках приложений), получаю вот это:
Как исправить создавшееся положение дел?
05 сен 2023, 10:04
1o4ka писал(а):
05 сен 2023, 09:24
Может так понятнее:
А прочитать и осознать вывод никак? В сети информации вагон. Читай и просвещайся
1o4ka
05 сен 2023, 10:06
sveta13 писал(а):
05 сен 2023, 09:45
sudo apt update
sudo apt update
[sudo] пароль для oleg:
Игн:1 http://archive.ubuntu.com/ubuntu jammy InRelease
Игн:2 http://security.ubuntu.com/ubuntu jammy-security InRelease
Игн:3 http://dl.winehq.org/wine-builds/ubuntu jammy InRelease
Игн:4 https://ppa.launchpadcontent.net/daniel ... zer/ubuntu jammy InRelease
Игн:5 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
Ошб:3 http://dl.winehq.org/wine-builds/ubuntu jammy InRelease
Не удалось соединиться с dl.winehq.org:80 (146.75.118.217): время ожидания для соединения истекло
Игн:6 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
Игн:7 http://packages.linuxmint.com victoria InRelease
Ошб:2 http://security.ubuntu.com/ubuntu jammy-security InRelease
Не удалось разрешить «security.ubuntu.com»
Ошб:4 https://ppa.launchpadcontent.net/daniel ... zer/ubuntu jammy InRelease
Не удалось разрешить «ppa.launchpadcontent.net»
Ошб:1 http://archive.ubuntu.com/ubuntu jammy InRelease
Не удалось разрешить «archive.ubuntu.com»
Ошб:5 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
Ошб:6 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
Ошб:7 http://packages.linuxmint.com victoria InRelease
Соединение разорвано [IP: 68.235.39.11 80]
Построение дерева зависимостей… Готово
Может быть обновлено 14 пакетов. Запустите «apt list --upgradable» для их показа.
W: Не удалось получить https://ppa.launchpadcontent.net/daniel ... /InRelease Не удалось разрешить «ppa.launchpadcontent.net»
W: Не удалось получить http://packages.linuxmint.com/dists/victoria/InRelease Соединение разорвано [IP: 68.235.39.11 80]
W: Не удалось получить http://archive.ubuntu.com/ubuntu/dists/jammy/InRelease Не удалось разрешить «archive.ubuntu.com»
W: Не удалось получить http://archive.ubuntu.com/ubuntu/dists/ ... /InRelease Не удалось разрешить «archive.ubuntu.com»
W: Не удалось получить http://security.ubuntu.com/ubuntu/dists ... /InRelease Не удалось разрешить «security.ubuntu.com»
W: Не удалось получить http://dl.winehq.org/wine-builds/ubuntu ... /InRelease Не удалось соединиться с dl.winehq.org:80 (146.75.118.217): время ожидания для соединения истекло
W: Некоторые индексные файлы скачать не удалось. Они были проигнорированы, или вместо них были использованы старые версии.
1o4ka
05 сен 2023, 10:08
rogoznik, не нужны эти ключи. Приложение удалено. Проблема - в другом. См выше.
05 сен 2023, 10:10
05 сен 2023, 10:11
1o4ka писал(а):
05 сен 2023, 10:08
не нужны эти ключи
А на кой ты тогда показываешь вывод с добавлением ключа?
Ты разберись что тебе надо и в с чем у тебя проблема.
А потом уже проси помощи в решении
