Совмещение икон паков
Sectos05
Благодарил (а): 4 раза
13 авг 2023, 20:25
EndeavourOS 6.4.10-arch1-1
Cinnamon 5.8.4
Kernel: 6.4.10-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: Cinnamon v: 5.8.4 Distro: EndeavourOS base: Arch Linux
Type: Desktop Mobo: ASRock model: B450M-HDV R4.0
serial: <superuser required> UEFI: American Megatrends v: P3.70
date: 11/14/2019
Info: 6-core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ rev: 2
cache: L1: 576 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 2314 high: 3438 min/max: 1550/3400 boost: enabled cores:
1: 3154 2: 3405 3: 1370 4: 1557 5: 1289 6: 2793 7: 3438 8: 1340 9: 1415
10: 1284 11: 3401 12: 3323 bogomips: 81469
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Micro-Star MSI
driver: nvidia v: 535.98 arch: Maxwell bus-ID: 09:00.0
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: nvidia
unloaded: modesetting gpu: nvidia,nvidia-nvswitch resolution: 1920x1080~60Hz
API: OpenGL v: 4.6.0 NVIDIA 535.98 renderer: NVIDIA GeForce GTX
960/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GM206 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 09:00.1
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 0b:00.3
API: ALSA v: k6.4.10-arch1-1 status: kernel-api
Server-1: PipeWire v: 0.3.77 status: active
vendor: ASRock driver: r8169 v: kernel port: f000 bus-ID: 08:00.0
IF: enp8s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 465.76 GiB used: 228.55 GiB (49.1%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SNVS500G size: 465.76 GiB
temp: 37.9 C
ID-1: / size: 91.11 GiB used: 18.11 GiB (19.9%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /home size: 365.24 GiB used: 210.21 GiB (57.6%) fs: ext4
dev: /dev/nvme0n1p3
Swap:
Alert: No swap data was found.
System Temperatures: cpu: 40.2 C mobo: N/A
Processes: 301 Uptime: 6h 56m Memory: total: 16 GiB available: 15.55 GiB
used: 5.28 GiB (34.0%) Init: systemd Compilers: gcc: 13.2.1 Packages: 1198
Shell: Bash v: 5.1.16 inxi: 3.3.28
В общем, дело такое. Скачал икон пак Oxylite. Иконки приложений в нём просто отменные, но вот жёлтые папки никуда не годятся. Папки очень крутые в паке Baphomet, но иконки приложений там дефолтные и уродские.
Вопрос: можно ли совместить эти паки так, чтобы папки были из "бафомета", а всё остальное - из "оксилайта"?
Как я понял, значки папок находятся в папке "places". Но в этих двух паках содержимое этих папок выглядит по-разному. В oxylite эти файлы лежат сплошняком, а в baphomet раскиданы по папкам с названиями "16", "22", "24" и т.д. Вот и не могу понять, что куда кидать.
14 авг 2023, 11:46
Sectos05 писал(а):
13 авг 2023, 20:25
В oxylite ваши папки 256x256. Вероятно, придётся искать значки папок, такие как в baphomet или аналогичные им, с размерами 256х256. И то не все, а те, которые нужны. Или покрасьте папки oxylite так как вам нравится, встречал такие инструменты online.
Sectos05
14 авг 2023, 20:46
madesta писал(а):
14 авг 2023, 11:46
В общем, перекинул с заменой всё из папки "Baphomet/places/96/" в "oxylite/places/", и вроде как заработало :)
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
14 авг 2023, 21:51
Есть ещё один вариант, альтернативный. В любом иконпаке есть файл index.theme. А в нём есть параметр "Inherits" (Наследует), в котором можно указать "запасную" тему, иконки из которой будут подгружаться, если не найдётся нужной. Можно указать даже несколько тем через запятую. Соответственно, в одной теме можно оставить только нужные разделы, а всё остальное будет подхватываться из другой. Ну и имя темы там же лучше поменять.
[Icon Theme]
Name=atkv@test
Comment=Mix of Adwaita and Numix circle
Inherits=Adwaita
Example=directory-x-normal
# Directory list
Directories=48/apps,48@2x/apps
[48/apps]
Size=48
Context=Applications
MinSize=8
MaxSize=512
Type=Scalable
[48@2x/apps]
Size=48
Scale=2
MinSize=8
MaxSize=512
Type=Scalable
15 авг 2023, 04:23
Ара Магеддон писал(а):
14 авг 2023, 21:51
При модификации темы я бы ещё сделал sudo gtk-update-icon-cache путь_к_папке_с_темой_значков
