для тестов ставил win 10, там все работает без ошибок, под Linux Mint если вытащить M2 SSD nvme, то все так же работает нормально, пробовал ядра начиная с 5.04 до 6.х, результат один и тот же
текущая конфигурация ПК:
Kernel: 6.2.0-25-generic x86_64 bits: 64 compiler: N/A Desktop: Cinnamon 5.8.4 tk: GTK 3.24.33
wm: muffin dm: LightDM Distro: Linux Mint 21.2 Victoria base: Ubuntu 22.04 jammy
Type: Desktop System: Gigabyte product: B550M AORUS ELITE v: N/A serial: <superuser required>
Mobo: Gigabyte model: B550M AORUS ELITE v: x.x serial: <superuser required>
BIOS: American Megatrends LLC. v: FB date: 11/14/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard PID:0065 serial: N/A
charge: 70% (should be ignored) status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse PID:003d serial: N/A
charge: 55% (should be ignored) status: Discharging
Info: 6-core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3 rev: 2 cache:
L1: 384 KiB L2: 3 MiB L3: 32 MiB
Speed (MHz): avg: 3586 high: 3703 min/max: 2200/4650 boost: enabled cores: 1: 3540 2: 3584
3: 3544 4: 3535 5: 3690 6: 3604 7: 3527 8: 3579 9: 3542 10: 3576 11: 3703 12: 3608
bogomips: 88629
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 535.54.03 pcie: speed: 8 GT/s
lanes: 16 ports: active: none off: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 04:00.0
chip-ID: 10de:1c82
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 92
Monitor-1: DVI-D-0 pos: primary,left res: 1920x1080 dpi: 93 diag: 604mm (23.8")
Monitor-2: HDMI-0 pos: primary,right res: 1920x1080 dpi: 93 diag: 604mm (23.8")
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 535.54.03
Device-1: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel v: kernel pcie:
speed: 8 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 10de:0fb9
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
speed: 16 GT/s lanes: 16 bus-ID: 06:00.4 chip-ID: 1022:1487
Sound Server-1: ALSA v: k6.2.0-25-generic running: yes
Device-1: TP-Link Archer T4U v2 [Realtek RTL8812AU] type: USB driver: rtl88XXau bus-ID: 3-4:2
chip-ID: 2357:010d
IF: wlan0 state: up mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Bluetooth:
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8
bus-ID: 1-8:4 chip-ID: 0a12:0001
Report: hciconfig ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 2.1 lmp-v: 4.0
sub-v: 22bb
Local Storage: total: 1.61 TiB used: 787.9 GiB (47.8%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SX8200PNP size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
serial: <filter> temp: 29.9 C
ID-2: /dev/sda vendor: Apacer model: AS350 256GB size: 238.47 GiB speed: 6.0 Gb/s
serial: <filter>
ID-3: /dev/sdb vendor: Western Digital model: WD10EZRZ-00HTKB0 size: 931.51 GiB
speed: 6.0 Gb/s serial: <filter>
ID-1: / size: 232.73 GiB used: 40.65 GiB (17.5%) fs: ext4 dev: /dev/sda5
ID-2: /boot size: 1.94 GiB used: 592 MiB (29.7%) fs: ext2 dev: /dev/sda2
ID-3: /home size: 469.39 GiB used: 100.75 GiB (21.5%) fs: ext4 dev: /dev/nvme0n1p1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
System Temperatures: cpu: 49.0 C mobo: 34.0 C gpu: nvidia temp: 39 C
Fan Speeds (RPM): cpu: 961 fan-1: 2376 fan-3: 0 gpu: nvidia fan: 30%
Power: 12v: N/A 5v: N/A 3.3v: N/A vbat: 3.05
Repos:
Packages: 2982 apt: 2973 flatpak: 9
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/docker.list
1: deb [arch=amd64 signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https: //download.docker.com/linux/ubuntu focal stable
Active apt repos in: /etc/apt/sources.list.d/nilarimogard-webupd8-focal.list
1: deb [signed-by=/etc/apt/keyrings/nilarimogard-webupd8.gpg] http: //ppa.launchpad.net/nilarimogard/webupd8/ubuntu focal main
1: deb http: //packages.linuxmint.com victoria main upstream import backport
2: deb http: //archive.ubuntu.com/ubuntu jammy main restricted universe multiverse
3: deb http: //archive.ubuntu.com/ubuntu jammy-updates main restricted universe multiverse
4: deb http: //archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
Active apt repos in: /etc/apt/sources.list.d/teejee2008-timeshift-jammy.list
1: deb [signed-by=/etc/apt/keyrings/teejee2008-timeshift-jammy.gpg] https: //ppa.launchpadcontent.net/teejee2008/timeshift/ubuntu jammy main
Active apt repos in: /etc/apt/sources.list.d/vscode.list
1: deb [arch=amd64,arm64,armhf signed-by=/etc/apt/trusted.gpg.d/packages.microsoft.gpg] https: //packages.microsoft.com/repos/code stable main
Active apt repos in: /etc/apt/sources.list.d/winehq-focal.sources
1: deb [arch=amd64 i386] https: //dl.winehq.org/wine-builds/ubuntu focal main
Processes: 327 Uptime: 9m Memory: 31.26 GiB used: 2.75 GiB (8.8%) Init: systemd v: 249
runlevel: 5 default: 2 Compilers: gcc: 11.3.0 alt: 11/12/9 Client: Unknown python3.10 client
inxi: 3.3.13
