Cinnamon 5.8.4
Kernel: 6.4.4-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
Desktop: Cinnamon v: 5.8.4 Distro: EndeavourOS base: Arch Linux
Type: Desktop Mobo: ASRock model: B450M-HDV R4.0
serial: <superuser required> UEFI: American Megatrends v: P3.70
date: 11/14/2019
Info: 6-core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ rev: 2
cache: L1: 576 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 1613 high: 2632 min/max: 1550/3400 boost: enabled cores:
1: 2632 2: 1550 3: 1605 4: 1390 5: 1547 6: 1550 7: 1563 8: 1568 9: 1379
10: 1482 11: 1550 12: 1550 bogomips: 81469
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Micro-Star MSI
driver: nvidia v: 535.86.05 arch: Maxwell bus-ID: 09:00.0
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: nvidia
unloaded: modesetting gpu: nvidia,nvidia-nvswitch resolution: 1920x1080~60Hz
API: OpenGL v: 4.6.0 NVIDIA 535.86.05 renderer: NVIDIA GeForce GTX
960/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GM206 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 09:00.1
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 0b:00.3
API: ALSA v: k6.4.4-arch1-1 status: kernel-api
Server-1: PipeWire v: 0.3.74 status: active
vendor: ASRock driver: r8169 v: kernel port: f000 bus-ID: 08:00.0
IF: enp8s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 473.22 GiB used: 170.78 GiB (36.1%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SNVS500G size: 465.76 GiB
temp: 37.9 C
ID-2: /dev/sda vendor: SanDisk model: Cruzer Force size: 7.45 GiB
type: USB
ID-1: / size: 91.11 GiB used: 11.34 GiB (12.4%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /home size: 365.24 GiB used: 159.22 GiB (43.6%) fs: ext4
dev: /dev/nvme0n1p3
Swap:
Alert: No swap data was found.
System Temperatures: cpu: 33.0 C mobo: N/A
Processes: 316 Uptime: 46m Memory: total: 16 GiB available: 15.55 GiB
used: 5.23 GiB (33.7%) Init: systemd Compilers: gcc: 13.1.1 Packages: 1170
Shell: Bash v: 5.1.16 inxi: 3.3.28
date: 11/14/2019
temp: 37.9 C
type: USB
dev: /dev/nvme0n1p3
Swap:
В общем вопрос: есть ли способ чётко узнать, какая тема какой стиль приложений имеет? Или ещё проще: подскажите конкретные темы с кнопками нормального стиля и размера.
Из тех, что видно на скрине, вменяемо выглядят только кнопки из темы "Jade 1 blue", разве что они без значков, просто кругляшки. В "Graphite" тоже большие, но там они, блин, цветные. Мерзость.
