Долгая загрузка (причина в Kernel)
Santyago
07 июл 2023, 16:40
Прошу помощи специалистов. Mint 21.
fixftp@APC-linux:~$ systemd-analyze
Startup finished in 116us (firmware) + 100us (loader) + 36.768s (kernel) + 5.704s (userspace) = 42.473s
graphical.target reached after 5.695s in userspace
fixftp@APC-linux:~$ systemd-analyze blame
1min 7.728s mintupdate-automation-upgrade.service
41.695s fstrim.service
2.491s systemd-udev-settle.service
2.057s NetworkManager-wait-online.service
1.198s vboxdrv.service
986ms winbind.service
917ms apt-daily-upgrade.service
581ms dev-sdc2.device
514ms systemd-random-seed.service
476ms blueman-mechanism.service
456ms logrotate.service
295ms networkd-dispatcher.service
290ms udisks2.service
256ms systemd-resolved.service
253ms zfs-load-module.service
249ms lightdm.service
244ms plymouth-quit-wait.service
232ms user@1000.service
226ms cups.service
200ms ModemManager.service
193ms systemd-logind.service
192ms accounts-daemon.service
183ms apparmor.service
183ms ua-timer.service
182ms networking.service
179ms e2scrub_reap.service
173ms systemd-timesyncd.service
165ms ubuntu-system-adjustments.service
131ms systemd-journal-flush.service
120ms systemd-udev-trigger.service
118ms mnt-E.mount
113ms update-notifier-download.service
111ms bluetooth.service
111ms NetworkManager.service
100ms systemd-journald.service
96ms grub-common.service
91ms systemd-fsck@dev-disk-by\x2duuid-73fcedc9\x2db9a6\x2d4125\x2d9e00\x2d6ae12a2d855d.service
90ms mnt-D.mount
89ms avahi-daemon.service
88ms gpu-manager.service
87ms keyboard-setup.service
86ms secureboot-db.service
86ms systemd-udevd.service
81ms polkit.service
80ms upower.service
80ms preload.service
78ms lvm2-monitor.service
74ms alsa-restore.service
65ms modprobe@chromeos_pstore.service
63ms systemd-rfkill.service
60ms dev-disk-by\x2duuid-7ff6bf96\x2dd5be\x2d4aab\x2d950a\x2d693b1f82e3db.swap
59ms atopacct.service
56ms wpa_supplicant.service
51ms rsyslog.service
49ms mnt-C.mount
48ms lm-sensors.service
45ms thermald.service
44ms colord.service
38ms nvidia-persistenced.service
36ms systemd-sysctl.service
31ms mnt-Manjaro.mount
28ms packagekit.service
27ms systemd-modules-load.service
27ms dev-hugepages.mount
26ms dev-mqueue.mount
fixftp@APC-linux:~$ cat /etc/fstab
UUID=a4feb00d-8dd9-4224-84f8-6f2b4aee2411 / ext4 errors=remount-ro 0 1
UUID=08FC3B70FC3B5762 /mnt/C ntfs-3g uid=fixftp,gid=users,dmask=022,fmask=133 0 2
UUID=115276CE055F4BEF /mnt/D ntfs-3g uid=fixftp,gid=users,dmask=022,fmask=133 0 2
UUID=7ff6bf96-d5be-4aab-950a-693b1f82e3db swap swap defaults,noatime 0 0
UUID=73fcedc9-b9a6-4125-9e00-6ae12a2d855d /mnt/Manjaro ext4 defaults 0 2
UUID=cbe00223-1192-4b61-ab9e-bd574bb3958c /mnt/E ext4 defaults 0 0
tmpfs /tmp tmpfs nodev,nosuid,noexec,size=1000M 0 0
#UUID=7dd18091-c868-48aa-a1e7-dc0de6f7770e /mnt/F ext4 defaults 0 2
fixftp@APC-linux:~$ lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1 vfat FAT32 5790-780A
├─sda2 ext4 1.0 73fcedc9-b9a6-4125-9e00-6ae12a2d855d 78,4G 79% /mnt/Manjaro
├─sda3 swap 1 swap 7ff6bf96-d5be-4aab-950a-693b1f82e3db [SWAP]
└─sda4 ntfs 115276CE055F4BEF 322,5G 23% /mnt/D
sdb
├─sdb1 ntfs Восстановить 90B03397B0338330
├─sdb2 vfat FAT32 3A36-F0E0
├─sdb3
└─sdb4 ntfs C 08FC3B70FC3B5762 31,2G 74% /mnt/C
sdc
└─sdc2 ext4 1.0 a4feb00d-8dd9-4224-84f8-6f2b4aee2411 405,1G 6% /
sdd
└─sdd1 ext4 1.0 cbe00223-1192-4b61-ab9e-bd574bb3958c 429,9G 1% /mnt/E
sdd1 не хотел грузится, писал ошибка. В manjaro грузится, при проверке ошибок не выдавал, тут при загрузке встаёт. Хотя если отключить его в fstab, при загрузке вручную монтировался. Поэтому поставил в fstab проверку в 0. Так грузится.
Обратите пожалуйста внимание на 36-ую и 40-ую секунду.
fixftp@APC-linux:~$ dmesg
[ 0.000000] Linux version 5.15.0-60-generic (buildd@lcy02-amd64-054) (gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #66-Ubuntu SMP Fri Jan 20 14:29:49 UTC 2023 (Ubuntu 5.15.0-60.66-generic 5.15.78)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.15.0-60-generic root=UUID=a4feb00d-8dd9-4224-84f8-6f2b4aee2411 ro quiet splash
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] signal: max sigframe size: 1776
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000ba6b5fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ba6b6000-0x00000000ba991fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ba992000-0x00000000ba9a1fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000ba9a2000-0x00000000bb7a7fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bb7a8000-0x00000000bc9c4fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000bc9c5000-0x00000000bca33fff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000bca34000-0x00000000bca34fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bca35000-0x00000000bcc3afff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bcc3b000-0x00000000bd082fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bd083000-0x00000000bd7f3fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000bd7f4000-0x00000000bd7fffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec20000-0x00000000fec20fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed61000-0x00000000fed70fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fef00000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100001000-0x000000043fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.10 by American Megatrends
[ 0.000000] efi: ACPI=0xba999000 ACPI 2.0=0xba999000 SMBIOS=0xf04c0
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: To be filled by O.E.M. To be filled by O.E.M./M5A97 R2.0, BIOS 2603 06/26/2015
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 4013.380 MHz processor
[ 0.001215] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001218] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.009104] AGP: No AGP bridge found
[ 0.009175] last_pfn = 0x440000 max_arch_pfn = 0x400000000
[ 0.009953] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.010185] total RAM covered: 3032M
[ 0.010411] Found optimal setting for mtrr clean up
[ 0.010412] gran_size: 64K chunk_size: 64M num_reg: 4 lose cover RAM: 0G
[ 0.011007] e820: update [mem 0xbd800000-0xffffffff] usable ==> reserved
[ 0.011017] last_pfn = 0xbd800 max_arch_pfn = 0x400000000
[ 0.015394] Using GB pages for direct mapping
[ 0.016090] secureboot: Secure boot disabled
[ 0.016091] RAMDISK: [mem 0x1cff9000-0x2a7f3fff]
[ 0.016099] ACPI: Early table checksum verification disabled
[ 0.016103] ACPI: RSDP 0x00000000BA999000 000024 (v02 ALASKA)
[ 0.016107] ACPI: XSDT 0x00000000BA999070 000054 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.016114] ACPI: FACP 0x00000000BA9A01F0 00010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.016120] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20210730/tbfadt-615)
[ 0.016125] ACPI: DSDT 0x00000000BA999158 007095 (v02 ALASKA A M I 00000000 INTL 20051117)
[ 0.016130] ACPI: FACS 0x00000000BB7A2F80 000040
[ 0.016133] ACPI: APIC 0x00000000BA9A0300 00009E (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.016137] ACPI: FPDT 0x00000000BA9A03A0 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.016141] ACPI: MCFG 0x00000000BA9A03E8 00003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.016145] ACPI: HPET 0x00000000BA9A0428 000038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.016149] ACPI: SSDT 0x00000000BA9A04B8 000D3C (v01 AMD POWERNOW 00000001 AMD 00000001)
[ 0.016152] ACPI: Reserving FACP table memory at [mem 0xba9a01f0-0xba9a02fb]
[ 0.016154] ACPI: Reserving DSDT table memory at [mem 0xba999158-0xba9a01ec]
[ 0.016156] ACPI: Reserving FACS table memory at [mem 0xbb7a2f80-0xbb7a2fbf]
[ 0.016157] ACPI: Reserving APIC table memory at [mem 0xba9a0300-0xba9a039d]
[ 0.016159] ACPI: Reserving FPDT table memory at [mem 0xba9a03a0-0xba9a03e3]
[ 0.016160] ACPI: Reserving MCFG table memory at [mem 0xba9a03e8-0xba9a0423]
[ 0.016162] ACPI: Reserving HPET table memory at [mem 0xba9a0428-0xba9a045f]
[ 0.016163] ACPI: Reserving SSDT table memory at [mem 0xba9a04b8-0xba9a11f3]
[ 0.016315] No NUMA configuration found
[ 0.016317] Faking a node at [mem 0x0000000000000000-0x000000043fffffff]
[ 0.016328] NODE_DATA(0) allocated [mem 0x43ffd4000-0x43fffdfff]
[ 0.016734] Zone ranges:
[ 0.016735] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.016737] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.016739] Normal [mem 0x0000000100000000-0x000000043fffffff]
[ 0.016741] Device empty
[ 0.016742] Movable zone start for each node
[ 0.016744] Early memory node ranges
[ 0.016745] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.016746] node 0: [mem 0x0000000000100000-0x00000000ba6b5fff]
[ 0.016748] node 0: [mem 0x00000000bca34000-0x00000000bca34fff]
[ 0.016749] node 0: [mem 0x00000000bcc3b000-0x00000000bd082fff]
[ 0.016750] node 0: [mem 0x00000000bd7f4000-0x00000000bd7fffff]
[ 0.016751] node 0: [mem 0x0000000100001000-0x000000043fffffff]
[ 0.016754] Initmem setup node 0 [mem 0x0000000000001000-0x000000043fffffff]
[ 0.016760] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.016798] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.025378] On node 0, zone DMA32: 9086 pages in unavailable ranges
[ 0.025407] On node 0, zone DMA32: 518 pages in unavailable ranges
[ 0.025437] On node 0, zone DMA32: 1905 pages in unavailable ranges
[ 0.064249] On node 0, zone Normal: 10241 pages in unavailable ranges
[ 0.064469] ACPI: PM-Timer IO Port: 0x808
[ 0.064480] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.064488] IOAPIC[0]: apic_id 9, version 33, address 0xfec00000, GSI 0-23
[ 0.064492] IOAPIC[1]: apic_id 10, version 33, address 0xfec20000, GSI 24-55
[ 0.064494] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.064497] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.064501] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.064502] ACPI: HPET id: 0x43538210 base: 0xfed00000
[ 0.064509] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.064535] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.064538] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.064541] PM: hibernation: Registered nosave memory: [mem 0xba6b6000-0xba991fff]
[ 0.064542] PM: hibernation: Registered nosave memory: [mem 0xba992000-0xba9a1fff]
[ 0.064543] PM: hibernation: Registered nosave memory: [mem 0xba9a2000-0xbb7a7fff]
[ 0.064544] PM: hibernation: Registered nosave memory: [mem 0xbb7a8000-0xbc9c4fff]
[ 0.064545] PM: hibernation: Registered nosave memory: [mem 0xbc9c5000-0xbca33fff]
[ 0.064547] PM: hibernation: Registered nosave memory: [mem 0xbca35000-0xbcc3afff]
[ 0.064549] PM: hibernation: Registered nosave memory: [mem 0xbd083000-0xbd7f3fff]
[ 0.064551] PM: hibernation: Registered nosave memory: [mem 0xbd800000-0xfebfffff]
[ 0.064552] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.064553] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfec0ffff]
[ 0.064554] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[ 0.064555] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfec1ffff]
[ 0.064556] PM: hibernation: Registered nosave memory: [mem 0xfec20000-0xfec20fff]
[ 0.064557] PM: hibernation: Registered nosave memory: [mem 0xfec21000-0xfecfffff]
[ 0.064558] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.064558] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed60fff]
[ 0.064559] PM: hibernation: Registered nosave memory: [mem 0xfed61000-0xfed70fff]
[ 0.064560] PM: hibernation: Registered nosave memory: [mem 0xfed71000-0xfed7ffff]
[ 0.064561] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[ 0.064562] PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xfeefffff]
[ 0.064563] PM: hibernation: Registered nosave memory: [mem 0xfef00000-0xffffffff]
[ 0.064564] PM: hibernation: Registered nosave memory: [mem 0x100000000-0x100000fff]
[ 0.064565] [mem 0xbd800000-0xfebfffff] available for PCI devices
[ 0.064568] Booting paravirtualized kernel on bare hardware
[ 0.064571] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.064580] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.065094] percpu: Embedded 60 pages/cpu s208896 r8192 d28672 u262144
[ 0.065104] pcpu-alloc: s208896 r8192 d28672 u262144 alloc=1*2097152
[ 0.065107] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.065146] Built 1 zonelists, mobility grouping on. Total pages: 4107101
[ 0.065147] Policy zone: Normal
[ 0.065149] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15.0-60-generic root=UUID=a4feb00d-8dd9-4224-84f8-6f2b4aee2411 ro quiet splash
[ 0.065213] Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-5.15.0-60-generic", will be passed to user space.
[ 0.067889] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.069246] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.069289] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.091082] AGP: Checking aperture...
[ 0.098962] AGP: No AGP bridge found
[ 0.098964] AGP: Node 0: aperture [bus addr 0x00000000-0x01ffffff] (32MB)
[ 0.098967] AGP: Your BIOS doesn't leave an aperture memory hole
[ 0.098968] AGP: Please enable the IOMMU option in the BIOS setup
[ 0.098968] AGP: This costs you 64MB of RAM
[ 0.098973] AGP: Mapping aperture over RAM [mem 0xa4000000-0xa7ffffff] (65536KB)
[ 0.098977] PM: hibernation: Registered nosave memory: [mem 0xa4000000-0xa7ffffff]
[ 0.153071] Memory: 15791572K/16689828K available (16393K kernel code, 4379K rwdata, 10820K rodata, 3240K init, 6560K bss, 897996K reserved, 0K cma-reserved)
[ 0.153394] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.153413] ftrace: allocating 50540 entries in 198 pages
[ 0.176260] ftrace: allocated 198 pages with 4 groups
[ 0.176428] rcu: Hierarchical RCU implementation.
[ 0.176429] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=8.
[ 0.176431] Rude variant of Tasks RCU enabled.
[ 0.176432] Tracing variant of Tasks RCU enabled.
[ 0.176432] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.176433] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.180937] NR_IRQS: 524544, nr_irqs: 1032, preallocated irqs: 16
[ 0.181298] Console: colour dummy device 80x25
[ 0.181312] printk: console [tty0] enabled
[ 0.181340] ACPI: Core revision 20210730
[ 0.181448] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.181462] APIC: Switch to symmetric I/O mode setup
[ 0.181911] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.201463] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x39d9bbf0b5d, max_idle_ns: 440795268303 ns
[ 0.201468] Calibrating delay loop (skipped), value calculated using timer frequency.. 8026.76 BogoMIPS (lpj=16053520)
[ 0.201471] pid_max: default: 32768 minimum: 301
[ 0.209519] LSM: Security Framework initializing
[ 0.209536] landlock: Up and running.
[ 0.209537] Yama: becoming mindful.
[ 0.209569] AppArmor: AppArmor initialized
[ 0.209661] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.209706] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.210033] LVT offset 1 assigned for vector 0xf9
[ 0.210037] Last level iTLB entries: 4KB 512, 2MB 1024, 4MB 512
[ 0.210039] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 512, 1GB 0
[ 0.210043] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.210045] Spectre V2 : Mitigation: Retpolines
[ 0.210046] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.210047] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[ 0.210047] Spectre V2 : Enabling Speculation Barrier for firmware calls
[ 0.210048] RETBleed: Mitigation: untrained return thunk
[ 0.210050] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.210051] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.221147] Freeing SMP alternatives memory: 40K
[ 0.332400] smpboot: CPU0: AMD FX(tm)-8350 Eight-Core Processor (family: 0x15, model: 0x2, stepping: 0x0)
[ 0.332625] Performance Events: Fam15h core perfctr, AMD PMU driver.
[ 0.332630] ... version: 0
[ 0.332631] ... bit width: 48
[ 0.332632] ... generic registers: 6
[ 0.332632] ... value mask: 0000ffffffffffff
[ 0.332633] ... max period: 00007fffffffffff
[ 0.332634] ... fixed-purpose events: 0
[ 0.332635] ... event mask: 000000000000003f
[ 0.332707] rcu: Hierarchical SRCU implementation.
[ 0.333190] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.333308] smp: Bringing up secondary CPUs ...
[ 0.333466] x86: Booting SMP configuration:
[ 0.333466] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7
[ 0.385532] smp: Brought up 1 node, 8 CPUs
[ 0.385532] smpboot: Max logical packages: 1
[ 0.385532] smpboot: Total of 8 processors activated (64214.08 BogoMIPS)
[ 0.390357] devtmpfs: initialized
[ 0.390357] x86/mm: Memory block size: 128MB
[ 0.394258] ACPI: PM: Registering ACPI NVS region [mem 0xba9a2000-0xbb7a7fff] (14704640 bytes)
[ 0.394258] ACPI: PM: Registering ACPI NVS region [mem 0xbca35000-0xbcc3afff] (2121728 bytes)
[ 0.394258] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.394258] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.394258] pinctrl core: initialized pinctrl subsystem
[ 0.394258] PM: RTC time: 12:40:25, date: 2023-07-07
[ 0.394309] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.394657] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.394902] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.395146] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.395156] audit: initializing netlink subsys (disabled)
[ 0.395168] audit: type=2000 audit(1688733624.212:1): state=initialized audit_enabled=0 res=1
[ 0.395168] thermal_sys: Registered thermal governor 'fair_share'
[ 0.395168] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.395168] thermal_sys: Registered thermal governor 'step_wise'
[ 0.395168] thermal_sys: Registered thermal governor 'user_space'
[ 0.395168] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.395168] EISA bus registered
[ 0.395168] cpuidle: using governor ladder
[ 0.395168] cpuidle: using governor menu
[ 0.395168] ACPI: bus type PCI registered
[ 0.395168] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.395168] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.395168] PCI: not using MMCONFIG
[ 0.395168] PCI: Using configuration type 1 for base access
[ 0.395168] PCI: Using configuration type 1 for extended access
[ 0.398718] Kprobes globally optimized
[ 0.398723] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.398723] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.398723] ACPI: Added _OSI(Module Device)
[ 0.398723] ACPI: Added _OSI(Processor Device)
[ 0.398723] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.398723] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.398723] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.398723] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.398723] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.406862] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.408287] ACPI: EC: EC started
[ 0.408288] ACPI: EC: interrupt blocked
[ 0.408295] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.408297] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC used to handle transactions
[ 0.408299] ACPI: Interpreter enabled
[ 0.408318] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.408319] ACPI: Using IOAPIC for interrupt routing
[ 0.408532] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.408592] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.408606] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.408607] PCI: Using E820 reservations for host bridge windows
[ 0.408953] ACPI: Enabled 11 GPEs in block 00 to 1F
[ 0.417693] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.417699] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.418171] PCI host bridge to bus 0000:00
[ 0.418174] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.418177] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.418178] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.418184] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[ 0.418185] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xffffffff window]
[ 0.418304] pci 0000:00:00.0: [1002:5a14] type 00 class 0x060000
[ 0.418542] pci 0000:00:02.0: [1002:5a16] type 01 class 0x060400
[ 0.418569] pci 0000:00:02.0: enabling Extended Tags
[ 0.418601] pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
[ 0.418801] pci 0000:00:04.0: [1002:5a18] type 01 class 0x060400
[ 0.418827] pci 0000:00:04.0: enabling Extended Tags
[ 0.418857] pci 0000:00:04.0: PME# supported from D0 D3hot D3cold
[ 0.419062] pci 0000:00:05.0: [1002:5a19] type 01 class 0x060400
[ 0.419087] pci 0000:00:05.0: enabling Extended Tags
[ 0.419117] pci 0000:00:05.0: PME# supported from D0 D3hot D3cold
[ 0.419309] pci 0000:00:07.0: [1002:5a1b] type 01 class 0x060400
[ 0.419334] pci 0000:00:07.0: enabling Extended Tags
[ 0.419364] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[ 0.419566] pci 0000:00:11.0: [1002:4391] type 00 class 0x010601
[ 0.419582] pci 0000:00:11.0: reg 0x10: [io 0xf040-0xf047]
[ 0.419591] pci 0000:00:11.0: reg 0x14: [io 0xf030-0xf033]
[ 0.419600] pci 0000:00:11.0: reg 0x18: [io 0xf020-0xf027]
[ 0.419608] pci 0000:00:11.0: reg 0x1c: [io 0xf010-0xf013]
[ 0.419616] pci 0000:00:11.0: reg 0x20: [io 0xf000-0xf00f]
[ 0.419625] pci 0000:00:11.0: reg 0x24: [mem 0xfe307000-0xfe3073ff]
[ 0.419831] pci 0000:00:12.0: [1002:4397] type 00 class 0x0c0310
[ 0.419847] pci 0000:00:12.0: reg 0x10: [mem 0xfe306000-0xfe306fff]
[ 0.420071] pci 0000:00:12.2: [1002:4396] type 00 class 0x0c0320
[ 0.420087] pci 0000:00:12.2: reg 0x10: [mem 0xfe305000-0xfe3050ff]
[ 0.420190] pci 0000:00:12.2: supports D1 D2
[ 0.420191] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
[ 0.420374] pci 0000:00:13.0: [1002:4397] type 00 class 0x0c0310
[ 0.420390] pci 0000:00:13.0: reg 0x10: [mem 0xfe304000-0xfe304fff]
[ 0.420613] pci 0000:00:13.2: [1002:4396] type 00 class 0x0c0320
[ 0.420629] pci 0000:00:13.2: reg 0x10: [mem 0xfe303000-0xfe3030ff]
[ 0.420703] pci 0000:00:13.2: supports D1 D2
[ 0.420704] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[ 0.420885] pci 0000:00:14.0: [1002:4385] type 00 class 0x0c0500
[ 0.421128] pci 0000:00:14.3: [1002:439d] type 00 class 0x060100
[ 0.421386] pci 0000:00:14.4: [1002:4384] type 01 class 0x060401
[ 0.421598] pci 0000:00:14.5: [1002:4399] type 00 class 0x0c0310
[ 0.421614] pci 0000:00:14.5: reg 0x10: [mem 0xfe302000-0xfe302fff]
[ 0.421834] pci 0000:00:16.0: [1002:4397] type 00 class 0x0c0310
[ 0.421850] pci 0000:00:16.0: reg 0x10: [mem 0xfe301000-0xfe301fff]
[ 0.422075] pci 0000:00:16.2: [1002:4396] type 00 class 0x0c0320
[ 0.422091] pci 0000:00:16.2: reg 0x10: [mem 0xfe300000-0xfe3000ff]
[ 0.422164] pci 0000:00:16.2: supports D1 D2
[ 0.422165] pci 0000:00:16.2: PME# supported from D0 D1 D2 D3hot
[ 0.422300] pci 0000:00:18.0: [1022:1600] type 00 class 0x060000
[ 0.422460] pci 0000:00:18.1: [1022:1601] type 00 class 0x060000
[ 0.422612] pci 0000:00:18.2: [1022:1602] type 00 class 0x060000
[ 0.422774] pci 0000:00:18.3: [1022:1603] type 00 class 0x060000
[ 0.422935] pci 0000:00:18.4: [1022:1604] type 00 class 0x060000
[ 0.423086] pci 0000:00:18.5: [1022:1605] type 00 class 0x060000
[ 0.423428] pci 0000:01:00.0: [10de:1b81] type 00 class 0x030000
[ 0.423444] pci 0000:01:00.0: reg 0x10: [mem 0xfd000000-0xfdffffff]
[ 0.423457] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.423469] pci 0000:01:00.0: reg 0x1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
[ 0.423477] pci 0000:01:00.0: reg 0x24: [io 0xe000-0xe07f]
[ 0.423486] pci 0000:01:00.0: reg 0x30: [mem 0xfe000000-0xfe07ffff pref]
[ 0.423493] pci 0000:01:00.0: enabling Extended Tags
[ 0.423511] pci 0000:01:00.0: BAR 3: assigned to efifb
[ 0.423517] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.423607] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:02.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.423663] pci 0000:01:00.1: [10de:10f0] type 00 class 0x040300
[ 0.423677] pci 0000:01:00.1: reg 0x10: [mem 0xfe080000-0xfe083fff]
[ 0.423713] pci 0000:01:00.1: enabling Extended Tags
[ 0.423846] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 0.423851] pci 0000:00:02.0: bridge window [io 0xe000-0xefff]
[ 0.423854] pci 0000:00:02.0: bridge window [mem 0xfd000000-0xfe0fffff]
[ 0.423857] pci 0000:00:02.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.424086] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.424105] pci 0000:02:00.0: reg 0x10: [io 0xd000-0xd0ff]
[ 0.424127] pci 0000:02:00.0: reg 0x18: [mem 0xd2104000-0xd2104fff 64bit pref]
[ 0.424141] pci 0000:02:00.0: reg 0x20: [mem 0xd2100000-0xd2103fff 64bit pref]
[ 0.424219] pci 0000:02:00.0: supports D1 D2
[ 0.424221] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.424320] pci 0000:00:04.0: PCI bridge to [bus 02]
[ 0.424324] pci 0000:00:04.0: bridge window [io 0xd000-0xdfff]
[ 0.424329] pci 0000:00:04.0: bridge window [mem 0xd2100000-0xd21fffff 64bit pref]
[ 0.424381] pci 0000:03:00.0: [1b21:1142] type 00 class 0x0c0330
[ 0.424405] pci 0000:03:00.0: reg 0x10: [mem 0xfe200000-0xfe207fff 64bit]
[ 0.424516] pci 0000:03:00.0: PME# supported from D3cold
[ 0.424602] pci 0000:00:05.0: PCI bridge to [bus 03]
[ 0.424607] pci 0000:00:05.0: bridge window [mem 0xfe200000-0xfe2fffff]
[ 0.424657] pci 0000:04:00.0: [1b21:1142] type 00 class 0x0c0330
[ 0.424682] pci 0000:04:00.0: reg 0x10: [mem 0xfe100000-0xfe107fff 64bit]
[ 0.424790] pci 0000:04:00.0: PME# supported from D3cold
[ 0.424881] pci 0000:00:07.0: PCI bridge to [bus 04]
[ 0.424886] pci 0000:00:07.0: bridge window [mem 0xfe100000-0xfe1fffff]
[ 0.424898] pci_bus 0000:05: extended config space not accessible
[ 0.424930] pci 0000:05:05.0: [13f6:8788] type 00 class 0x040100
[ 0.424949] pci 0000:05:05.0: reg 0x10: [io 0xc000-0xc0ff]
[ 0.425054] pci 0000:05:05.0: supports D1 D2
[ 0.425125] pci 0000:00:14.4: PCI bridge to [bus 05] (subtractive decode)
[ 0.425129] pci 0000:00:14.4: bridge window [io 0xc000-0xcfff]
[ 0.425134] pci 0000:00:14.4: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.425136] pci 0000:00:14.4: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.425138] pci 0000:00:14.4: bridge window [mem 0x000a0000-0x000dffff window] (subtractive decode)
[ 0.425139] pci 0000:00:14.4: bridge window [mem 0xc0000000-0xffffffff window] (subtractive decode)
[ 0.425648] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.425745] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.425846] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.425946] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.426028] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.426092] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.426155] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.426218] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.426402] ACPI: EC: interrupt unblocked
[ 0.426404] ACPI: EC: event unblocked
[ 0.426407] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.426409] ACPI: EC: GPE=0xa
[ 0.426410] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC initialization complete
[ 0.426412] ACPI: \_SB_.PCI0.SBRG.EC0_: EC: Used to handle transactions and events
[ 0.426484] iommu: Default domain type: Translated
[ 0.426484] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.426484] SCSI subsystem initialized
[ 0.426484] libata version 3.00 loaded.
[ 0.426484] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.426484] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.426484] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.426484] vgaarb: loaded
[ 0.426484] ACPI: bus type USB registered
[ 0.426484] usbcore: registered new interface driver usbfs
[ 0.426484] usbcore: registered new interface driver hub
[ 0.426484] usbcore: registered new device driver usb
[ 0.426484] pps_core: LinuxPPS API ver. 1 registered
[ 0.426484] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.426484] PTP clock support registered
[ 0.426484] EDAC MC: Ver: 3.0.0
[ 0.426484] Registered efivars operations
[ 0.426484] NetLabel: Initializing
[ 0.426484] NetLabel: domain hash size = 128
[ 0.426484] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.426484] NetLabel: unlabeled traffic allowed by default
[ 0.426484] PCI: Using ACPI for IRQ routing
[ 0.435367] PCI: pci_cache_line_size set to 64 bytes
[ 0.435423] e820: reserve RAM buffer [mem 0xba6b6000-0xbbffffff]
[ 0.435425] e820: reserve RAM buffer [mem 0xbca35000-0xbfffffff]
[ 0.435426] e820: reserve RAM buffer [mem 0xbd083000-0xbfffffff]
[ 0.435428] e820: reserve RAM buffer [mem 0xbd800000-0xbfffffff]
[ 0.435433] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.435433] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.437535] clocksource: Switched to clocksource tsc-early
[ 0.451793] VFS: Disk quotas dquot_6.6.0
[ 0.451813] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.451962] AppArmor: AppArmor Filesystem Enabled
[ 0.451999] pnp: PnP ACPI init
[ 0.452165] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.452546] system 00:01: [io 0x040b] has been reserved
[ 0.452549] system 00:01: [io 0x04d6] has been reserved
[ 0.452551] system 00:01: [io 0x0c00-0x0c01] has been reserved
[ 0.452552] system 00:01: [io 0x0c14] has been reserved
[ 0.452554] system 00:01: [io 0x0c50-0x0c51] has been reserved
[ 0.452556] system 00:01: [io 0x0c52] has been reserved
[ 0.452557] system 00:01: [io 0x0c6c] has been reserved
[ 0.452559] system 00:01: [io 0x0c6f] has been reserved
[ 0.452560] system 00:01: [io 0x0cd0-0x0cd1] has been reserved
[ 0.452562] system 00:01: [io 0x0cd2-0x0cd3] has been reserved
[ 0.452563] system 00:01: [io 0x0cd4-0x0cd5] has been reserved
[ 0.452565] system 00:01: [io 0x0cd6-0x0cd7] has been reserved
[ 0.452567] system 00:01: [io 0x0cd8-0x0cdf] has been reserved
[ 0.452568] system 00:01: [io 0x0800-0x089f] has been reserved
[ 0.452570] system 00:01: [io 0x0b20-0x0b3f] has been reserved
[ 0.452572] system 00:01: [io 0x0900-0x090f] has been reserved
[ 0.452573] system 00:01: [io 0x0910-0x091f] has been reserved
[ 0.452575] system 00:01: [io 0xfe00-0xfefe] has been reserved
[ 0.452577] system 00:01: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.452579] system 00:01: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.452581] system 00:01: [mem 0xfed80000-0xfed8ffff] has been reserved
[ 0.452583] system 00:01: [mem 0xfed61000-0xfed70fff] has been reserved
[ 0.452585] system 00:01: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.452587] system 00:01: [mem 0xfed00000-0xfed00fff] could not be reserved
[ 0.452589] system 00:01: [mem 0xff800000-0xffffffff] has been reserved
[ 0.452780] system 00:02: [io 0x0290-0x02af] has been reserved
[ 0.452890] system 00:04: [io 0x04d0-0x04d1] has been reserved
[ 0.453282] system 00:07: [mem 0xfec20000-0xfec200ff] could not be reserved
[ 0.453487] pnp: PnP ACPI: found 8 devices
[ 0.459842] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.459910] NET: Registered PF_INET protocol family
[ 0.460281] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.462902] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.462958] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.463130] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.463405] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.463467] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.463627] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.463711] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.463774] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.463842] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.463848] NET: Registered PF_XDP protocol family
[ 0.463863] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 0.463867] pci 0000:00:02.0: bridge window [io 0xe000-0xefff]
[ 0.463871] pci 0000:00:02.0: bridge window [mem 0xfd000000-0xfe0fffff]
[ 0.463874] pci 0000:00:02.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.463878] pci 0000:00:04.0: PCI bridge to [bus 02]
[ 0.463880] pci 0000:00:04.0: bridge window [io 0xd000-0xdfff]
[ 0.463884] pci 0000:00:04.0: bridge window [mem 0xd2100000-0xd21fffff 64bit pref]
[ 0.463888] pci 0000:00:05.0: PCI bridge to [bus 03]
[ 0.463890] pci 0000:00:05.0: bridge window [mem 0xfe200000-0xfe2fffff]
[ 0.463895] pci 0000:00:07.0: PCI bridge to [bus 04]
[ 0.463898] pci 0000:00:07.0: bridge window [mem 0xfe100000-0xfe1fffff]
[ 0.463903] pci 0000:00:14.4: PCI bridge to [bus 05]
[ 0.463905] pci 0000:00:14.4: bridge window [io 0xc000-0xcfff]
[ 0.463916] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.463918] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.463920] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000dffff window]
[ 0.463921] pci_bus 0000:00: resource 7 [mem 0xc0000000-0xffffffff window]
[ 0.463923] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.463925] pci_bus 0000:01: resource 1 [mem 0xfd000000-0xfe0fffff]
[ 0.463926] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.463928] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
[ 0.463929] pci_bus 0000:02: resource 2 [mem 0xd2100000-0xd21fffff 64bit pref]
[ 0.463931] pci_bus 0000:03: resource 1 [mem 0xfe200000-0xfe2fffff]
[ 0.463933] pci_bus 0000:04: resource 1 [mem 0xfe100000-0xfe1fffff]
[ 0.463934] pci_bus 0000:05: resource 0 [io 0xc000-0xcfff]
[ 0.463936] pci_bus 0000:05: resource 4 [io 0x0000-0x0cf7 window]
[ 0.463937] pci_bus 0000:05: resource 5 [io 0x0d00-0xffff window]
[ 0.463938] pci_bus 0000:05: resource 6 [mem 0x000a0000-0x000dffff window]
[ 0.463940] pci_bus 0000:05: resource 7 [mem 0xc0000000-0xffffffff window]
[ 0.485470] pci 0000:00:12.0: quirk_usb_early_handoff+0x0/0x160 took 20957 usecs
[ 0.505457] pci 0000:00:13.0: quirk_usb_early_handoff+0x0/0x160 took 19380 usecs
[ 0.525459] pci 0000:00:14.5: quirk_usb_early_handoff+0x0/0x160 took 19391 usecs
[ 0.545468] pci 0000:00:16.0: quirk_usb_early_handoff+0x0/0x160 took 19531 usecs
[ 0.545662] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.545988] PCI: CLS 64 bytes, default 64
[ 0.546075] Trying to unpack rootfs image as initramfs...
[ 0.546404] PCI-DMA: Disabling AGP.
[ 0.546467] PCI-DMA: aperture base @ a4000000 size 65536 KB
[ 0.546469] PCI-DMA: using GART IOMMU.
[ 0.546470] PCI-DMA: Reserving 64MB of IOMMU area in the AGP aperture
[ 0.547177] software IO TLB: tearing down default memory pool
[ 0.548718] LVT offset 0 assigned for vector 0x400
[ 0.548873] perf: AMD IBS detected (0x000000ff)
[ 0.549483] Initialise system trusted keyrings
[ 0.549496] Key type blacklist registered
[ 0.549552] workingset: timestamp_bits=36 max_order=22 bucket_order=0
[ 0.551171] zbud: loaded
[ 0.551544] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.551804] fuse: init (API version 7.34)
[ 0.552045] integrity: Platform Keyring initialized
[ 0.560805] Key type asymmetric registered
[ 0.560807] Asymmetric key parser 'x509' registered
[ 0.560829] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.560878] io scheduler mq-deadline registered
[ 0.561573] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.561717] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.561757] ACPI: button: Power Button [PWRB]
[ 0.561792] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.561816] ACPI: button: Power Button [PWRF]
[ 0.561851] ACPI: \_PR_.P001: Found 2 idle states
[ 0.561934] ACPI: \_PR_.P002: Found 2 idle states
[ 0.562065] ACPI: \_PR_.P003: Found 2 idle states
[ 0.562185] ACPI: \_PR_.P004: Found 2 idle states
[ 0.562297] ACPI: \_PR_.P005: Found 2 idle states
[ 0.562657] ACPI: \_PR_.P006: Found 2 idle states
[ 0.562791] ACPI: \_PR_.P007: Found 2 idle states
[ 0.562906] ACPI: \_PR_.P008: Found 2 idle states
[ 0.563213] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.565185] Linux agpgart interface v0.103
[ 0.567865] loop: module loaded
[ 0.568158] tun: Universal TUN/TAP device driver, 1.6
[ 0.568190] PPP generic driver version 2.4.2
[ 0.568251] VFIO - User Level meta-driver version: 0.3
[ 0.568322] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.568325] ehci-pci: EHCI PCI platform driver
[ 0.568428] QUIRK: Enable AMD PLL fix
[ 0.568462] ehci-pci 0000:00:12.2: EHCI Host Controller
[ 0.568468] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 1
[ 0.568472] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 0.568480] ehci-pci 0000:00:12.2: debug port 1
[ 0.568517] ehci-pci 0000:00:12.2: irq 17, io mem 0xfe305000
[ 0.581368] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
[ 0.581442] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.581445] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.581447] usb usb1: Product: EHCI Host Controller
[ 0.581449] usb usb1: Manufacturer: Linux 5.15.0-60-generic ehci_hcd
[ 0.581450] usb usb1: SerialNumber: 0000:00:12.2
[ 0.581553] hub 1-0:1.0: USB hub found
[ 0.581561] hub 1-0:1.0: 5 ports detected
[ 0.581915] ehci-pci 0000:00:13.2: EHCI Host Controller
[ 0.581921] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 2
[ 0.581925] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 0.581933] ehci-pci 0000:00:13.2: debug port 1
[ 0.581974] ehci-pci 0000:00:13.2: irq 21, io mem 0xfe303000
[ 0.597368] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 0.597435] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.597438] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.597440] usb usb2: Product: EHCI Host Controller
[ 0.597442] usb usb2: Manufacturer: Linux 5.15.0-60-generic ehci_hcd
[ 0.597443] usb usb2: SerialNumber: 0000:00:13.2
[ 0.597559] hub 2-0:1.0: USB hub found
[ 0.597566] hub 2-0:1.0: 5 ports detected
[ 0.597892] ehci-pci 0000:00:16.2: EHCI Host Controller
[ 0.597897] ehci-pci 0000:00:16.2: new USB bus registered, assigned bus number 3
[ 0.597901] ehci-pci 0000:00:16.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 0.597909] ehci-pci 0000:00:16.2: debug port 1
[ 0.597945] ehci-pci 0000:00:16.2: irq 23, io mem 0xfe300000
[ 0.613367] ehci-pci 0000:00:16.2: USB 2.0 started, EHCI 1.00
[ 0.613425] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.613427] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.613429] usb usb3: Product: EHCI Host Controller
[ 0.613431] usb usb3: Manufacturer: Linux 5.15.0-60-generic ehci_hcd
[ 0.613432] usb usb3: SerialNumber: 0000:00:16.2
[ 0.613536] hub 3-0:1.0: USB hub found
[ 0.613544] hub 3-0:1.0: 4 ports detected
[ 0.613715] ehci-platform: EHCI generic platform driver
[ 0.613738] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.613752] ohci-pci: OHCI PCI platform driver
[ 0.613896] ohci-pci 0000:00:12.0: OHCI PCI host controller
[ 0.613902] ohci-pci 0000:00:12.0: new USB bus registered, assigned bus number 4
[ 0.613931] ohci-pci 0000:00:12.0: irq 18, io mem 0xfe306000
[ 0.677408] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 0.677413] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.677419] usb usb4: Product: OHCI PCI host controller
[ 0.677421] usb usb4: Manufacturer: Linux 5.15.0-60-generic ohci_hcd
[ 0.677422] usb usb4: SerialNumber: 0000:00:12.0
[ 0.677547] hub 4-0:1.0: USB hub found
[ 0.677555] hub 4-0:1.0: 5 ports detected
[ 0.677869] ohci-pci 0000:00:13.0: OHCI PCI host controller
[ 0.677875] ohci-pci 0000:00:13.0: new USB bus registered, assigned bus number 5
[ 0.677903] ohci-pci 0000:00:13.0: irq 20, io mem 0xfe304000
[ 0.741408] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 0.741417] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.741419] usb usb5: Product: OHCI PCI host controller
[ 0.741421] usb usb5: Manufacturer: Linux 5.15.0-60-generic ohci_hcd
[ 0.741423] usb usb5: SerialNumber: 0000:00:13.0
[ 0.741549] hub 5-0:1.0: USB hub found
[ 0.741558] hub 5-0:1.0: 5 ports detected
[ 0.741855] ohci-pci 0000:00:14.5: OHCI PCI host controller
[ 0.741861] ohci-pci 0000:00:14.5: new USB bus registered, assigned bus number 6
[ 0.741881] ohci-pci 0000:00:14.5: irq 18, io mem 0xfe302000
[ 0.805402] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 0.805407] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.805408] usb usb6: Product: OHCI PCI host controller
[ 0.805410] usb usb6: Manufacturer: Linux 5.15.0-60-generic ohci_hcd
[ 0.805416] usb usb6: SerialNumber: 0000:00:14.5
[ 0.805527] hub 6-0:1.0: USB hub found
[ 0.805536] hub 6-0:1.0: 2 ports detected
[ 0.805816] ohci-pci 0000:00:16.0: OHCI PCI host controller
[ 0.805824] ohci-pci 0000:00:16.0: new USB bus registered, assigned bus number 7
[ 0.805851] ohci-pci 0000:00:16.0: irq 22, io mem 0xfe301000
[ 0.869405] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 0.869415] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.869417] usb usb7: Product: OHCI PCI host controller
[ 0.869418] usb usb7: Manufacturer: Linux 5.15.0-60-generic ohci_hcd
[ 0.869420] usb usb7: SerialNumber: 0000:00:16.0
[ 0.869536] hub 7-0:1.0: USB hub found
[ 0.869544] hub 7-0:1.0: 4 ports detected
[ 0.869719] ohci-platform: OHCI generic platform driver
[ 0.869736] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.869803] i8042: PNP: No PS/2 controller found.
[ 0.869873] mousedev: PS/2 mouse device common for all mice
[ 0.869992] rtc_cmos 00:03: RTC can wake from S4
[ 0.870204] rtc_cmos 00:03: registered as rtc0
[ 0.870225] rtc_cmos 00:03: setting system clock to 2023-07-07T12:40:25 UTC (1688733625)
[ 0.870245] rtc_cmos 00:03: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.870254] i2c_dev: i2c /dev entries driver
[ 0.870275] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[ 0.870305] device-mapper: uevent: version 1.0.3
[ 0.870366] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.870388] platform eisa.0: Probing EISA bus 0
[ 0.870390] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 0.870393] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 0.870394] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 0.870396] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 0.870397] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 0.870398] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 0.870400] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 0.870401] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 0.870402] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 0.870404] platform eisa.0: EISA: Detected 0 cards
[ 0.870712] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.870741] efifb: probing for efifb
[ 0.870757] efifb: No BGRT, not showing boot graphics
[ 0.870758] efifb: framebuffer at 0xd1000000, using 3072k, total 3072k
[ 0.870759] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 0.870761] efifb: scrolling: redraw
[ 0.870762] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.870802] fbcon: Deferring console take-over
[ 0.870803] fb0: EFI VGA frame buffer device
[ 0.870809] EFI Variables Facility v0.08 2004-May-17
[ 0.882043] drop_monitor: Initializing network drop monitor service
[ 0.882242] NET: Registered PF_INET6 protocol family
[ 1.210169] usb 4-3: new full-speed USB device number 2 using ohci-pci
[ 1.229495] usb 5-1: new full-speed USB device number 2 using ohci-pci
[ 1.426081] usb 5-1: New USB device found, idVendor=0bda, idProduct=8771, bcdDevice= 2.00
[ 1.426086] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.426088] usb 5-1: Product: Bluetooth Radio
[ 1.426090] usb 5-1: Manufacturer: Realtek
[ 1.426091] usb 5-1: SerialNumber: 00E04C239987
[ 1.432210] usb 4-3: New USB device found, idVendor=09da, idProduct=fa04, bcdDevice= 0.1d
[ 1.432215] usb 4-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.432217] usb 4-3: Product: USB Device
[ 1.432219] usb 4-3: Manufacturer: COMPANY
[ 1.557492] tsc: Refined TSC clocksource calibration: 4013.381 MHz
[ 1.557507] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x39d9bcc1e0c, max_idle_ns: 440795244821 ns
[ 1.557556] clocksource: Switched to clocksource tsc
[ 1.668443] Freeing initrd memory: 221164K
[ 1.674884] Segment Routing with IPv6
[ 1.674900] In-situ OAM (IOAM) with IPv6
[ 1.674924] NET: Registered PF_PACKET protocol family
[ 1.674980] Key type dns_resolver registered
[ 1.674982] x86/pm: family 0x15 cpu detected, MSR saving is needed during suspending.
[ 1.675506] microcode: microcode updated early to new patch_level=0x06000852
[ 1.675540] microcode: CPU0: patch_level=0x06000852
[ 1.675546] microcode: CPU1: patch_level=0x06000852
[ 1.675553] microcode: CPU2: patch_level=0x06000852
[ 1.675560] microcode: CPU3: patch_level=0x06000852
[ 1.675566] microcode: CPU4: patch_level=0x06000852
[ 1.675573] microcode: CPU5: patch_level=0x06000852
[ 1.675579] microcode: CPU6: patch_level=0x06000852
[ 1.675586] microcode: CPU7: patch_level=0x06000852
[ 1.675627] microcode: Microcode Update Driver: v2.2.
[ 1.675633] IPI shorthand broadcast: enabled
[ 1.675647] sched_clock: Marking stable (1675418873, 204118)->(1886662553, -211039562)
[ 1.675933] registered taskstats version 1
[ 1.676022] Loading compiled-in X.509 certificates
[ 1.676789] Loaded X.509 cert 'Build time autogenerated kernel key: 2453f7d92edfc2f639f43e9f3b2f2940ca2143ea'
[ 1.677463] Loaded X.509 cert 'Canonical Ltd. Live Patch Signing: 14df34d1a87cf37625abec039ef2bf521249b969'
[ 1.678186] Loaded X.509 cert 'Canonical Ltd. Kernel Module Signing: 88f752e560a1e0737e31163a466ad7b70a850c19'
[ 1.678188] blacklist: Loading compiled-in revocation X.509 certificates
[ 1.678210] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing: 61482aa2830d0ab2ad5af10b7250da9033ddcef0'
[ 1.678229] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2017): 242ade75ac4a15e50d50c84b0d45ff3eae707a03'
[ 1.678250] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (ESM 2018): 365188c1d374d6b07c3c8f240f8ef722433d6a8b'
[ 1.678268] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2019): c0746fd6c5da3ae827864651ad66ae47fe24b3e8'
[ 1.678286] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v1): a8d54bbb3825cfb94fa13c9f8a594a195c107b8d'
[ 1.678304] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v2): 4cf046892d6fd3c9a5b03f98d845f90851dc6a8c'
[ 1.678322] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v3): 100437bb6de6e469b581e61cd66bce3ef4ed53af'
[ 1.678340] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (Ubuntu Core 2019): c1d57b8f6b743f23ee41f4f7ee292f06eecadfb9'
[ 1.678712] zswap: loaded using pool lzo/zbud
[ 1.679009] Key type .fscrypt registered
[ 1.679012] Key type fscrypt-provisioning registered
[ 1.682218] Key type encrypted registered
[ 1.682221] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.682511] integrity: Loading X.509 certificate: UEFI:db
[ 1.682820] integrity: Loaded X.509 cert 'ASUSTeK MotherBoard SW Key Certificate: da83b990422ebc8c441f8d8b039a65a2'
[ 1.682822] integrity: Loading X.509 certificate: UEFI:db
[ 1.683036] integrity: Loaded X.509 cert 'ASUSTeK Notebook SW Key Certificate: b8e581e4df77a5bb4282d5ccfc00c071'
[ 1.683038] integrity: Loading X.509 certificate: UEFI:db
[ 1.683065] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[ 1.683066] integrity: Loading X.509 certificate: UEFI:db
[ 1.683094] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[ 1.683095] integrity: Loading X.509 certificate: UEFI:db
[ 1.683309] integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
[ 1.684100] ima: No TPM chip found, activating TPM-bypass!
[ 1.684107] Loading compiled-in module X.509 certificates
[ 1.684776] Loaded X.509 cert 'Build time autogenerated kernel key: 2453f7d92edfc2f639f43e9f3b2f2940ca2143ea'
[ 1.684778] ima: Allocated hash algorithm: sha1
[ 1.684784] ima: No architecture policies found
[ 1.684793] evm: Initialising EVM extended attributes:
[ 1.684794] evm: security.selinux
[ 1.684795] evm: security.SMACK64
[ 1.684796] evm: security.SMACK64EXEC
[ 1.684797] evm: security.SMACK64TRANSMUTE
[ 1.684798] evm: security.SMACK64MMAP
[ 1.684799] evm: security.apparmor
[ 1.684799] evm: security.ima
[ 1.684800] evm: security.capability
[ 1.684801] evm: HMAC attrs: 0x1
[ 1.685078] PM: Magic number: 15:934:682
[ 1.685414] acpi_cpufreq: overriding BIOS provided _PSD data
[ 1.685929] RAS: Correctable Errors collector initialized.
[ 1.687728] Freeing unused decrypted memory: 2036K
[ 1.688533] Freeing unused kernel image (initmem) memory: 3240K
[ 1.713554] Write protecting the kernel read-only data: 30720k
[ 1.714892] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 1.715672] Freeing unused kernel image (rodata/data gap) memory: 1468K
[ 1.807282] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.807287] Run /init as init process
[ 1.807288] with arguments:
[ 1.807289] /init
[ 1.807290] splash
[ 1.807291] with environment:
[ 1.807292] HOME=/
[ 1.807293] TERM=linux
[ 1.807294] BOOT_IMAGE=/boot/vmlinuz-5.15.0-60-generic
[ 1.945221] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 1.945322] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 8
[ 1.954313] cryptd: max_cpu_qlen set to 1000
[ 1.959898] AVX version of gcm_enc/dec engaged.
[ 1.959937] AES CTR mode by8 optimization enabled
[ 1.996089] asus_wmi: ASUS WMI generic driver loaded
[ 2.006673] xhci_hcd 0000:03:00.0: hcc params 0x0200e080 hci version 0x100 quirks 0x0000000010800410
[ 2.006983] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 2.006987] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 9
[ 2.006992] xhci_hcd 0000:03:00.0: Host supports USB 3.0 SuperSpeed
[ 2.007055] usb usb8: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.007058] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.007060] usb usb8: Product: xHCI Host Controller
[ 2.007061] usb usb8: Manufacturer: Linux 5.15.0-60-generic xhci-hcd
[ 2.007062] usb usb8: SerialNumber: 0000:03:00.0
[ 2.007103] ahci 0000:00:11.0: version 3.0
[ 2.007269] ahci 0000:00:11.0: AHCI 0001.0200 32 slots 4 ports 6 Gbps 0xf impl SATA mode
[ 2.007272] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part
[ 2.007907] scsi host0: ahci
[ 2.008065] hub 8-0:1.0: USB hub found
[ 2.008076] hub 8-0:1.0: 2 ports detected
[ 2.008098] scsi host1: ahci
[ 2.008237] scsi host2: ahci
[ 2.008376] scsi host3: ahci
[ 2.008431] ata1: SATA max UDMA/133 abar m1024@0xfe307000 port 0xfe307100 irq 19
[ 2.008434] ata2: SATA max UDMA/133 abar m1024@0xfe307000 port 0xfe307180 irq 19
[ 2.008436] ata3: SATA max UDMA/133 abar m1024@0xfe307000 port 0xfe307200 irq 19
[ 2.008438] ata4: SATA max UDMA/133 abar m1024@0xfe307000 port 0xfe307280 irq 19
[ 2.008494] usb usb9: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.008531] usb usb9: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 2.008534] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.008536] usb usb9: Product: xHCI Host Controller
[ 2.008538] usb usb9: Manufacturer: Linux 5.15.0-60-generic xhci-hcd
[ 2.008539] usb usb9: SerialNumber: 0000:03:00.0
[ 2.008594] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 2.008602] piix4_smbus 0000:00:14.0: Using register 0x2c for SMBus port selection
[ 2.008876] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 2.009246] hub 9-0:1.0: USB hub found
[ 2.009286] hub 9-0:1.0: 2 ports detected
[ 2.009499] xhci_hcd 0000:04:00.0: xHCI Host Controller
[ 2.009510] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 10
[ 2.069955] xhci_hcd 0000:04:00.0: hcc params 0x0200e080 hci version 0x100 quirks 0x0000000010800410
[ 2.070327] r8169 0000:02:00.0 eth0: RTL8168f/8111f, 2c:4d:54:4e:25:7f, XID 480, IRQ 40
[ 2.070330] r8169 0000:02:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 2.070504] xhci_hcd 0000:04:00.0: xHCI Host Controller
[ 2.070508] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 11
[ 2.070510] xhci_hcd 0000:04:00.0: Host supports USB 3.0 SuperSpeed
[ 2.070565] usb usb10: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.070567] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.070569] usb usb10: Product: xHCI Host Controller
[ 2.070570] usb usb10: Manufacturer: Linux 5.15.0-60-generic xhci-hcd
[ 2.070572] usb usb10: SerialNumber: 0000:04:00.0
[ 2.070679] hub 10-0:1.0: USB hub found
[ 2.070687] hub 10-0:1.0: 2 ports detected
[ 2.070787] usb usb11: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.070811] usb usb11: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 2.070814] usb usb11: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.070815] usb usb11: Product: xHCI Host Controller
[ 2.070817] usb usb11: Manufacturer: Linux 5.15.0-60-generic xhci-hcd
[ 2.070818] usb usb11: SerialNumber: 0000:04:00.0
[ 2.070917] hub 11-0:1.0: USB hub found
[ 2.070925] hub 11-0:1.0: 2 ports detected
[ 2.089491] usb 4-4: new full-speed USB device number 3 using ohci-pci
[ 2.284210] usb 4-4: New USB device found, idVendor=09da, idProduct=fc7c, bcdDevice= 0.17
[ 2.284215] usb 4-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.284217] usb 4-4: Product: USB Device
[ 2.284219] usb 4-4: Manufacturer: COMPANY
[ 2.291847] hid: raw HID events driver (C) Jiri Kosina
[ 2.485522] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.485545] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.485567] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.485585] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.485641] ata1.00: ATA-11: Netac SSD 1TB, H220916a, max UDMA/133
[ 2.485671] ata1.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 2.485837] ata1.00: configured for UDMA/133
[ 2.485998] scsi 0:0:0:0: Direct-Access ATA Netac SSD 1TB 916a PQ: 0 ANSI: 5
[ 2.486098] ata2.00: ATA-9: OCZ-VERTEX4, 1.5, max UDMA/133
[ 2.486116] ata2.00: 250069680 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 2.486267] ata4.00: ATA-8: TOSHIBA DT01ACA050, MS1OA750, max UDMA/133
[ 2.486304] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.486418] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 2.486439] sd 0:0:0:0: [sda] Write Protect is off
[ 2.486442] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.486471] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.486534] ata4.00: ATA Identify Device Log not supported
[ 2.486536] ata4.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 2.486670] ata2.00: configured for UDMA/133
[ 2.487142] ata3.00: supports DRM functions and may not be fully accessible
[ 2.487144] ata3.00: ATA-9: Samsung SSD 850 EVO 500GB, EMT02B6Q, max UDMA/133
[ 2.487626] ata4.00: ATA Identify Device Log not supported
[ 2.487630] ata4.00: configured for UDMA/133
[ 2.487636] ata3.00: disabling queued TRIM support
[ 2.487638] ata3.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 2.489663] ata3.00: Features: Trust Dev-Sleep NCQ-sndrcv
[ 2.489981] ata3.00: supports DRM functions and may not be fully accessible
[ 2.490524] ata3.00: disabling queued TRIM support
[ 2.492503] ata3.00: configured for UDMA/133
[ 2.496841] scsi 1:0:0:0: Direct-Access ATA OCZ-VERTEX4 1.5 PQ: 0 ANSI: 5
[ 2.497044] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 2.497161] sd 1:0:0:0: [sdb] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[ 2.497177] sd 1:0:0:0: [sdb] Write Protect is off
[ 2.497180] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.497208] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.497220] scsi 2:0:0:0: Direct-Access ATA Samsung SSD 850 2B6Q PQ: 0 ANSI: 5
[ 2.497521] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 2.497657] sd 2:0:0:0: [sdc] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 2.497675] sd 2:0:0:0: [sdc] Write Protect is off
[ 2.497678] scsi 3:0:0:0: Direct-Access ATA TOSHIBA DT01ACA0 A750 PQ: 0 ANSI: 5
[ 2.497679] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 2.497707] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.498043] sd 3:0:0:0: Attached scsi generic sg3 type 0
[ 2.498105] sd 3:0:0:0: [sdd] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 2.498109] sd 3:0:0:0: [sdd] 4096-byte physical blocks
[ 2.498122] sd 3:0:0:0: [sdd] Write Protect is off
[ 2.498125] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[ 2.498153] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.593478] nvidia: loading out-of-tree module taints kernel.
[ 2.593492] nvidia: module license 'NVIDIA' taints kernel.
[ 2.593494] Disabling lock debugging due to kernel taint
[ 2.645595] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 2.647282] sdc: sdc2
[ 2.650521] sda: sda1 sda2 sda3 sda4
[ 2.650610] sdb: sdb1 sdb2 sdb3 sdb4
[ 2.663000] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 2.664525] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 2.664531] fbcon: Taking over console
[ 2.666307] usbcore: registered new interface driver usbhid
[ 2.666309] usbhid: USB HID core driver
[ 2.703100] sdd: sdd1
[ 2.780326] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 525.78.01 Mon Dec 26 05:58:42 UTC 2022
[ 2.780347] Console: switching to colour frame buffer device 128x48
[ 2.785647] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.793590] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 2.795380] sd 2:0:0:0: [sdc] supports TCG Opal
[ 2.795383] sd 2:0:0:0: [sdc] Attached SCSI disk
[ 2.801604] sd 3:0:0:0: [sdd] Attached SCSI disk
[ 2.814744] input: COMPANY USB Device as /devices/pci0000:00/0000:00:12.0/usb4/4-3/4-3:1.0/0003:09DA:FA04.0001/input/input2
[ 2.816798] r8169 0000:02:00.0 enp2s0: renamed from eth0
[ 2.830530] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 525.78.01 Mon Dec 26 05:38:56 UTC 2022
[ 2.833181] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 2.873583] hid-generic 0003:09DA:FA04.0001: input,hidraw0: USB HID v1.11 Keyboard [COMPANY USB Device ] on usb-0000:00:12.0-3/input0
[ 2.873737] input: COMPANY USB Device as /devices/pci0000:00/0000:00:12.0/usb4/4-3/4-3:1.1/0003:09DA:FA04.0002/input/input3
[ 2.873854] hid-generic 0003:09DA:FA04.0002: input,hidraw1: USB HID v1.11 Mouse [COMPANY USB Device ] on usb-0000:00:12.0-3/input1
[ 2.874137] input: COMPANY USB Device Keyboard as /devices/pci0000:00/0000:00:12.0/usb4/4-3/4-3:1.2/0003:09DA:FA04.0003/input/input4
[ 2.937589] input: COMPANY USB Device as /devices/pci0000:00/0000:00:12.0/usb4/4-3/4-3:1.2/0003:09DA:FA04.0003/input/input5
[ 2.937692] hid-generic 0003:09DA:FA04.0003: input,hiddev0,hidraw2: USB HID v1.11 Keyboard [COMPANY USB Device ] on usb-0000:00:12.0-3/input2
[ 2.937838] input: COMPANY USB Device as /devices/pci0000:00/0000:00:12.0/usb4/4-4/4-4:1.0/0003:09DA:FC7C.0004/input/input6
[ 2.937935] hid-generic 0003:09DA:FC7C.0004: input,hidraw3: USB HID v1.11 Mouse [COMPANY USB Device ] on usb-0000:00:12.0-4/input0
[ 2.938056] hid-generic 0003:09DA:FC7C.0005: hiddev1,hidraw4: USB HID v1.11 Device [COMPANY USB Device ] on usb-0000:00:12.0-4/input1
[ 3.793197] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 4.216651] random: lvm: uninitialized urandom read (4 bytes read)
[ 4.304528] random: lvm: uninitialized urandom read (4 bytes read)
[ 4.473483] raid6: sse2x4 gen() 9561 MB/s
[ 4.541484] raid6: sse2x4 xor() 3923 MB/s
[ 4.609483] raid6: sse2x2 gen() 8502 MB/s
[ 4.677481] raid6: sse2x2 xor() 6930 MB/s
[ 4.745482] raid6: sse2x1 gen() 6522 MB/s
[ 4.813482] raid6: sse2x1 xor() 5044 MB/s
[ 4.813484] raid6: using algorithm sse2x4 gen() 9561 MB/s
[ 4.813485] raid6: .... xor() 3923 MB/s, rmw enabled
[ 4.813486] raid6: using ssse3x2 recovery algorithm
[ 4.819915] xor: automatically using best checksumming function avx
[ 4.855604] Btrfs loaded, crc32c=crc32c-intel, zoned=yes, fsverity=yes
[ 36.605188] EXT4-fs (sdc2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 36.787228] systemd[1]: Inserted module 'autofs4'
[ 36.839692] systemd[1]: systemd 249.11-0ubuntu3.6 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 36.857564] systemd[1]: Detected architecture x86-64.
[ 36.980043] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 37.055482] systemd[1]: /lib/systemd/system/clamav-freshclam.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 37.057814] systemd[1]: /etc/systemd/system/anydesk.service:9: PIDFile= references a path below legacy directory /var/run/, updating /var/run/anydesk.pid → /run/anydesk.pid; please update the unit file accordingly.
[ 37.094945] systemd[1]: Queued start job for default target Graphical Interface.
[ 37.095194] random: systemd: uninitialized urandom read (16 bytes read)
[ 37.096136] systemd[1]: Created slice Slice /system/modprobe.
[ 37.096192] random: systemd: uninitialized urandom read (16 bytes read)
[ 37.096565] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 37.096884] systemd[1]: Created slice User and Session Slice.
[ 37.096958] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 37.097141] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 37.097236] systemd[1]: Reached target Remote File Systems.
[ 37.097256] systemd[1]: Reached target Slice Units.
[ 37.097296] systemd[1]: Reached target Local Verity Protected Volumes.
[ 37.097389] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 37.097513] systemd[1]: Listening on LVM2 poll daemon socket.
[ 37.097625] systemd[1]: Listening on Syslog Socket.
[ 37.098845] systemd[1]: Listening on Process Core Dump Socket.
[ 37.098934] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 37.098987] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 37.099167] systemd[1]: Listening on Journal Audit Socket.
[ 37.099265] systemd[1]: Listening on Journal Socket (/dev/log).
[ 37.099381] systemd[1]: Listening on Journal Socket.
[ 37.099969] systemd[1]: Listening on udev Control Socket.
[ 37.100067] systemd[1]: Listening on udev Kernel Socket.
[ 37.100983] systemd[1]: Mounting Huge Pages File System...
[ 37.101822] systemd[1]: Mounting POSIX Message Queue File System...
[ 37.102820] systemd[1]: Mounting Kernel Debug File System...
[ 37.103762] systemd[1]: Mounting Kernel Trace File System...
[ 37.105441] systemd[1]: Starting Journal Service...
[ 37.105688] systemd[1]: Finished Availability of block devices.
[ 37.107517] systemd[1]: Starting Set the console keyboard layout...
[ 37.108557] systemd[1]: Starting Create List of Static Device Nodes...
[ 37.109622] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 37.110789] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 37.112038] systemd[1]: Starting Load Kernel Module configfs...
[ 37.113354] systemd[1]: Starting Load Kernel Module drm...
[ 37.114603] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 37.116269] systemd[1]: Starting Load Kernel Module fuse...
[ 37.117528] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 37.118859] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 37.120210] systemd[1]: Starting Load Kernel Module ramoops...
[ 37.120420] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 37.122577] systemd[1]: Starting Load Kernel Modules...
[ 37.123941] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 37.125566] systemd[1]: Starting Coldplug All udev Devices...
[ 37.128283] systemd[1]: Mounted Huge Pages File System.
[ 37.128418] systemd[1]: Mounted POSIX Message Queue File System.
[ 37.128515] systemd[1]: Mounted Kernel Debug File System.
[ 37.128642] systemd[1]: Mounted Kernel Trace File System.
[ 37.129182] systemd[1]: Finished Create List of Static Device Nodes.
[ 37.129712] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 37.129953] systemd[1]: Finished Load Kernel Module configfs.
[ 37.130317] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 37.130748] systemd[1]: Finished Load Kernel Module drm.
[ 37.131031] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 37.131269] systemd[1]: Finished Load Kernel Module fuse.
[ 37.131548] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
[ 37.131846] systemd[1]: Finished Load Kernel Module pstore_blk.
[ 37.132167] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
[ 37.132455] EXT4-fs (sdc2): re-mounted. Opts: errors=remount-ro. Quota mode: none.
[ 37.132623] systemd[1]: Finished Load Kernel Module pstore_zone.
[ 37.134512] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
[ 37.134854] systemd[1]: Finished Load Kernel Module ramoops.
[ 37.135489] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 37.136785] systemd[1]: Mounting FUSE Control File System...
[ 37.136914] pstore: Using crash dump compression: deflate
[ 37.136927] pstore: Registered efi as persistent store backend
[ 37.137957] systemd[1]: Mounting Kernel Configuration File System...
[ 37.138750] lp: driver loaded but no devices found
[ 37.139334] systemd[1]: Starting Load/Save Random Seed...
[ 37.140639] systemd[1]: Starting Create System Users...
[ 37.142516] ppdev: user-space parallel port driver
[ 37.143498] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 37.143791] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 37.143942] systemd[1]: Mounted FUSE Control File System.
[ 37.144162] systemd[1]: Mounted Kernel Configuration File System.
[ 37.149885] systemd[1]: Finished Load Kernel Modules.
[ 37.151243] systemd[1]: Starting Apply Kernel Variables...
[ 37.154127] systemd[1]: Finished Create System Users.
[ 37.155365] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 37.166444] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 37.168379] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 37.186332] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
[ 37.186705] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[ 37.187334] systemd[1]: Finished Apply Kernel Variables.
[ 37.187878] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 37.188039] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 37.195242] systemd[1]: Finished Set the console keyboard layout.
[ 37.195390] systemd[1]: Reached target Preparation for Local File Systems.
[ 37.206423] systemd[1]: Started Journal Service.
[ 37.211927] systemd-journald[486]: Received client request to flush runtime journal.
[ 37.367977] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 37.389759] nvidia-uvm: Loaded the UVM driver, major device number 509.
[ 37.641474] random: crng init done
[ 37.641478] random: 107 urandom warning(s) missed due to ratelimiting
[ 37.730259] asus_wmi: Initialization: 0x0
[ 37.730318] asus_wmi: BIOS WMI version: 0.9
[ 37.730723] asus_wmi: SFUN value: 0x0
[ 37.730728] eeepc-wmi eeepc-wmi: Detected ASUSWMI, use DCTS
[ 37.732455] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input7
[ 37.769560] Bluetooth: Core ver 2.22
[ 37.769984] NET: Registered PF_BLUETOOTH protocol family
[ 37.769986] Bluetooth: HCI device and connection manager initialized
[ 37.769995] Bluetooth: HCI socket layer initialized
[ 37.769999] Bluetooth: L2CAP socket layer initialized
[ 37.770007] Bluetooth: SCO socket layer initialized
[ 37.781775] Adding 9227464k swap on /dev/sda3. Priority:-2 extents:1 across:9227464k SSFS
[ 37.784250] kvm: Nested Virtualization enabled
[ 37.784253] SVM: kvm: Nested Paging enabled
[ 37.810716] snd_virtuoso 0000:05:05.0: enabling device (0000 -> 0001)
[ 37.812410] MCE: In-kernel MCE decoding enabled.
[ 37.858410] usbcore: registered new interface driver btusb
[ 37.860138] Bluetooth: hci0: RTL: examining hci_ver=0a hci_rev=000b lmp_ver=0a lmp_subver=8761
[ 37.862147] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 37.862150] Bluetooth: hci0: RTL: loading rtl_bt/rtl8761bu_fw.bin
[ 37.864282] Bluetooth: hci0: RTL: loading rtl_bt/rtl8761bu_config.bin
[ 37.864434] Bluetooth: hci0: RTL: cfg_sz 6, total sz 27814
[ 37.946889] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 37.984706] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 37.984993] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 37.985004] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 38.033610] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input8
[ 38.033719] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input9
[ 38.033836] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input10
[ 38.033918] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input11
[ 38.034012] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input12
[ 38.034067] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input13
[ 38.034126] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input14
[ 38.116117] Bluetooth: hci0: RTL: fw version 0x09a98a6b
[ 38.294597] EXT4-fs (sdd1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 40.000842] ZFS: Loaded module v2.1.4-0ubuntu0.1, ZFS pool version 5000, ZFS filesystem version 5
[ 40.047577] audit: type=1400 audit(1688733664.671:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1034 comm="apparmor_parser"
[ 40.047604] audit: type=1400 audit(1688733664.671:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1034 comm="apparmor_parser"
[ 40.047609] audit: type=1400 audit(1688733664.671:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1037 comm="apparmor_parser"
[ 40.047613] audit: type=1400 audit(1688733664.671:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1037 comm="apparmor_parser"
[ 40.047617] audit: type=1400 audit(1688733664.671:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1037 comm="apparmor_parser"
[ 40.047622] audit: type=1400 audit(1688733664.671:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/freshclam" pid=1036 comm="apparmor_parser"
[ 40.047672] audit: type=1400 audit(1688733664.671:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/redshift" pid=1038 comm="apparmor_parser"
[ 40.050240] audit: type=1400 audit(1688733664.675:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oosplash" pid=1047 comm="apparmor_parser"
[ 40.051695] audit: type=1400 audit(1688733664.675:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=1050 comm="apparmor_parser"
[ 40.051990] audit: type=1400 audit(1688733664.675:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="tcpdump" pid=1040 comm="apparmor_parser"
[ 40.257820] Process accounting resumed
[ 40.377816] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 40.377819] Bluetooth: BNEP filters: protocol multicast
[ 40.377823] Bluetooth: BNEP socket layer initialized
[ 40.390205] NET: Registered PF_ALG protocol family
[ 40.404974] process '/usr/bin/anydesk' started with executable stack
[ 40.606050] RTL8211E Gigabit Ethernet r8169-0-200:00: attached PHY driver (mii_bus:phy_addr=r8169-0-200:00, irq=MAC)
[ 40.842154] vboxdrv: Found 8 processor cores
[ 40.855265] r8169 0000:02:00.0 enp2s0: Link is Down
[ 40.861682] vboxdrv: TSC mode is Invariant, tentative frequency 4013381126 Hz
[ 40.861685] vboxdrv: Successfully loaded version 6.1.38 r153438 (interface 0x00320000)
[ 41.121618] VBoxNetFlt: Successfully started.
[ 41.160882] VBoxNetAdp: Successfully started.
[ 42.398789] r8169 0000:02:00.0 enp2s0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 42.398803] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[ 43.269186] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[ 43.319365] Bluetooth: RFCOMM TTY layer initialized
[ 43.319374] Bluetooth: RFCOMM socket layer initialized
[ 43.319381] Bluetooth: RFCOMM ver 1.11
[ 52.654269] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[ 1282.825428] kauditd_printk_skb: 21 callbacks suppressed
[ 1282.825431] audit: type=1400 audit(1688734907.852:33): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/haveged" pid=94331 comm="apparmor_parser"
Помогите, пожалуйста, что делать?
Долгая загрузка (причина в Kernel)
07 июл 2023, 19:49
Santyago писал(а):
07 июл 2023, 16:40
sdd1 не хотел грузится, писал ошибка.
Ошибки бывают разные. Хотелось бы подробностей - что именно за ошибка. Полный текст.
Santyago писал(а):
07 июл 2023, 16:40
Поэтому поставил в fstab проверку в 0
Хотелось бы уточнить - проверку чего? Если шестое поле (pass) в 0, то это не проверка, а разрешение пропускать отсутствующий носитель. Единица должна быть только у root раздела, остальные - 2 (монтировать после root и сообщать о проблемах) или 0 - можно пропустить монтирование если носитель отсутствует.
Вообще - эти логи хорошо, но все-же вывод inxi -Fxz хотелось бы тоже видеть. Упрощает понимание, что у вас за набор железа, даже если по сути это все можно из приведенных логов вытащить, там оно в одном месте будет.
Santyago
08 июл 2023, 09:32
07 июл 2023, 19:49
Спасибо за помощь! Я разобрался. Диск был отформатирован в manjaro. Там при проверке fsck ошибок не выдавал, писал что всё ОК. А в минте писал что то типа файловая система по прежнему содержит ошибки. При попытке e2fsck -cfpv /dev/sdd1 выдывал ошибку
/dev/sdd1 has unsupported feature(s): FEATURE_C12
Так как диск используется как файло-помойка я просто удалил раздел, создал новый и отформатировал в минте. Все ошибки исчезли.
Спасибо!
08 июл 2023, 10:35
Manjaro - rolling дистрибутив, там практически всегда более новые версии всего. В данном случае, в файловую систему ext4 добавили новую фичу (вообще-то manjaro здесь не при чем, туда просто быстрее это новшество попало). Если ext4 создается с пакетом e2fsck 1.47.0 или новее, она включена по дефолту. В минте этот пакет старее, фичу не понимает. Так что решение правильное.
