Проблемы с загрузкой сайтов
Isemann
Благодарил (а): 2 раза
14 июн 2023, 10:47
LM 21 Vanessa Cinnamon
Kernel: 6.3.7-1-liquorix-amd64 x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: Cinnamon 5.4.12 Distro: Linux Mint 21 Vanessa
base: Ubuntu 22.04 jammy
Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: PRIME H510M-K v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1203
date: 10/27/2021
Info: 6-core model: 11th Gen Intel Core i5-11400F bits: 64 type: MT MCP
arch: Rocket Lake rev: 1 cache: L1: 480 KiB L2: 3 MiB L3: 12 MiB
Speed (MHz): avg: 3184 high: 4400 min/max: 800/4400 cores: 1: 4400
2: 2600 3: 4307 4: 4386 5: 2600 6: 4315 7: 2600 8: 2600 9: 2600 10: 2600
11: 2600 12: 2600 bogomips: 62208
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Gigabyte driver: nvidia
v: 525.105.17 bus-ID: 01:00.0
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia
resolution: 1920x1080~144Hz
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 525.105.17 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Sound Server-1: ALSA v: k6.3.7-1-liquorix-amd64 running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6
Local Storage: total: 1.14 TiB used: 577.26 GiB (49.6%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SWORDFISH size: 232.89 GiB
temp: 38.9 C
ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-00BBHA0
ID-1: / size: 93.31 GiB used: 44.14 GiB (47.3%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 486 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 117.43 GiB used: 31.37 GiB (26.7%) fs: ext4
dev: /dev/nvme0n1p5
Swap:
ID-1: swap-1 type: partition size: 15.26 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p4
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 56%
Processes: 287 Uptime: 16m Memory: 15.46 GiB used: 2.16 GiB (14.0%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2878 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Проблема в том что некоторые сайты как например Youtube, Ap-Pro или даже вход на этот форум занял 5-10 минут.
В то время как LostFilm и Ozon грузятся за считанные секунды.
При загрузке происходит долгое получение данных с желаемого сайта или получение ответа от fonts.googleapis и google.analitycs.
В чем может быть проблема?
14 июн 2023, 10:55
Isemann, На 21 версии сидишь принципиально ? И ядро какое то староватое. Может ещё и не делал обновлений ?
Isemann
14 июн 2023, 11:04
14 июн 2023, 10:55
С этой версией бы справиться. Ядро поставил левое и не могу вернуть старое. Обновления раз в пару дней скачиваю.
14 июн 2023, 11:09
Isemann писал(а):
14 июн 2023, 10:47
Например в том, что не удается загрузить какой-то компонент из популярных, но который грузится со стороннего ресурса. Это может быть какой-то счетчик, рекламный модуль, шрифт и т.д. Что-то опциональное. Но тем не менее - временно блокирующее загрузку остальной части сайта пока длятся попытки его загрузить.
Вообще - возможных причин много. Чаще всего это признак блокировок, или проблем с не обновившимся DNS.у вышестоящих серверов. Такое нужно диагностировать по месту. Но проверять лучше всего начинать с попыток входа на такие сайты с другого устройства/системы подключенный в ту же сеть, и через другой броузер. Вне зависимости от конкретного результата - это диагностическая информация, помогающая сузить количество возможных вариантов.
Isemann
14 июн 2023, 11:15
14 июн 2023, 11:09
Isemann писал(а):
14 июн 2023, 10:47
Попробовал со смартфона через свой роутеровский вайфай все идеально.
Через браузер Chromium так же как и описывал выше.
14 июн 2023, 11:18
Тогда искать причину, скорее всего, нужно в косяках кеширования DNS в самой системе. Но сначала имеет смысл все-же поставить хотя бы firefox, и посмотреть как через него грузится - тоже поможет с диагностикой.
Isemann
14 июн 2023, 11:22
14 июн 2023, 11:18
Firefox мой постоянный браузер.
14 июн 2023, 11:41
Для начала можно открыть консоль на проблемном сайте с вкладкой сеть - и посмотреть какие элементы мешают прогрузиться, возвращают ли 200/30X ответ, потыкать их источник ручными запросами через curl/telnet/traceroute.
Isemann
14 июн 2023, 12:00
14 июн 2023, 11:41
Вот что не подгружается, а дальше не знаю куда тыкать.
14 июн 2023, 12:15
Этих похоже режет твой аддон против рекламы (adblock/ublock/adguard и подобные). С этого и можно начать, пусть googlead и не страшные казалось бы.
Т.к. ошибка с NS_ERROR - предположу что рекламу и прочую непотребность режем все же на уровне ДНС, верно?
14 июн 2023, 14:11
Во второй картинке увидел fonts.googleapis... с ошибкой NS_ERROR_NET... Вероятно, кто-то или что-то воспрепятствовал подгрузке шрифтов от Google. Почему бы для начала не попробовать отключить блокировщик рекламы и посмотреть как будет?
Isemann
14 июн 2023, 16:03
С включеным, отключеным и снесеным Adblock'erom все одинаково.
Чистил кэш DNS Youtube стал грузиться значительно быстрее. А Ap-Pro и этот форум по прежнему долго грузятся.
Так например я захожу на форум.
14 июн 2023, 16:12
Так и хочется спросить про VPN )
Isemann
14 июн 2023, 16:21
14 июн 2023, 16:12
Не задействован.
14 июн 2023, 16:36
nslookup fonts.googleapis.com в терминале норм отвечает?
Isemann
14 июн 2023, 16:41
14 июн 2023, 16:36
Server: 127.0.0.53
Address: 127.0.0.53#53
Non-authoritative answer:
Address: 64.233.165.95
Address: 2a00:1450:4010:c08::5f
14 июн 2023, 16:45
Isemann писал(а):
14 июн 2023, 16:21
Не задействован.
Может попробовать ?
Isemann писал(а):
14 июн 2023, 16:41
Вроде у ТС нормальный ответ.
14 июн 2023, 16:46
Isemann, на картинке выглядит именно так что днс (внешний, или кэширующий резолвер) не хотят вернуть ip этих гуглодоменов, и соотвественно через 90 секунд таймаута css-ка не прогружена
Осталось понять кто виноват)
Локальная это проблема в системе, или над ней у провайдера (т.к. андроид девайсы не показательны в этом плане - их чуть сложней заставить юзать негугловые днс)
Isemann
14 июн 2023, 16:53
Chocobo, Как это выяснить?
ilikethat
Решено: 10
Благодарил (а): 129 раз
14 июн 2023, 18:53
Isemann, а ты не добавлял в настройки сети DNS сервера руками? Например 8.8.8.8?
