microCD
Bums
Благодарил (а): 80 раз
microCD
11 июн 2023, 07:47
Kernel: 5.15.0-73-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
base: Ubuntu 22.04 jammy
Type: Laptop System: Hewlett-Packard product: HP Pavilion 17 Notebook PC
v: 0975110000405F10000610180 serial: <superuser required>
Mobo: Hewlett-Packard model: 2282 v: 77.35 serial: <superuser required>
UEFI: Insyde v: F.57 date: 11/09/2018
ID-1: BAT0 charge: 10.4 Wh (100.0%) condition: 10.4/10.4 Wh (100.0%)
volts: 15.8 min: 14.8 model: Hewlett-Packard Primary status: Full
Info: dual core model: Intel Core i5-4210U bits: 64 type: MT MCP
arch: Haswell rev: 1 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 1722 high: 1769 min/max: 800/2700 cores: 1: 1769
2: 1696 3: 1696 4: 1729 bogomips: 19155
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM108M [GeForce 840M] vendor: Hewlett-Packard
driver: nvidia v: 530.41.03 bus-ID: 0a:00.0
Device-3: Realtek HP Truevision HD laptop camera type: USB
driver: uvcvideo bus-ID: 1-1.3:4
Display: x11 server: X.Org v: 1.21.1.4 driver: X:
loaded: modesetting,nvidia unloaded: fbdev,nouveau,vesa gpu: i915
resolution: 1600x900~60Hz
OpenGL: renderer: NVIDIA GeForce 840M/PCIe/SSE2 v: 4.6.0 NVIDIA 530.41.03
Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Sound Server-1: ALSA v: k5.15.0-73-generic running: yes
Device-1: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
v: kernel bus-ID: 08:00.0
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 09:00.0
Bluetooth:
Device-1: Broadcom BCM43142A0 Bluetooth Device type: USB driver: btusb
v: 0.8 bus-ID: 1-1.7:5
bt-v: 2.1 lmp-v: 4.0
Local Storage: total: 927.45 GiB used: 246.77 GiB (26.6%)
ID-1: /dev/mmcblk0 vendor: SMI (STMicroelectronics) model: N/A
ID-2: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
ID-3: /dev/sdb vendor: HGST (Hitachi) model: HTS545050A7E680
ID-1: / size: 21.78 GiB used: 15.53 GiB (71.3%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 145.7 MiB used: 6 MiB (4.1%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 416.95 GiB used: 231.23 GiB (55.5%) fs: ext4
dev: /dev/sda3
Swap:
ID-1: swap-1 type: file size: 1.03 GiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 43.0 C mobo: N/A gpu: nvidia temp: 38 C
Processes: 239 Uptime: 22m Memory: 7.69 GiB used: 1.58 GiB (20.6%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2340 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Купид микро сд, и не могу с ним ничего с делать, подсажите может драйвер нужно ставить.
В дисках его видно, а в немо нет.
microCD
11 июн 2023, 09:25
Защита от записи не включена случаем?
Давным давно все драйвера на это дело уже идут комплектом, если устройство исправно - ничего больше не нужно, воткнул и работай. Как с флешками.
