Kernel: 5.4.0-150-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
Desktop: Xfce 4.16.0 Distro: Linux Mint 20.2 Uma base: Ubuntu 20.04 focal
Type: Laptop System: Acer product: Extensa 2520G v: V1.15 serial: <filter>
Mobo: Acer model: BA50_SL v: V1.15 serial: <filter> UEFI [Legacy]: Insyde
v: 1.15 date: 05/13/2016
ID-1: BAT1 charge: 27.7 Wh condition: 27.7/37.0 Wh (75%)
model: SANYO AL15A32 status: Full
Topology: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP
arch: Skylake rev: 3 L2 cache: 3072 KiB
bogomips: 19200
Speed: 2300 MHz min/max: 400/2301 MHz Core speeds (MHz): 1: 2300 2: 2300
3: 2300 4: 2300
Device-1: Intel Skylake GT2 [HD Graphics 520]
Device-2: NVIDIA GK208BM [GeForce 920M] vendor: Acer Incorporated ALI
driver: nvidia v: 470.182.03 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.13 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa resolution: 1366x768~60Hz
OpenGL: renderer: NVIDIA GeForce 920M/PCIe/SSE2 v: 4.6.0 NVIDIA 470.182.03
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Acer Incorporated ALI
Sound Server: ALSA v: k5.4.0-150-generic
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus ID: 02:00.0
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel port: 3000 bus ID: 03:00.0
Device-3: Lite-On Qualcomm Atheros Bluetooth type: USB driver: btusb
bus ID: 1-5:9
Local Storage: total: 238.47 GiB used: 99.06 GiB (41.5%)
ID-1: /dev/sda vendor: Samsung model: P3-256 size: 238.47 GiB
ID-1: / size: 233.18 GiB used: 99.06 GiB (42.5%) fs: ext4 dev: /dev/sda5
System Temperatures: cpu: 51.0 C mobo: N/A gpu: nvidia temp: 50 C
Processes: 237 Uptime: 3h 18m Memory: 7.64 GiB used: 5.21 GiB (68.2%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
bogomips: 19200
3: 2300 4: 2300
bus ID: 02:00.0
bus ID: 1-5:9
inxi: 3.0.38
В общем хочу установить одну игру - Valoren. https://veloren.net/download/
Ставлю:
sudo add-apt-repository ppa:frinksy/airshipper
sudo apt-get update
sudo apt install airshipper
Запускаю:
airshipperПолучаю:
MESA-INTEL: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0
[WARN] Shader validation is disabled
[ERROR] X11 error: XError {
description: "BadDrawable (invalid Pixmap or Window parameter)",
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
[ERROR] Airshipper panicked:
Next frame: Timeout: panicked at 'Next frame: Timeout', /build/airshipper-Pi52Jl/airshipper-0.4.2/vendor/iced_wgpu/src/window/compositor.rs:130:52
thread 'main' panicked at 'Next frame: Timeout', /build/airshipper-Pi52Jl/airshipper-0.4.2/vendor/iced_wgpu/src/window/compositor.rs:130:52
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
[ERROR] Heaps not completely freed before drop. Utilization: MemoryHeapUtilization { utilization: MemoryUtilization { used: 85648896, effective: 34122240 }, size: 6153400320 }
[ERROR] Memory leak: SizeEntry(256) is still used
[ERROR] Memory leak: SizeEntry(2048) is still used
[ERROR] Memory leak: SizeEntry(16384) is still used
[ERROR] Memory leak: SizeEntry(131072) is still used
[ERROR] Memory leak: SizeEntry(32768) is still used
[ERROR] Memory leak: SizeEntry(262144) is still used
[ERROR] Memory leak: SizeEntry(65536) is still used
[ERROR] Memory leak: SizeEntry(524288) is still used
[ERROR] Memory leak: SizeEntry(1048576) is still used
[ERROR] Memory leak: SizeEntry(2097152) is still used
[ERROR] Memory leak: SizeEntry(4194304) is still used
[ERROR] Memory leak: SizeEntry(25600) is still used
[ERROR] Memory leak: SizeEntry(204800) is still used
[ERROR] Memory leak: SizeEntry(51200) is still used
[ERROR] Memory leak: SizeEntry(409600) is still used
[ERROR] Memory leak: SizeEntry(102400) is still used
[ERROR] Memory leak: SizeEntry(819200) is still used
[ERROR] Memory leak: SizeEntry(1638400) is still used
[ERROR] Memory leak: SizeEntry(2600192) is still used
[ERROR] Memory leak: SizeEntry(5600000) is still used
[ERROR] Memory leak: SizeEntry(1400000) is still used
[ERROR] Memory leak: SizeEntry(12800) is still used
[ERROR] Memory leak: SizeEntry(240128) is still used
[ERROR] Memory leak: SizeEntry(40192) is still used
[ERROR] Memory leak: SizeEntry(321536) is still used
[ERROR] Memory leak: SizeEntry(80384) is still used
[ERROR] Memory leak: SizeEntry(643072) is still used
[ERROR] Memory leak: SizeEntry(160768) is still used
[ERROR] Memory leak: SizeEntry(1286144) is still used
[ERROR] Memory leak: SizeEntry(36096) is still used
[ERROR] Memory leak: SizeEntry(288768) is still used
[ERROR] Memory leak: SizeEntry(72192) is still used
[ERROR] Memory leak: SizeEntry(577536) is still used
[ERROR] Memory leak: SizeEntry(144384) is still used
[ERROR] Memory leak: SizeEntry(1155072) is still used
[ERROR] Memory leak: SizeEntry(16814080) is still used
[ERROR] Memory leak: SizeEntry(4206592) is still used
[ERROR] Memory leak: SizeEntry(10240) is still used
[ERROR] Memory leak: SizeEntry(749056) is still used
[ERROR] Memory leak: SizeEntry(230656) is still used
[ERROR] Memory leak: SizeEntry(91392) is still used
[ERROR] DescriptorAllocator is dropped
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
error_code: 9,
request_code: 149,
minor_code: 4,
Гуглинг ошибки привел меня к тому, что рекомендуют прописать:
airshipper runНа эту команду я получаю уже другую ошибку:
[INFO] Update found, do you want to update? [Y/n]
Y
[INFO] Updating...
[INFO] Extracting...
[INFO] Unzipping to "/home/leo/.local/share/airshipper/profiles/default"
[ERROR] ArchiveError => invalid Zip archive
[INFO] Press enter to exit...
Там два ответа:
Первый -
Второй -i can replicate the issue with ppa, it works with latest build.
Честно говоря не совсем понимаю что конкретно необходимо сделать.this means you have a too old version of aishipper installed, the current version you should be using is 0.7.0, a way to fix this is by compiling https://gitlab.com/veloren/airshipper
Касательного второго ответа - я сделал git clone , и full-upgrade , но задачу не решило.
Также вычитал на каком-то сайте , что это неполадки с vulkan. Поставил vkcube - выдает чёрный экран.
Вот
vulkaninfo | grep error :Код: Выделить всё
ERROR: [Loader Message] Code 0 : /usr/lib/i386-linux-gnu/libvulkan_radeon.so: wrong ELF class: ELFCLASS32
ERROR: [Loader Message] Code 0 : /usr/lib/i386-linux-gnu/libvulkan_intel.so: wrong ELF class: ELFCLASS32
ERROR: [Loader Message] Code 0 : /usr/lib/i386-linux-gnu/libvulkan_lvp.so: wrong ELF class: ELFCLASS32
WARNING: lavapipe is not a conformant vulkan implementation, testing use only.
WARNING: lavapipe is not a conformant vulkan implementation, testing use only.Вопрос - можно ли это как-то пофиксить?
P.S.
Знаю, что написано
MESA-INTEL: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0Код: Выделить всё
Graphics: Device-1: Intel Skylake GT2 [HD Graphics 520] driver: i915 v: kernel
Device-2: NVIDIA GK208BM [GeForce 920M] driver: nvidia v: 470.182.03
Display: x11 server: X.Org 1.20.13 driver: modesetting,nvidia unloaded: fbdev,nouveau,vesa
OpenGL: renderer: NVIDIA GeForce 920M/PCIe/SSE2 v: 4.6.0 NVIDIA 470.182.03 Код: Выделить всё
1:00.0 3D controller: NVIDIA Corporation GK208BM [GeForce 920M] (rev a1)
Subsystem: Acer Incorporated [ALI] GK208BM [GeForce 920M]
Flags: bus master, fast devsel, latency 0, IRQ 131
Memory at 93000000 (32-bit, non-prefetchable) [size=16M]
Memory at 80000000 (64-bit, prefetchable) [size=256M]
Memory at 90000000 (64-bit, prefetchable) [size=32M]
I/O ports at 4000 [size=128]
Expansion ROM at 94080000 [virtual] [disabled] [size=512K]
Capabilities: <access denied>
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
