Как привязать иконки к рабочему столу.
Пингвин
08 май 2023, 12:15
acer@acer-eME528:~$ inxi -Fxz
Kernel: 5.4.0-148-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
Desktop: Xfce 4.16.0 Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Type: Laptop System: eMachines product: eME528 v: N/A serial: <filter>
Mobo: eMachines model: HM55-MV serial: <filter> BIOS: Phoenix v: 1.3404
date: 07/16/2010
ID-1: BAT1 charge: 39.9 Wh condition: 39.9/47.5 Wh (84%)
model: SANYO AS09C31 status: Full
Topology: Dual Core model: Celeron T3500 bits: 64 type: MCP arch: Penryn
rev: A L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 8379
Speed: 2095 MHz min/max: N/A Core speeds (MHz): 1: 2095 2: 2094
Device-1: Intel Mobile 4 Series Integrated Graphics
Display: x11 server: X.Org 1.20.13 driver: modesetting
unloaded: fbdev,vesa resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express (CTG)
v: 2.1 Mesa 21.2.6 direct render: Yes
Device-1: Intel 82801I HD Audio vendor: Acer Incorporated ALI
Sound Server: ALSA v: k5.4.0-148-generic
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: Foxconn
driver: ath9k v: kernel port: 1c00 bus ID: 07:00.0
IF: wlp7s0 state: up mac: <filter>
Device-2: Qualcomm Atheros AR8131 Gigabit Ethernet
vendor: Acer Incorporated ALI driver: atl1c v: 1.0.1.1-NAPI port: 4000
bus ID: 09:00.0
IF: enp9s0 state: down mac: <filter>
Local Storage: total: 149.05 GiB used: 39.50 GiB (26.5%)
ID-1: /dev/sda vendor: Samsung model: HM160HI size: 149.05 GiB
ID-1: / size: 145.16 GiB used: 39.50 GiB (27.2%) fs: ext4 dev: /dev/sda5
System Temperatures: cpu: 58.0 C mobo: N/A
Processes: 206 Uptime: 2h 47m Memory: 2.85 GiB used: 1.93 GiB (67.8%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
Linux Mint 20.3 Xfce 64-bit.
Acer emachines e528.
Здравствуйте.
Подскажите как привязать значки к определенному рабочему столу. Нужно что бы на разных рабочих столах были свои значки запуска приложений. Как у Астра линукс.
п.с. Я искал но не нашел. Честное пионерское.
08 май 2023, 12:52
Просто кинь на стол.
Пингвин
08 май 2023, 14:17
08 май 2023, 12:52
Кидаю, и она на всех столах видна. А мне надо что бы только на одном.
08 май 2023, 15:03
Пингвин писал(а):
08 май 2023, 14:17
Честно говоря не знаю. Я крыской не пользовался и стол у меня 1. И он совершенно пустой , нет виндовой привычки разбрасывать хлам на столе. Попробуй показать текст этой иконки. Может там что интересное есть.
Пингвин
08 май 2023, 16:17
Какой текст? В свойствах что ли?
Последний раз редактировалось пользователем 1 Dja; всего редактировалось раз: 27
Причина: подправил урл
08 май 2023, 16:36
Пингвин, Скорее второе. И смени хостинг картинок , или вообще лучше не используй. Здесь их можно вставлять прямо в сообщение. Кнопка слева под окном. Добавить файлы.
Пингвин
08 май 2023, 16:38
Что второе?
08 май 2023, 16:50
Пингвин писал(а):
08 май 2023, 16:38
Что второе?
Это самое - изображение.
Пингвин
08 май 2023, 16:54
Так там изменить ничего нельзя.
08 май 2023, 16:56
Пингвин писал(а):
08 май 2023, 16:54
С чего ты взял ? Это текстовый файл.
Пингвин
08 май 2023, 17:54
Пойду астру поставлю, гляну как там это сделано.
08 май 2023, 18:23
Пингвин писал(а):
08 май 2023, 17:54
Сходи. :-D
08 май 2023, 23:15
Пингвин писал(а):
08 май 2023, 12:15
Сугубо частное мнение, но как по мне, то на XFCE продуктивнее делать всплывающие дополнительные панели с кнопками запуска нужных приложений или назначать горячие клавиши. А насчёт как в Astra Linux то, на моё предположение, нужно искать нечто дополнительное, что присутствует в настройках рабочего стола именно Astra Linux и отсутствует в Linux Mint.
09 май 2023, 08:17
madesta писал(а):
08 май 2023, 23:15
Там DE называется Fly
Lika
09 май 2023, 11:37
Пингвин писал(а):
08 май 2023, 12:15
Как Октябрёнок Пионеру :hshake: верёвками привязывать не пробовал? :thumbs: получается!
Пингвин
09 май 2023, 20:19
Lika писал(а):
09 май 2023, 11:37
Верёвку перегрызают а проволоку в чермет уносят :sad:
Пингвин
09 май 2023, 20:29
Сходил в гости к Астре :tux:
Жму Пуск выбираю программу, ПКМ отправить рабочий стол. Появляется значек на рабочем столе. Именно на том который был включен, на других он не показывается. Если надо на другой стол перенести то ПКМ на ярлычке и в окошке пункт рабочий стол наводишь на него стрелку и выбираешь на какой перенести.
Ничего такого особенного в настройках не нашел. Наверное в Минт нет такого :cray2:
09 май 2023, 22:40
Если речь идёт именно о пункте "Отправить", то вы можете сделать нужное себе самостоятельно. Документация (на англ.) здесь и конкретно по 4.16 здесь. Наследуемые дефолтные пункты для "Отправить" расположены здесь: /usr/share/Thunar/sendto В качестве примера привожу пункт "Отправить - Audacious Playlist" (файл thunar-sendto-audacious-playlist.desktop):
[Desktop Entry]
Version=1.0
Type=Application
Name=Audacious Playlist
Name[de]=Audacious Wiedergabeliste
Name[fr]=Liste de lecture d'Audacious
GenericName=Audio Playlist
GenericName[de]=Musik Wiedergabeliste
GenericName[fr]=Liste de lecture de musique
Comment=Enqueue files to playlist
Comment[de]=Dateien zur Wiedergabeliste hinzufügen
Comment[fr]=Ajouter à la liste de lecture
Icon=sound
Exec=audacious -e %F
Terminal=false
MimeType=application/ogg;application/x-cue;application/x-ogg;application/xspf+xml;audio/midi;audio/mp3;audio/mpeg;audio/mpegurl;audio/ogg;audio/prs.sid;audio/x-flac;audio/x-it;audio/x-mod;audio/x-mp3;audio/x-mpeg;audio/x-mpegurl;audio/x-ms-wma;audio/x-musepack;audio/x-s3m;audio/x-scpls;audio/x-stm;audio/x-vorbis+ogg;audio/x-wav;audio/x-xm;x-content/audio-cdda;x-directory/normal;inode/directory;
Для пользователя рекомендуют создать папку "Отправить" в своем профиле: ~/.local/share/Thunar/sendto/ По умолчанию такая папка отсутствует. А далее сравнивайте как в Астре и как в Mint. Если получится сделать, то, полагаю, народу было бы любопытно ознакомиться.
Но, насколько понял из вашей второй картинки, это больше похоже не на пункт "Отправить", а на "Особые действия" в настройках менеджера файлов. В Thunar XFCE настройка особых действий вызывается через пункт "Правка" верхнего меню (спойлер ниже). Посмотрите как в вашем менеджере файлов, не знаю какой используется в Астре.
15 авг 2023, 14:16
Пингвин, зависит от окружения. В астре не xfce. И в том же KDE есть виджет (отображение папки), который можно расположить на столах (разные папки с разным содержимым)
Вернуться в «Xfce»
