Скринсейвер на экране входа
7OH
27 апр 2023, 17:57
Mint 21.1 x64 Cinnamon
  Kernel: 5.15.0-71-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
    base: Ubuntu 22.04 jammy
  Type: Laptop System: HP product: HP ZBook Power G7 Mobile Workstation
    v: N/A serial: <superuser required>
  Mobo: HP model: 87EC v: KBC Version 34.26.00 serial: <superuser required>
    UEFI: HP v: T75 Ver. 01.09.00 date: 04/13/2022
  ID-1: BAT0 charge: 65.4 Wh (98.3%) condition: 66.5/83.2 Wh (79.9%)
    volts: 12.5 min: 11.6 model: Hewlett-Packard Primary status: N/A
  Info: 6-core model: Intel Core i7-10750H bits: 64 type: MT MCP
    arch: Comet Lake rev: 2 cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
  Speed (MHz): avg: 899 high: 901 min/max: 800/5000 cores: 1: 892 2: 900
    3: 900 4: 901 5: 900 6: 900 7: 900 8: 900 9: 900 10: 900 11: 901 12: 900
    bogomips: 62399
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Hewlett-Packard
    driver: i915 v: kernel bus-ID: 00:02.0
  Device-2: Luxvisions Innotech HP HD Camera type: USB driver: uvcvideo
    bus-ID: 1-7:4
    unloaded: fbdev,vesa gpu: i915 resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.2.5
  Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3
  Sound Server-1: ALSA v: k5.15.0-71-generic running: yes
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3
  IF: wlp0s20f3 state: up mac: <filter>
  Device-2: Intel Ethernet I219-LM vendor: Hewlett-Packard driver: e1000e
    v: kernel port: N/A bus-ID: 00:1f.6
  IF: enp0s31f6 state: down mac: <filter>
Bluetooth:
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-14:6
    bt-v: 3.0 lmp-v: 5.2
  Local Storage: total: 476.94 GiB used: 49.56 GiB (10.4%)
  ID-1: /dev/nvme0n1 vendor: KIOXIA model: N/A size: 476.94 GiB
    temp: 27.9 C
  ID-1: / size: 45.53 GiB used: 2.49 GiB (5.5%) fs: ext4 dev: /dev/nvme0n1p5
  ID-2: /boot size: 445.7 MiB used: 286.2 MiB (64.2%) fs: ext2
    dev: /dev/nvme0n1p1
  ID-3: /boot/efi size: 18.62 GiB used: 6.2 MiB (0.0%) fs: vfat
    dev: /dev/nvme0n1p2
  ID-4: /home size: 79.66 GiB used: 1.7 GiB (2.1%) fs: ext4
    dev: /dev/nvme0n1p8
  ID-5: /opt size: 18.16 GiB used: 24 KiB (0.0%) fs: ext4
    dev: /dev/nvme0n1p7
  ID-6: /usr size: 18.16 GiB used: 9.25 GiB (50.9%) fs: ext4
    dev: /dev/nvme0n1p6
Swap:
  ID-1: swap-1 type: partition size: 16.76 GiB used: 0 KiB (0.0%)
    dev: /dev/nvme0n1p4
  System Temperatures: cpu: 31.0 C pch: 27.0 C mobo: 25.0 C
  Processes: 322 Uptime: 9h 5m Memory: 15.4 GiB used: 1.35 GiB (8.8%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2345 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
Есть желание изменить настройки таймаута выключения экрана или запуска заставки на экране входа.
Чтобы у пользователей свои настройки, а вот когда ещё никто не вошел в систему - свои.
Сейчас на экране входа через 10 минут экран становится черным.
Выключается он или запускается такой скринсейвер - не уверен.
Пока я в системе (ввёл пароль) - экран не гаснет - ровно так ведёт себя как и настроено.
A.L.E.X
07 июн 2023, 13:35
7OH писал(а):
27 апр 2023, 17:57
На сколько я знаю именно так это и работает. Заставка отображается в зависимости от настройки последнего вошедшего пользователя. Если у вас гаснет экран, возможно у вас настроено отключение экрана в параметрах электропитания.
