Проблемы с копированием mp3 файлов
Isemann
Благодарил (а): 2 раза
Сообщение Isemann » 17 апр 2023, 16:40
Linux Mint 21 Vanessa Cinnamon
Kernel: 6.2.11-3-liquorix-amd64 x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: Cinnamon 5.4.12 Distro: Linux Mint 21 Vanessa
base: Ubuntu 22.04 jammy
Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: PRIME H510M-K v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1203
date: 10/27/2021
Info: 6-core model: 11th Gen Intel Core i5-11400F bits: 64 type: MT MCP
arch: Rocket Lake rev: 1 cache: L1: 480 KiB L2: 3 MiB L3: 12 MiB
Speed (MHz): avg: 3181 high: 4400 min/max: 800/4400 cores: 1: 4400
2: 2600 3: 2600 4: 4350 5: 4302 6: 4329 7: 2600 8: 2600 9: 2600 10: 2600
11: 2600 12: 2600 bogomips: 62208
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Gigabyte driver: nvidia
v: 525.105.17 bus-ID: 01:00.0
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia
resolution: 1920x1080~144Hz
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 525.105.17 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Sound Server-1: ALSA v: k6.2.11-3-liquorix-amd64 running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6
Local Storage: total: 1.14 TiB used: 425.88 GiB (36.6%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SWORDFISH size: 232.89 GiB
temp: 40.9 C
ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-00BBHA0
ID-1: / size: 93.31 GiB used: 32.66 GiB (35.0%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 486 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 117.43 GiB used: 23.22 GiB (19.8%) fs: ext4
dev: /dev/nvme0n1p5
Swap:
ID-1: swap-1 type: partition size: 15.26 GiB used: 768 KiB (0.0%)
dev: /dev/nvme0n1p4
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 56%
Processes: 284 Uptime: 2h 36m Memory: 15.46 GiB used: 3.62 GiB (23.4%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2835 Shell: Bash
v: 5.1.16 inxi: 3.3.13
При копировании MKV файлов по два за раз ~5Гб не возникает ни каких проблем. При копировании 8-ми файлов mp3 ~100-150Мб, копирование останавливается и сыпет ошибками.
Благодарил (а): 55 раз
Сообщение slant » 17 апр 2023, 17:02
Проблема на стороне телефона, вероятность 95%. Сам регулярно сталкивался.
Проверяйте разъемы, кабель, и софт (состояние OS и памяти телефона).
Это у Xaomi вообще достаточно частое явление - проблемы подобного типа при подключении. Именно что - чем больше файлов в операции, тем капризнее. Один большой файл грузится, мелочь - выдает сбои. По моим наблюдениям, если кабель и разъемы в порядке, помогает чистка телефона от лишних запущенных приложений - если он у вас "задумывается" во время переключения действий/программ хотя бы немного - очень вероятно, что при передаче по кабелю будет такой цирк.
Isemann
Сообщение Isemann » 17 апр 2023, 17:47
Проблема не на стороне смартфона 100%. Методом тыка удалось выяснить что проблема в одном конкретном файле, а именно при выделении файла внизу каталога отображались скрытые символы ↵ которых не было в названии файла. Переименование файла решило проблему.
Сообщение symon2014 » 17 апр 2023, 18:03
Isemann, Немного не в тему. Когда вставляешь картинки в сообщение , вставляй их до конца. Там рядом с загруженным файлом есть кнопочка для этого.
