Огромные иконки в тексте
graal
12 апр 2023, 18:36
Собственно сабж отчетливо виден на скриншотах. ОГРОМНЫЕ иконки в тексте в заголовке окна, в панели задач, в файловом менеджере и др. Как это можно побороть?
Kernel: 5.15.0-69-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
base: Ubuntu 22.04 jammy
Type: Desktop System: LENOVO product: 5033A3G v: ThinkCentre M71e
serial: <superuser required>
Mobo: LENOVO model: N/A serial: <superuser required> BIOS: LENOVO
v: 9QKT39AUS date: 08/10/2012
Info: dual core model: Intel Core i3-2120 bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 2480 high: 2903 min/max: 1600/3300 cores: 1: 2699
2: 2301 3: 2903 4: 2018 bogomips: 26341
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Gigabyte driver: nvidia
v: 525.105.17 bus-ID: 01:00.0
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia
resolution: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
v: 4.6.0 NVIDIA 525.105.17 direct render: Yes
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GP108 High Definition Audio vendor: Gigabyte
Sound Server-1: ALSA v: k5.15.0-69-generic running: yes
vendor: Lenovo driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Local Storage: total: 689.33 GiB used: 451.57 GiB (65.5%)
ID-1: /dev/sda vendor: Kimtigo model: SSD 240GB size: 223.57 GiB
ID-2: /dev/sdb vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-1: / size: 117.43 GiB used: 69.91 GiB (59.5%) fs: ext4 dev: /dev/sda6
ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/sda5
Swap:
ID-1: swap-1 type: file size: 8 GiB used: 1.2 MiB (0.0%) file: /swapfile
System Temperatures: cpu: 38.0 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 34%
Processes: 250 Uptime: 5h 46m Memory: 7.75 GiB used: 2.9 GiB (37.5%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2616 Shell: Bash
v: 5.1.16 inxi: 3.3.13
13 апр 2023, 06:58
graal, а не расскажешь нам после каких действий они такими стали?
graal
13 апр 2023, 22:04
Разобрался. По совету "добрых людей" из Инторнета был удален файл (ну как файл , ссылка): /etc/fonts/conf.d/10-scale-bitmap-fonts.conf
Сглаживания шрифтов, как в винде, вы не добётесь, а гемморой со шрифтами поимеете.
14 апр 2023, 01:37
graal писал(а):
13 апр 2023, 22:04
По совету
Странно, но у меня эта ссылка присутствует, но никаких проблем как нарисовано в скриншотах у себя ни разу не наблюдал. М.б. файл когда-то был подвергнут изменению и в нем поигрались с цифрами или значениями false/true ...
graal
14 апр 2023, 10:17
madesta, Все верно. Ссылка есть - проблем нет, ссылки нет - проблема есть. Просто где-то в теме про сглаживание шрифтов видел совет удалить ссылки. Вот я удалил и получил гемор.
