Проблема с SSD
1o4ka
Благодарил (а): 23 раза
Проблема с SSD
16 мар 2023, 10:51
LM 21.1x64
железо:
$ inxi -Fxz
Kernel: 5.15.0-56-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: Cinnamon 5.6.5 Distro: Linux Mint 21.1 Vera
base: Ubuntu 22.04 jammy
Type: Desktop Mobo: Gigabyte model: H81M-S2PV serial: <superuser required>
UEFI: American Megatrends v: F9 date: 08/11/2015
Info: dual core model: Intel Pentium G3420 bits: 64 type: MCP arch: Haswell
rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 2787 high: 3193 min/max: 800/3200 cores: 1: 2381
2: 3193 bogomips: 12770
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM107 [GeForce GTX 750] vendor: Palit Microsystems
driver: nouveau v: kernel bus-ID: 01:00.0
Device-3: Sunplus Innovation HD 720P webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-4:3
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: nouveau resolution: 1920x1080~60Hz
OpenGL: renderer: NV117 v: 4.3 Mesa 22.0.5 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-3: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: Palit Microsystems driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-4: Sunplus Innovation HD 720P webcam type: USB
Sound Server-1: ALSA v: k5.15.0-56-generic running: yes
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 3-1:2
IF: wlxc46e1f210c3f state: up mac: <filter>
Local Storage: total: 1.35 TiB used: 261.34 GiB (19.0%)
ID-1: /dev/sda vendor: Patriot model: Burst Elite 480GB size: 447.13 GiB
ID-2: /dev/sdb vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-3: /dev/sdc vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-1: / size: 97.97 GiB used: 16.19 GiB (16.5%) fs: ext4 dev: /dev/sda5
ID-2: /boot/efi size: 96 MiB used: 30.3 MiB (31.5%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 245.44 GiB used: 56.21 GiB (22.9%) fs: ext4
dev: /dev/sda7
Swap:
ID-1: swap-1 type: partition size: 16.6 GiB used: 0 KiB (0.0%)
dev: /dev/sda6
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%)
dev: /dev/sdb5
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 40.0 C
Processes: 240 Uptime: 1d 11h 51m Memory: 15.52 GiB used: 4.77 GiB (30.7%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2800 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Навалились беды разом. Сегодня с утра "полетел" стационарный ПК. Вернее не сам ПК, а диск SSD с установленными на нём виндой и LM.
Что было перед этим? Вынимал SSD из системного блока, запускал (через внешний бокс, USB3) на ноуте. Потом вставил SSD обратно в системный блок
Потом сделал резервные копии OC на внешний накопитель. Вроде всё, как обычно.
С утра стационар повёл себя странно. Начал зависать. Перезагрузил, и собственно, всё. Стационар перестал видеть SSD. Отключил системник, проверил соединения. Вроде, всё в норме. Включил ПК. И вот какая получилась картина. Комп видит SSD:
Вот он: Р0 Patriot
Но при загрузке P0 выскакивает ошибка:
Попытка восстановить ОСь LM посредством LiveCD заканчивается ничем. LiveSD не видит SSD:
Обратите внимание на скрин. Здесь должны быть ещё три раздела: Винда на SSD, /LM и /home на SSD.
А здесь только винда с HDD и Магея с HDD со своим хомяком. Ну, ещё виден home LiveCD.
Короче, восстанавливать LM некуда.
Подскажите, что можно предпринять?
...bis dat qui cito dat
1o4ka
Проблема с SSD
16 мар 2023, 12:00
Подключил SSD к винде. Через Paragon увидел следующее:
То есть, на SSD ничего нет. Как такое могло произойти? Я понимаю, не само оно так случилось, но быть может, кто-либо объяснит?
Проблема с SSD
16 мар 2023, 12:14
1o4ka писал(а):
16 мар 2023, 12:00
угадайте что я сделал и объясните мне :-D
1o4ka
Проблема с SSD
16 мар 2023, 12:17
У меня лично никаких соображений на сей счёт нет. Быть может, у кого-то случалась подобная проблема? Поделитесь.
s681
Благодарил (а): 71 раз
Проблема с SSD
16 мар 2023, 12:47
Что видит утилита Диски или Gparted из-под LiveCD?
Slav164
Благодарил (а): 12 раз
Проблема с SSD
16 мар 2023, 13:14
1o4ka писал(а):
16 мар 2023, 10:51
Поменяй шнурок.
Благодарил (а): 1226 раз
Проблема с SSD
16 мар 2023, 13:16
1o4ka писал(а):
16 мар 2023, 10:51
Если не получается восстановить диск из резервных копий, то проще всего с нуля установить на него винду и затем LM
Проблема с SSD
16 мар 2023, 13:16
Slav164 писал(а):
16 мар 2023, 13:14
Поменяй шнурок.
Тоже нормальная идея. SATA шлейфы очень часто выходят из строя, особенно дешёвые
Проблема с SSD
16 мар 2023, 14:21
1o4ka писал(а):
16 мар 2023, 12:00
Объяснит - вряд ли. Могу только предположить, исходя из описания в первом посте, что с вероятностью ~75% это аппаратная проблема. Какая-то железка начала глючить - SSD, кабель, разъемы, или контроллер (или даже БП - правда тут вероятность не так высока). В результате на SSD оказался затерт блок с таблицей разделов (неправильно оказался выбран блок для записи). В случае SSD это приговор для данных.
И что хуже всего - нельзя дать никаких гарантий что это не повторится. Нужно искать какая именно деталь чудит.
1o4ka
Проблема с SSD
16 мар 2023, 16:24
Всё закончилось полным форматированием SSD (полетело всё: и винда, и LM). По всей видимости, LM поймал очередной глюк. Было такое, как-то, после установки обновлений.
Так что,hellonet, вы правы
hellonet писал(а):
16 мар 2023, 13:16
Но, я думал, присоветуют что-либо новое...
1o4ka
Проблема с SSD
16 мар 2023, 16:25
slant, а может, и вы правы. Но, в системнике стоят ещё два HDD (рабочих, с ОСями), и с ними - никакой беды. А вот с SSD, там где LM, уже второй "залёт".
А почему? Вот и я не знаю.
Проблема с SSD
16 мар 2023, 16:41
1o4ka, скорее всего залёт из-за не очень качественного SSD диска. Был бы фирмы Samsung, например, то такой фигни скорее всего не было бы. У меня такая ерунда пару раз происходила на старинном диске фирмы OCZ Vertex3. Стоял на рабочем компе, вообще не определялся ничем. Дал ему с недельку отдохнуть, потом воткнул в ноутбук. Определился. Установил с нуля LM, да так и стоит на нём единственной осью. Больше не слетает. А пока на компе стоял там была Винда и LM - 2 раза слетал. На старых и не очень качественных дисках это болезнь. Видимо не любят сильного заполнения. Всегда надо запас пустого места держать около сотни гигов. Будет меньше - будет всё слетать
1o4ka
Проблема с SSD
16 мар 2023, 17:00
hellonet, на нём и так - 256 Гб Всего.
Проблема с SSD
16 мар 2023, 17:02
1o4ka писал(а):
16 мар 2023, 17:00
А почему пишет: ID-1: /dev/sda vendor: Patriot model: Burst Elite 480GB size: 447.13 GiB? Грубо говоря пятисотка. Может ещё из-за этого глючит
1o4ka
Проблема с SSD
16 мар 2023, 17:04
hellonet, ошибся, пардон. Это на ноуте - 256.
Проблема с SSD
16 мар 2023, 17:07
1o4ka писал(а):
16 мар 2023, 17:04
Ну тогда я бы на комп поставил парочку SSD дисков. И на каждом своя ось. Тогда глюков будет минимально. Тем более SSD диски сейчас уже достаточно дешёвые, ну а все HDD под файлопомойку.
6 ошибок при использовании SSD накопителей:
https://club.dns-shop.ru/blog/t-101-ssd ... kopitelei/
1o4ka
Проблема с SSD
17 мар 2023, 07:51
В общем, можно подвести, какой ни какой, итог.
Долго и нудно восстанавливал я LM из резервной копии. Вначале подцепил snaphost с ноутбука (там у меня KDE). Стационар не пошёл. Написал: не удалось загрузить plasmу. Потом раза три гонял snaphost от стационара. Не хотелось бы плохо говорить про людей пишущих о том, что Timeshift является исключительной панацеей от всех бед, но положение дел таково: я уже не раз (судьба) восстанавливал ОСь LM и на ноуте, и на стационаре. Тенденция такова: восстановление удаётся только из LiveCD. Восстановление из установленной системы у меня нигде не прошло. Зато, после восстановления из установленной ОСи, что ноут, что стационар, уходили в аврийный режим. И самым лёгким решением, для меня, было повторное использование LiveCD.
На этот раз восстановление прошло не совсем гладко, и повторюсь, с третьего (где-то) раза. Так как копия была неполная (exclude all files), /home приказал долго жить. Как научила практика, всё самое ценное, надо хранить в двух, а то и в трёх местах. На стационаре установлены два HDD по 500Гб. Когда настала пора апргейда, я решил их не выкидывать. Пусть стоят. Кому они мешают? Таким образом, у меня в запасе две кладовки. И всё моё ценное: файлы свёрстанных книг, хранятся там. Более того, на одном HDD установлена 7-ка. Я ей не пользуюсь. Но на разделе D, у меня там есть много интересного. На втором HDD установлена Mageia 8. Я ей тоже не пользуюсь. Захожу, иногда, обновить. Но система в рабочем состоянии. И даже, когда "летит" вроде бы всё (а было уже такое), без рабочей ОСи я не остаюсь.
В отличие от /home, / восстановился. Но как-то не совсем. Полетели все мои настройки DE под себя. Рабочий стол, обои, панели, браузеры и т.д. пришлось перенастраивать сызнова. Хотя, загрузочное меню Grub, над которым я колдовал не один день, сохранилось:
(какая радость)
Винду (10), которая стояла на SSD, не жалко абсолютно. Там только С был в наличии. Уговорили меня, её установить, товарищи: ну, посмотри, поработай...может, понравится. Посмотрел, поработал...не вставила меня винда.
Единственное, чем я иногда пользовался в 10-ке, так это играл в Ведьмака III, напрямую из 7-ки (там Ведьмак установлен), без установки на 10-ку. И всё проходило. Играй - не хочу.Тем более что, ОЗУ вместо 8Гб, расширили до 16-ти, и Геральд перстал спать на ходу. Хорошая игрушка. Жалко играться некогда.
О чём хотелось бы сказать в завершение. Пошёл я в магазин и купил внешний бокс на SSD. Вставил SSD в бокс и теперь могу работать, с этого SSD, как на стационаре, так и на ноуте, через USB.
(как-то так)
yarichin
Проблема с SSD
17 мар 2023, 08:04
1o4ka писал(а):
17 мар 2023, 07:51
А что , такое возможно разве ? Сам себе операцию по замене сердца делать.
1o4ka писал(а):
17 мар 2023, 07:51
С линуксом. С виндой дела обстоят не столь радужно.
yarichin
Проблема с SSD
17 мар 2023, 08:09
yarichin писал(а):
17 мар 2023, 08:04
Могу предложить попробовать для эксперимента вариант харакири. Перед запуском таймшифта удалить из файла /etc/mtab строку с корневым разделом. Может что и выйдет , но это не точно. Этот трюк я использовал при установке линукса с исошника , находящегося в корневом разделе.
Проблема с SSD
17 мар 2023, 08:14
1o4ka писал(а):
17 мар 2023, 07:51
Так эти настройки хранятся в каталоге пользователя, что лежит в каталоге /home
1o4ka писал(а):
17 мар 2023, 07:51
А потом задавать вопросы на форуме: "что произошло?", "где мои разделы на диске?", "объясните мне что произошло?" и т.д. Это называется ССЗБ.
Сейчас этот форум просматривают: Google [Bot] и 1 гость
