Не работает микрофон.
yarichin
19 фев 2023, 23:42
Всем привет. Поменял мыло на шило. В смысле ноутбук. Был Lenovo G50-70. Всё работало , но слабоват конечно.
Поменял на такой.
Kernel: 5.19.0-32-generic x86_64 bits: 64 compiler: N/A
Desktop: MATE 1.26.0 Distro: Linux Mint 21.1 Vera base: Ubuntu 22.04 jammy
Type: Laptop System: LENOVO product: 80YN v: Lenovo ideapad 320-17ABR
serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40679WIN
serial: <superuser required> UEFI: LENOVO v: 5QCN24WW date: 07/29/2019
ID-1: BAT0 charge: 25.9 Wh (100.0%) condition: 25.9/35.0 Wh (73.9%)
volts: 8.4 min: 7.6 model: LGC L16L2PB3 status: Full
Info: quad core model: AMD A10-9620P RADEON R5 10 COMPUTE CORES 4C+6G
bits: 64 type: MT MCP arch: Excavator rev: 1 cache: L1: 320 KiB L2: 2 MiB
Speed (MHz): avg: 1465 high: 1924 min/max: 1300/2500 boost: enabled
cores: 1: 1924 2: 1348 3: 1293 4: 1296 bogomips: 19962
Device-1: AMD Wani [Radeon R5/R6/R7 Graphics] vendor: Lenovo driver: amdgpu
v: kernel bus-ID: 00:01.0
Device-2: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 M440/M445 530/535
620/625 Mobile]
vendor: Lenovo driver: amdgpu v: kernel bus-ID: 03:00.0
Device-3: Syntek EasyCamera type: USB driver: uvcvideo bus-ID: 1-1.2:4
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1600x900~60Hz
OpenGL:
renderer: CARRIZO (carrizo LLVM 15.0.6 DRM 3.47 5.19.0-32-generic)
v: 4.6 Mesa 22.2.5 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:01.1
Device-2: AMD Family 15h Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:09.2
Sound Server-1: ALSA v: k5.19.0-32-generic running: yes
Device-1: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtl8821ae v: kernel port: 3000 bus-ID: 01:00.0
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus-ID: 02:00.0
Bluetooth:
Device-1: Realtek RTL8821A Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-1.1:3
Report: hciconfig ID: hci0 rfk-id: 3 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Local Storage: total: 476.94 GiB used: 125.6 GiB (26.3%)
ID-1: /dev/sda model: SATA3 512GB SSD size: 476.94 GiB
ID-1: / size: 54.7 GiB used: 19.1 GiB (34.9%) fs: ext4 dev: /dev/sda3
ID-2: /boot/efi size: 474.9 MiB used: 61 MiB (12.8%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 246.39 GiB used: 106.44 GiB (43.2%) fs: ext4
dev: /dev/sda4
Swap:
ID-1: swap-1 type: file size: 1024 MiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 56.8 C mobo: N/A
GPU: device: amdgpu temp: 50.0 C device: amdgpu temp: 56.0 C
Processes: 243 Uptime: 38m Memory: 7.16 GiB used: 2.38 GiB (33.2%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2833 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Вроде всё нормально. Но пытаясь связаться в телеге , обнаружил что меня не слышно.
Оказалось не пашет микрофон.
cat /proc/asound/card*/codec* | grep Codec
Codec: ATI R6xx HDMI
Codec: Realtek ALC236
В настройках всё выбрано верно. Проверял в телеге , скайпе и онлайн тесты - везде молчок.
Есть только один вариант где проверка проходит.
arecord -f cd -d 10 test-mic.wav
aplay test-mic.wav
В этом случае микрофон пишет звук.
Чуствую подвох в конфликте кодеков , или возможно пульсеадио и пипевире. Сам разобраться пока не смог.
PS. Проверил с внешней вэбкой , микрофон пашет.
И ещё одно интересное наблюдение. При включенном pavucontrol увидел два ползунка микрофона. Если один убрать на ноль то индикатор начинает реагировать на голос. Проверил на вэб версии скайпа , звук появляется , но на 1-2секунды , потом второй ползунок подтягивается к первому и звук пропадает. На вэбке микрофон один и режим по звуку называется моно. А на ноуте видимо 2 микрофона ( на крышке ноута 2 дырки по бокам камеры ) , и в стереорежиме работать не желает.
20 фев 2023, 01:35
yarichin писал(а):
19 фев 2023, 23:42
Сами по себе они не конфликтуют. Но возможны проблемы, если ставился пакет pipewire-pulse (эмулятор пульсы от pipewire) без предварительного удаления обычного pulseaudio. Этот пакет должен полностью заменять собой оригинальную пульсу - тогда все будет хорошо, и программы которые работают через пульсу ничего даже не заметят.
yarichin
20 фев 2023, 01:43
20 фев 2023, 01:35
не ставился
apt policy pipewire-pulse
pipewire-pulse:
Установлен: (отсутствует)
Кандидат: 0.3.48-1ubuntu3
меня напрягло вот это
20 фев 2023, 02:46
yarichin писал(а):
20 фев 2023, 01:43
Не, это нормальная картина. У меня то же самое было примерно полгода, с момента когда pipewire только добавили, но пульсу еще не выпилили.
20 фев 2023, 06:30
yarichin, а покажи скрины pavucontrol что там по звуку и микрофону. И давай скрины alsamixer до кучи
yarichin
20 фев 2023, 07:16
rogoznik,
20 фев 2023, 07:24
yarichin, а вот там в pavucontrol есть еще advanced. Покажи что там.
В программах, в которых звонишь попробуй выключить автоматическую настройку микрофона.
Я всегда выключаю - т.к. много раз сталкивался с тем что меня либо не слышат, либо я громкий с шумами, либо еще иногда бывало что во время того как говорю чувствительность микрофона прыгала туда сюда.
yarichin
20 фев 2023, 07:35
Ничего там интересного. С шумами , уровнями , автоматическими настройками , это всё я пробовал. Фигня получается. А реальный вариант когда микрофон работает это если убрать на ноль любой из них , хоть левый , хоть правый. Я даже где то в сети читал про этот способ , но там не было описано как это сделать. А так эффекта хватает не на долго , они сравнивают уровни и замолкают.
Кстати в винде немного выглядит по другому. При проверке звука индикатор отрабатывает на ура , как и надо. А если запустить скайп или любой онлайн тест , то молчание )0
20 фев 2023, 07:53
yarichin, а если замок нажать ничего дополнительно не появляется? Там где-то должна быть настройка, которая включает/отключает автоматическое выравнивание уровня каналов.
И посмотри на вкладке "Конфигурация" нет ли там возможности для микрофона включить режим моно
yarichin
20 фев 2023, 08:09
20 фев 2023, 07:53
замок нажать
Как раз там собака и роется. Выставлял любые варианты , связать , не связать. Один раз на онлайн проверке микрофон проработал больше 30 секунд и заткнулся. Посмотрел эту вкладку , а уровни снова одинаковые.. Получается каналы связываются сами втихаря.
yarichin
20 фев 2023, 08:40
Кажется нашёл решение , немного костыльное но я не аудио маньяк. Нашёл здесь же на форуме.
Нет звука с микрофона в скайпе
Там есть ссылочка с названием -- Иная возможная причина
Мне подошло.
20 фев 2023, 08:47
yarichin, это будет работать до тех пор пока ubuntu полностью не перейдет на pipewire
yarichin
20 фев 2023, 08:49
20 фев 2023, 08:47
до тех пор пока
Вот тогда и озадачимся ) . Апнем тему )
sheridan
Решено: 14
Благодарил (а): 900 раз
20 фев 2023, 13:19
Пытался подключить чистый pipewire в linuxmint, вешал систему, в Gentoo, Arch, Manjaro работает хорошо.
Вернуться в «Мультимедиа»
