Cinnamon скукоживается интерфейс при масштабировании
Sectos05
Благодарил (а): 4 раза
04 фев 2023, 20:14
Linux Mint 21.1
Cinnamon 5.6.7
Монитор Viewsonic VX2263Smhl
Разрешение 1920х1080
Kernel: 5.15.0-58-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: Cinnamon 5.6.7 Distro: Linux Mint 21.1 Vera
base: Ubuntu 22.04 jammy
Type: Desktop Mobo: ASRock model: B450M-HDV R4.0
serial: <superuser required> UEFI: American Megatrends v: P3.70
date: 11/14/2019
Info: 6-core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
rev: 2 cache: L1: 576 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 1480 high: 2039 min/max: 1550/3400 boost: enabled
cores: 1: 1392 2: 1371 3: 1372 4: 2039 5: 1468 6: 1450 7: 1372 8: 1374
9: 1372 10: 1665 11: 1519 12: 1377 bogomips: 81435
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Micro-Star MSI
driver: nvidia v: 525.78.01 bus-ID: 08:00.0
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia
resolution: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 960/PCIe/SSE2
v: 4.6.0 NVIDIA 525.78.01 direct render: Yes
Device-1: NVIDIA GM206 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 08:00.1
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3
Sound Server-1: ALSA v: k5.15.0-58-generic running: yes
vendor: ASRock driver: r8169 v: kernel port: f000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 465.76 GiB used: 305.37 GiB (65.6%)
ID-1: /dev/sda vendor: Seagate model: ST3500418AS size: 465.76 GiB
ID-1: / size: 95.05 GiB used: 34.85 GiB (36.7%) fs: ext4 dev: /dev/sda4
ID-2: /boot/efi size: 487 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/sda2
Swap:
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 27 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 36%
Processes: 362 Uptime: 23m Memory: 15.55 GiB used: 3.6 GiB (23.2%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2534 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Проблема такая: поставил Linux Mint и попробовал задать масштабирование монитора в настройках экрана в 125%. Шрифт при этом увеличился, но кнопки наоборот уменьшились.
Замечено минимум в трёх программах: Krusader, Open Office, Steam.
Перезапуск сеанса и перезагрузка не помогают, только возврат к 100%.
Прицеплю для примера скрины из крусейдера.
04 фев 2023, 21:58
Sectos05 писал(а):
04 фев 2023, 20:14
Krusader
Этот на QT написан. Надо лезть в настройки для приложений на QT и там настраивать масштабирование.
Sectos05 писал(а):
04 фев 2023, 20:14
Open Office
А чем не угодил LibreOffice?
Sectos05 писал(а):
04 фев 2023, 20:14
Steam
Если не ошибваюсь, написан на QT
04 фев 2023, 22:08
Sectos05 писал(а):
04 фев 2023, 20:14
Удивил выбор именно Krusader и Open Office. Krusader тянет за собой что-то из kde и qt. Могу ошибаться, но полагаю, что и настройки отображения в нём регулируются больше настройками из области qt. В gtk-ориентированной системе, наверное, разумнее было бы использовать Double Commander версии gtk. Что касается Open Office, то почему не Libre Office, который более активно развивается? Тем более, что совсем недавно вышел вообще новый LO7.5 Open Office может использовать только gtk2, в то время как сейчас почти перешли на gtk3. По крайней мере, в моём устаревшем LO 6.4.7.2 (LM20.3) и то используется пакет libreoffice-gtk3, а не libreoffice-gtk2 и libreoffice-gtk.
Sectos05
04 фев 2023, 23:14
04 фев 2023, 21:58
На сайте, для которого я пишу тексты, при копировании из либры почему-то съедаются пробелы (удаление двойных пробелов не помогает), вот и решил попробовать опен. Хотя на нём проблема тоже иногда проскакивает, так что не исключено, что перейду обратно.
Белый Кролик
Решено: 10
Благодарил (а): 354 раза
06 фев 2023, 22:32
04 фев 2023, 21:58
Electron.
07 фев 2023, 23:22
Sectos05 писал(а):
04 фев 2023, 23:14
Мне думалось, что при написании текстов сайта можно ограничиться простым текстовым редактором.
Sectos05
09 фев 2023, 16:54
madesta писал(а):
07 фев 2023, 23:22
Для больших текстов блокнот не особо удобен, функционала не хватает. Плюс у меня есть жирные и курсивные участки.
