Проблема с flatpak/Nvidia. Прошу помочь.
rekshinskiy
31 янв 2023, 10:56
Добрый день. Подскажите пожалуйста как быть.
Kernel: 5.15.0-58-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: Cinnamon 5.6.7 Distro: Linux Mint 21.1 Vera
base: Ubuntu 22.04 jammy
Type: Desktop System: Gigabyte product: N/A v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z77-DS3H serial: <superuser required>
UEFI: American Megatrends v: F11a date: 11/13/2013
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
charge: 55% (should be ignored) status: Discharging
Info: quad core model: Intel Core i5-3470 bits: 64 type: MCP
arch: Ivy Bridge rev: 9 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 2188 high: 2730 min/max: 1600/3600 cores: 1: 1766
2: 1845 3: 2413 4: 2730 bogomips: 25541
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: NVIDIA GK104 [GeForce GTX 660 Ti] vendor: Gigabyte driver: nvidia
v: 470.161.03 bus-ID: 01:00.0
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1.5:5
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia resolution:
1: 1200x1920~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 660 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 470.161.03 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GK104 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1.5:5
Sound Server-1: ALSA v: k5.15.0-58-generic running: yes
Device-1: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: Gigabyte
driver: alx v: kernel port: d000 bus-ID: 03:00.0
Device-2: TP-Link Archer T2U PLUS [RTL8821AU] type: USB driver: rtl88XXau
bus-ID: 3-3:2
IF: wlx9848278a60d6 state: dormant mac: <filter>
IF-ID-1: tunsnx state: unknown speed: 10 Mbps duplex: full mac: N/A
Local Storage: total: 577.55 GiB used: 47.8 GiB (8.3%)
ID-1: /dev/sda vendor: Seagate model: ST500NM0011 size: 465.76 GiB
ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO mSATA 120GB
ID-1: / size: 109.38 GiB used: 47.8 GiB (43.7%) fs: ext4 dev: /dev/sdb2
ID-2: /boot/efi size: 92.5 MiB used: 5.2 MiB (5.6%) fs: vfat
dev: /dev/sdb1
Swap:
ID-1: swap-1 type: partition size: 22.35 GiB used: 0 KiB (0.0%)
dev: /dev/sda1
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 44 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Processes: 260 Uptime: 2h 1m Memory: 23.44 GiB used: 2.99 GiB (12.8%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2446 Shell: Bash
v: 5.1.16 inxi: 3.3.13
В менеджере обновлений висит и не хочет обновляться org.freedesktop.Platform.GL.nvidia-470-161-03 (A flatpak runtime package)
Пробовал через терминал:
В менеджере приложений не могу установить ни одно приложение через flatpak, т.к. установщик сначала пытается поставить этот пакет.
31 янв 2023, 11:03
rekshinskiy, пробовал удалить этот пакет?
rekshinskiy
31 янв 2023, 11:09
нет, я относительно недавно поставил линукс, поэтому владею им не очень свободно(
Удалить именно flatpak и потом переустановить?
yarichin
31 янв 2023, 12:42
Код 403 иногда указывает на желательность VPN соединения.
31 янв 2023, 13:55
rekshinskiy писал(а):
31 янв 2023, 11:09
Не...flatpak удалять не надо.
А вот пакет nvidia, установленный из flatpak, попробуй удалить
rekshinskiy
31 янв 2023, 21:20
Да, vpn соединение оказало положительное влияние. Спасибо всем откликнувшимся!
