После ввода команды "dist-upgrade" выдает ошибку "Пакет zlib1g:i386 пока не настроен."
_Pokoi_
Решено: 6
Благодарил (а): 9 раз
27 янв 2023, 01:11
inxi
System: Kernel: 5.19.8-xanmod1 x86_64 bits: 64 compiler: N/A Desktop: Gnome 3.36.9 Distro: Linux Mint 20.3 Una
base: Ubuntu 20.04 focal
Machine: Type: Laptop System: Acer product: Extensa 2520G v: V1.15 serial: <filter>
Mobo: Acer model: BA50_SL v: V1.15 serial: <filter> UEFI [Legacy]: Insyde v: 1.15 date: 05/13/2016
Battery: ID-1: BAT1 charge: 23.1 Wh condition: 26.9/37.0 Wh (73%) model: SANYO AL15A32 status: Charging
CPU: Topology: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake rev: 3 L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38400
Speed: 2300 MHz min/max: 400/2301 MHz Core speeds (MHz): 1: 2626 2: 2624 3: 2601 4: 2600
Graphics: Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA GK208BM [GeForce 920M] vendor: Acer Incorporated ALI driver: nvidia v: 470.141.03 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.13 driver: modesetting,nvidia unloaded: fbdev,nouveau,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: NVIDIA GeForce 920M/PCIe/SSE2 v: 4.6.0 NVIDIA 470.141.03 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus ID: 00:1f.3
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k5.19.8-xanmod1
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8169
v: kernel port: 3000 bus ID: 02:00.0
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Lite-On driver: ath9k v: kernel
port: 3000 bus ID: 03:00.0
Device-3: Lite-On Qualcomm Atheros Bluetooth type: USB driver: btusb bus ID: 1-5:6
Drives: Local Storage: total: 465.76 GiB used: 122.88 GiB (26.4%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB temp: 37 C
Partition: ID-1: / size: 456.88 GiB used: 122.88 GiB (26.9%) fs: ext4 dev: /dev/sda5
Sensors: System Temperatures: cpu: 47.5 C mobo: N/A gpu: nvidia temp: 47 C
Info: Processes: 259 Uptime: 2h 39m Memory: 7.64 GiB used: 6.24 GiB (81.6%) Init: systemd runlevel: 5 Compilers:
gcc: 9.4.0 Shell: bash v: 5.0.17 inxi: 3.0.38
Суть проблемы:
sudo apt-get dist-upgrade
Расчёт обновлений… Готово
libllvm12:i386 linux-tools-5.4.0-125 linux-tools-5.4.0-125-generic
Следующие НОВЫЕ пакеты будут установлены:
libllvm14 libllvm14:i386 libxmlb2 linux-headers-6.1.8-x64v1-xanmod1 linux-image-6.1.8-x64v1-xanmod1 linux-tools-5.4.0-137 linux-tools-5.4.0-137-generic
linux-xanmod-x64v1
Следующие пакеты будут обновлены:
bind9-dnsutils bind9-host bind9-libs binutils binutils-common binutils-x86-64-linux-gnu ca-certificates chromium compiz compiz-core compiz-gnome compiz-plugins
compiz-plugins-default compizconfig-settings-manager corectrl curl dnsmasq-base firefox-locale-en firefox-locale-ru fwupd ghostscript ghostscript-x
gir1.2-javascriptcoregtk-4.0 gir1.2-webkit2-4.0 gir1.2-xapp-1.0 git git-man grub-common grub-pc grub-pc-bin grub2-common isc-dhcp-client isc-dhcp-common kpartx
kpartx-boot krb5-locales libasn1-8-heimdal libasn1-8-heimdal:i386 libbinutils libcompizconfig0 libctf-nobfd0 libctf0 libcurl4 libdecoration0 libegl-mesa0
libflac++6v5 libflac8 libflac8:i386 libfprint-2-2 libfwupd2 libfwupdplugin5 libgbm1 libgl1-mesa-dri libgl1-mesa-dri:i386 libgl1-mesa-glx libgl1-mesa-glx:i386
libglapi-mesa libglapi-mesa:i386 libglx-mesa0 libglx-mesa0:i386 libgs9 libgs9-common libgssapi3-heimdal libgssapi3-heimdal:i386 libhcrypto4-heimdal
libhcrypto4-heimdal:i386 libheimbase1-heimdal libheimbase1-heimdal:i386 libheimntlm0-heimdal libheimntlm0-heimdal:i386 libhx509-5-heimdal libhx509-5-heimdal:i386
libjavascriptcoregtk-4.0-18 libjbig0 libjbig0:i386 libjpeg-turbo8 libjpeg-turbo8:i386 libkrb5-26-heimdal libkrb5-26-heimdal:i386 libksba8 libmysqlclient21
libmysqlclient21:i386 libnautilus-extension1a libnl-3-200 libnl-genl-3-200 libnl-route-3-200 libnss-myhostname libnvidia-cfg1-470 libnvidia-common-470
libnvidia-compute-470 libnvidia-compute-470:i386 libnvidia-decode-470 libnvidia-decode-470:i386 libnvidia-encode-470 libnvidia-encode-470:i386 libnvidia-extra-470
libnvidia-fbc1-470 libnvidia-fbc1-470:i386 libnvidia-gl-470 libnvidia-gl-470:i386 libnvidia-ifr1-470 libnvidia-ifr1-470:i386 libosmesa6 libosmesa6:i386
libpam-modules libpam-modules-bin libpam-runtime libpam0g libpcre2-16-0 libpcre2-32-0 libpq5 libpython3.8 libpython3.8-dev libpython3.8-minimal libpython3.8-stdlib
libraw19 libreoffice-java-common libreoffice-l10n-en-za libreoffice-sdbc-hsqldb libroken18-heimdal libroken18-heimdal:i386 libsmbclient libsnmp-base libsnmp35
libsnmp35:i386 libtiff5 libtiff5:i386 libunoil-java libwayland-cursor0 libwayland-cursor0:i386 libwayland-egl1 libwayland-egl1:i386 libwbclient0 libwebkit2gtk-4.0-37
libwind0-heimdal libwind0-heimdal:i386 libxatracker2 libxpm4 libxpm4:i386 lintian linux-libc-dev linux-tools-common linux-tools-generic linux-xanmod login
mesa-va-drivers mesa-va-drivers:i386 mesa-vdpau-drivers mesa-vdpau-drivers:i386 mesa-vulkan-drivers mesa-vulkan-drivers:i386 nautilus-data nvidia-compute-utils-470
nvidia-dkms-470 nvidia-driver-470 nvidia-kernel-common-470 nvidia-kernel-source-470 nvidia-utils-470 openjdk-11-jre openjdk-11-jre-headless passwd python-apt-common
python-pip-whl python3-apport python3-apt python3-compizconfig python3-mako python3-numpy python3-pil python3-pip python3-pkg-resources python3-problem-report
python3-samba python3-setuptools python3-tz python3-urllib3 python3-wheel python3.8 python3.8-dev python3.8-minimal python3.8-venv samba-common samba-common-bin
samba-libs smbclient sudo thunderbird thunderbird-gnome-support thunderbird-locale-en thunderbird-locale-en-us thunderbird-locale-ru timeshift tzdata unzip
vim-common vim-tiny warpinator xserver-common xserver-xephyr xserver-xorg-core xserver-xorg-legacy xserver-xorg-video-amdgpu xserver-xorg-video-nvidia-470
xul-ext-lightning xwayland xxd
Обновлено 206 пакетов, установлено 8 новых пакетов, для удаления отмечено 0 пакетов, и 0 пакетов не обновлено.
Установлено или удалено не до конца 87 пакетов.
Необходимо скачать 0 B/748 MB архивов.
После данной операции объём занятого дискового пространства возрастёт на 953 MB.
Хотите продолжить? [Д/н]
Извлекаются шаблоны из пакетов: 100%
Предварительная настройка пакетов …
setting xserver-xorg-legacy/xwrapper/allowed_users from configuration file
dpkg: проблемы зависимостей не позволяют выполнить обработку триггеров libglib2.0-0:i386:
libglib2.0-0:i386 зависит от zlib1g (>= 1:1.2.2), однако:
dpkg: ошибка при обработке пакета libglib2.0-0:i386 (--configure):
проблемы зависимостей — оставляем триггеры не обработанными
dpkg: слишком много ошибок — останавливаемся
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
libglib2.0-0:i386
Обработка остановлена из-за слишком большого количества ошибок.
Процесс гуглинга привёл сюда https://www.linux.org.ru/forum/desktop/16813683
в качестве решения предлагается выполнить скрипт :
while read PKG; do
sudo dpkg --remove --force-remove-reinstreq "$PKG":i386
done < pkg.txt
sudo apt reinstall ~i
Но у меня выдает следующее :
Идет длинный список переустановленных пакетов а за ним вот это -
E: Невозможно найти источник для загрузки «login:amd64» версии «1:4.8.1-1ubuntu5.20.04.2»
E: Невозможно найти источник для загрузки «libpam-modules:amd64» версии «1.3.1-5ubuntu4.3»
E: Невозможно найти источник для загрузки «python3.8-minimal:amd64» версии «3.8.10-0ubuntu1~20.04.5»
E: Невозможно найти источник для загрузки «grub-common:amd64» версии «2.04-1ubuntu26.15»
E: Невозможно найти источник для загрузки «libsmbclient:amd64» версии «2:4.13.17~dfsg-0ubuntu1.20.04.1»
E: Невозможно найти источник для загрузки «libwbclient0:amd64» версии «2:4.13.17~dfsg-0ubuntu1.20.04.1»
E: Невозможно найти источник для загрузки «samba-common:amd64» версии «2:4.13.17~dfsg-0ubuntu1.20.04.1»
E: Невозможно найти источник для загрузки «smbclient:amd64» версии «2:4.13.17~dfsg-0ubuntu1.20.04.1»
E: Невозможно найти источник для загрузки «libpam-modules-bin:amd64» версии «1.3.1-5ubuntu4.3»
E: Невозможно найти источник для загрузки «libpam-runtime:amd64» версии «1.3.1-5ubuntu4.3»
E: Невозможно найти источник для загрузки «libpam0g:amd64» версии «1.3.1-5ubuntu4.3»
E: Невозможно найти источник для загрузки «passwd:amd64» версии «1:4.8.1-1ubuntu5.20.04.2»
E: Невозможно найти источник для загрузки «ca-certificates:amd64» версии «20211016~20.04.1»
E: Невозможно найти источник для загрузки «libpython3.8-minimal:amd64» версии «3.8.10-0ubuntu1~20.04.5»
E: Невозможно найти источник для загрузки «libpython3.8-stdlib:amd64» версии «3.8.10-0ubuntu1~20.04.5»
E: Невозможно найти источник для загрузки «python3.8:amd64» версии «3.8.10-0ubuntu1~20.04.5»
E: Невозможно найти источник для загрузки «tzdata:amd64» версии «2022f-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «gir1.2-xapp-1.0:amd64» версии «2.2.8+una»
E: Невозможно найти источник для загрузки «libjpeg-turbo8:amd64» версии «2.0.3-0ubuntu1.20.04.1»
E: Невозможно найти источник для загрузки «libjpeg-turbo8:i386» версии «2.0.3-0ubuntu1.20.04.1»
E: Невозможно найти источник для загрузки «libtiff5:amd64» версии «4.1.0+git191117-2ubuntu0.20.04.4»
E: Невозможно найти источник для загрузки «libtiff5:i386» версии «4.1.0+git191117-2ubuntu0.20.04.4»
E: Невозможно найти источник для загрузки «python-apt-common:amd64» версии «2.0.0ubuntu0.20.04.8»
E: Невозможно найти источник для загрузки «python3-apt:amd64» версии «2.0.0ubuntu0.20.04.8»
E: Невозможно найти источник для загрузки «python3-urllib3:amd64» версии «1.25.8-2ubuntu0.1»
E: Невозможно найти источник для загрузки «isc-dhcp-client:amd64» версии «4.4.1-2.1ubuntu5.20.04.3»
E: Невозможно найти источник для загрузки «isc-dhcp-common:amd64» версии «4.4.1-2.1ubuntu5.20.04.3»
E: Невозможно найти источник для загрузки «sudo:amd64» версии «1.8.31-1ubuntu1.2»
E: Невозможно найти источник для загрузки «xxd:amd64» версии «2:8.1.2269-1ubuntu5.7»
E: Невозможно найти источник для загрузки «vim-common:amd64» версии «2:8.1.2269-1ubuntu5.7»
E: Невозможно найти источник для загрузки «vim-tiny:amd64» версии «2:8.1.2269-1ubuntu5.7»
E: Невозможно найти источник для загрузки «git-man:amd64» версии «1:2.25.1-1ubuntu3.5»
E: Невозможно найти источник для загрузки «git:amd64» версии «1:2.25.1-1ubuntu3.5»
E: Невозможно найти источник для загрузки «bind9-dnsutils:amd64» версии «1:9.16.1-0ubuntu2.10»
E: Невозможно найти источник для загрузки «bind9-host:amd64» версии «1:9.16.1-0ubuntu2.10»
E: Невозможно найти источник для загрузки «bind9-libs:amd64» версии «1:9.16.1-0ubuntu2.10»
E: Невозможно найти источник для загрузки «4kvideodownloader:amd64» версии «4.22-2»
E: Невозможно найти источник для загрузки «binutils-x86-64-linux-gnu:amd64» версии «2.34-6ubuntu1.3»
E: Невозможно найти источник для загрузки «libbinutils:amd64» версии «2.34-6ubuntu1.3»
E: Невозможно найти источник для загрузки «binutils-common:amd64» версии «2.34-6ubuntu1.3»
E: Невозможно найти источник для загрузки «binutils:amd64» версии «2.34-6ubuntu1.3»
E: Невозможно найти источник для загрузки «chromium:amd64» версии «105.0.5195.102~linuxmint1+una»
E: Невозможно найти источник для загрузки «corectrl:amd64» версии «1.3.0~git2209121851.910207e~f~mesarc16»
E: Невозможно найти источник для загрузки «curl:amd64» версии «7.68.0-1ubuntu2.13»
E: Невозможно найти источник для загрузки «firefox-locale-en:amd64» версии «104.0.2+linuxmint1+una»
E: Невозможно найти источник для загрузки «firefox-locale-ru:amd64» версии «104.0.2+linuxmint1+una»
E: Невозможно найти источник для загрузки «fwupd:amd64» версии «1.7.5-3~20.04.1»
E: Невозможно найти источник для загрузки «ghostscript:amd64» версии «9.50~dfsg-5ubuntu4.5»
E: Невозможно найти источник для загрузки «ghostscript-x:amd64» версии «9.50~dfsg-5ubuntu4.5»
E: Невозможно найти источник для загрузки «gir1.2-javascriptcoregtk-4.0:amd64» версии «2.36.7-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «gir1.2-webkit2-4.0:amd64» версии «2.36.7-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «grub2-common:amd64» версии «2.04-1ubuntu26.15»
E: Невозможно найти источник для загрузки «grub-pc:amd64» версии «2.04-1ubuntu26.15»
E: Невозможно найти источник для загрузки «grub-pc-bin:amd64» версии «2.04-1ubuntu26.15»
E: Невозможно найти источник для загрузки «krb5-locales:amd64» версии «1.17-6ubuntu4.1»
E: Невозможно найти источник для загрузки «libctf-nobfd0:amd64» версии «2.34-6ubuntu1.3»
E: Невозможно найти источник для загрузки «libctf0:amd64» версии «2.34-6ubuntu1.3»
E: Невозможно найти источник для загрузки «libcurl4:amd64» версии «7.68.0-1ubuntu2.13»
E: Невозможно найти источник для загрузки «libfprint-2-2:amd64» версии «1:1.90.2+tod1-0ubuntu1~20.04.8»
E: Невозможно найти источник для загрузки «libfwupd2:amd64» версии «1.7.5-3~20.04.1»
E: Невозможно найти источник для загрузки «libfwupdplugin5:amd64» версии «1.7.5-3~20.04.1»
E: Невозможно найти источник для загрузки «libgl1-mesa-dri:amd64» версии «22.2.0~rc3+git2208312110.f44745add97~f~mesarc1»
E: Невозможно найти источник для загрузки «libgl1-mesa-dri:i386» версии «22.2.0~rc3+git2208312110.f44745add97~f~mesarc1»
E: Невозможно найти источник для загрузки «libgl1-mesa-glx:amd64» версии «22.2.0~rc3+git2208312110.f44745add97~f~mesarc1»
E: Невозможно найти источник для загрузки «libgl1-mesa-glx:i386» версии «22.2.0~rc3+git2208312110.f44745add97~f~mesarc1»
E: Невозможно найти источник для загрузки «libglx-mesa0:i386» версии «22.2.0~rc3+git2208312110.f44745add97~f~mesarc1»
E: Невозможно найти источник для загрузки «libglx-mesa0:amd64» версии «22.2.0~rc3+git2208312110.f44745add97~f~mesarc1»
E: Невозможно найти источник для загрузки «libgs9:amd64» версии «9.50~dfsg-5ubuntu4.5»
E: Невозможно найти источник для загрузки «libgs9-common:amd64» версии «9.50~dfsg-5ubuntu4.5»
E: Невозможно найти источник для загрузки «libjavascriptcoregtk-4.0-18:amd64» версии «2.36.7-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libmysqlclient21:i386» версии «8.0.30-0ubuntu0.20.04.2»
E: Невозможно найти источник для загрузки «libmysqlclient21:amd64» версии «8.0.30-0ubuntu0.20.04.2»
E: Невозможно найти источник для загрузки «libnautilus-extension1a:amd64» версии «1:3.36.3-0ubuntu1.20.04.1»
E: Невозможно найти источник для загрузки «libnss-myhostname:amd64» версии «245.4-4ubuntu3.17»
E: Невозможно найти источник для загрузки «libnvidia-cfg1-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libnvidia-extra-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libnvidia-common-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libnvidia-compute-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libnvidia-compute-470:i386» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libnvidia-decode-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libnvidia-decode-470:i386» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libnvidia-encode-470:i386» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libnvidia-encode-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libnvidia-fbc1-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libnvidia-fbc1-470:i386» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libnvidia-gl-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libnvidia-gl-470:i386» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libnvidia-ifr1-470:i386» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libnvidia-ifr1-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libosmesa6:amd64» версии «22.2.0~rc3+git2208312110.f44745add97~f~mesarc1»
E: Невозможно найти источник для загрузки «libosmesa6:i386» версии «22.2.0~rc3+git2208312110.f44745add97~f~mesarc1»
E: Невозможно найти источник для загрузки «libpython3.8:amd64» версии «3.8.10-0ubuntu1~20.04.5»
E: Невозможно найти источник для загрузки «libpython3.8-dev:amd64» версии «3.8.10-0ubuntu1~20.04.5»
E: Невозможно найти источник для загрузки «libreoffice-java-common:amd64» версии «1:6.4.7-0ubuntu0.20.04.4»
E: Невозможно найти источник для загрузки «libunoil-java:amd64» версии «1:6.4.7-0ubuntu0.20.04.4»
E: Невозможно найти источник для загрузки «libreoffice-l10n-en-za:amd64» версии «1:6.4.7-0ubuntu0.20.04.4»
E: Невозможно найти источник для загрузки «libreoffice-sdbc-hsqldb:amd64» версии «1:6.4.7-0ubuntu0.20.04.4»
E: Невозможно найти источник для загрузки «libsnmp-base:amd64» версии «5.8+dfsg-2ubuntu2.5»
E: Невозможно найти источник для загрузки «libsnmp35:amd64» версии «5.8+dfsg-2ubuntu2.5»
E: Невозможно найти источник для загрузки «libsnmp35:i386» версии «5.8+dfsg-2ubuntu2.5»
E: Невозможно найти источник для загрузки «libwebkit2gtk-4.0-37:amd64» версии «2.36.7-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «libxatracker2:amd64» версии «22.2.0~rc3+git2208312110.f44745add97~f~mesarc1»
E: Невозможно найти источник для загрузки «lintian:amd64» версии «2.62.0ubuntu2.1»
E: Невозможно найти источник для загрузки «linux-firmware:amd64» версии «1.201.5»
E: Невозможно найти источник для загрузки «linux-headers-5.15.36-xanmod1:amd64» версии «5.15.36-xanmod1-0~git20220427.21e6525»
E: Невозможно найти источник для загрузки «linux-headers-5.17.12-xanmod1:amd64» версии «5.17.12-xanmod1-0~git20220530.22bcbb0»
E: Невозможно найти источник для загрузки «linux-headers-5.19.8-xanmod1:amd64» версии «5.19.8-xanmod1-0~20220908.git42d221f»
E: Невозможно найти источник для загрузки «linux-image-5.15.36-xanmod1:amd64» версии «5.15.36-xanmod1-0~git20220427.21e6525»
E: Невозможно найти источник для загрузки «linux-image-5.17.12-xanmod1:amd64» версии «5.17.12-xanmod1-0~git20220530.22bcbb0»
E: Невозможно найти источник для загрузки «linux-image-5.19.8-xanmod1:amd64» версии «5.19.8-xanmod1-0~20220908.git42d221f»
E: Невозможно найти источник для загрузки «linux-libc-dev:amd64» версии «5.4.0-125.141»
E: Невозможно найти источник для загрузки «linux-tools-generic:amd64» версии «5.4.0.125.126»
E: Невозможно найти источник для загрузки «linux-xanmod:amd64» версии «5.19.8-xanmod1-0»
E: Невозможно найти источник для загрузки «mesa-va-drivers:amd64» версии «22.2.0~rc3+git2208312110.f44745add97~f~mesarc1»
E: Невозможно найти источник для загрузки «mesa-va-drivers:i386» версии «22.2.0~rc3+git2208312110.f44745add97~f~mesarc1»
E: Невозможно найти источник для загрузки «mesa-vdpau-drivers:i386» версии «22.2.0~rc3+git2208312110.f44745add97~f~mesarc1»
E: Невозможно найти источник для загрузки «mesa-vdpau-drivers:amd64» версии «22.2.0~rc3+git2208312110.f44745add97~f~mesarc1»
E: Невозможно найти источник для загрузки «mesa-vulkan-drivers:i386» версии «22.2.0~rc3+git2208312110.f44745add97~f~mesarc1»
E: Невозможно найти источник для загрузки «mesa-vulkan-drivers:amd64» версии «22.2.0~rc3+git2208312110.f44745add97~f~mesarc1»
E: Невозможно найти источник для загрузки «nautilus-data:amd64» версии «1:3.36.3-0ubuntu1.20.04.1»
E: Невозможно найти источник для загрузки «nvidia-compute-utils-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «nvidia-dkms-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «nvidia-driver-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «nvidia-kernel-common-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «nvidia-kernel-source-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «nvidia-utils-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «openjdk-11-jre:amd64» версии «11.0.16+8-0ubuntu1~20.04»
E: Невозможно найти источник для загрузки «openjdk-11-jre-headless:amd64» версии «11.0.16+8-0ubuntu1~20.04»
E: Невозможно найти источник для загрузки «python-pip-whl:amd64» версии «20.0.2-5ubuntu1.6»
E: Невозможно найти источник для загрузки «python3-pil:amd64» версии «7.0.0-4ubuntu0.5»
E: Невозможно найти источник для загрузки «python3.8-venv:amd64» версии «3.8.10-0ubuntu1~20.04.5»
E: Невозможно найти источник для загрузки «python3-pip:amd64» версии «20.0.2-5ubuntu1.6»
E: Невозможно найти источник для загрузки «python3-samba:amd64» версии «2:4.13.17~dfsg-0ubuntu1.20.04.1»
E: Невозможно найти источник для загрузки «python3.8-dev:amd64» версии «3.8.10-0ubuntu1~20.04.5»
E: Невозможно найти источник для загрузки «samba-common-bin:amd64» версии «2:4.13.17~dfsg-0ubuntu1.20.04.1»
E: Невозможно найти источник для загрузки «samba-libs:amd64» версии «2:4.13.17~dfsg-0ubuntu1.20.04.1»
E: Невозможно найти источник для загрузки «thunderbird:amd64» версии «1:91.11.0+build2-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «thunderbird-gnome-support:amd64» версии «1:91.11.0+build2-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «thunderbird-locale-en:amd64» версии «1:91.11.0+build2-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «thunderbird-locale-en-us:amd64» версии «1:91.11.0+build2-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «thunderbird-locale-ru:amd64» версии «1:91.11.0+build2-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «warpinator:amd64» версии «1.2.9+una»
E: Невозможно найти источник для загрузки «whatsapp-desktop:amd64» версии «0.6.1»
E: Невозможно найти источник для загрузки «xserver-xephyr:amd64» версии «2:1.20.13-1ubuntu1~20.04.3»
E: Невозможно найти источник для загрузки «xserver-xorg-video-amdgpu:amd64» версии «22.0.0+git2208181249.4e011b9~f~mesarc0»
E: Невозможно найти источник для загрузки «xserver-xorg-video-nvidia-470:amd64» версии «470.141.03-0ubuntu0.20.04.1»
E: Невозможно найти источник для загрузки «xwayland:amd64» версии «2:1.20.13-1ubuntu1~20.04.3»
E: Невозможно найти источник для загрузки «timeshift:amd64» версии «21.09.1.1+una»
E: Невозможно найти источник для загрузки «xul-ext-lightning:amd64» версии «1:91.11.0+build2-0ubuntu0.20.04.1»
После распаковки 0 Б будет занято.
E: Внутренняя ошибка: не удалось создать список пакетов для скачивания
E: Возможно, список пакетов устарел, для начала выполните «aptitude update» или эквивалентную команду; в противном случае некоторые пакеты или некоторые версии не будут
Как решить вопрос?
Благодарил (а): 845 раз
27 янв 2023, 12:38
Я бы попробовал переустановить вместе с зависимостями и zlib и зависимый пакет.
попробуй с apt install --reinstall libglib2.0-0:i386 zlib1g:i386
или даже чуть драматичней, вынести их с apt remove, выписать все зависимости что утащит за собой и повторно установить всем скопом. Правда на список лучше сначала глянуть чтоб не вынес что-нибудь уберважного хотя бы для графической сессии. Тоже не фатально но чуть менее удобно без нее)
_Pokoi_ писал(а):
27 янв 2023, 01:11
Ну а тут все просто, пакеты в репозитории не живут вечно, изменилась версия и там уже вероятно лежит версия свежей чем указана в твоем списке.
Ну и в самом dist-upgrade обычно сакрального смысла нет в минте
_Pokoi_
Решено: 6
28 янв 2023, 01:31
27 янв 2023, 12:38
_Pokoi_ писал(а):
27 янв 2023, 01:11
Ну в общем касательно данной команды apt install --reinstall libglib2.0-0:i386 zlib1g:i386
получается следующее :
[sudo] пароль для ui:
libllvm12:i386 linux-headers-5.17.12-xanmod1 linux-image-5.17.12-xanmod1
Обновлено 0 пакетов, установлено 0 новых пакетов, переустановлено 4 пакетов, для удаления отмечено 0 пакетов, и 0 пакетов не обновлено.
Установлено или удалено не до конца 2 пакетов.
Необходимо скачать 2 757 kB архивов.
После данной операции объём занятого дискового пространства возрастёт на 0 B.
Пол:1 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 zlib1g amd64 1:1.2.11.dfsg-2ubuntu1.5 [54,2 kB]
Пол:2 http://archive.ubuntu.com/ubuntu focal-updates/main i386 zlib1g i386 1:1.2.11.dfsg-2ubuntu1.5 [57,0 kB]
Пол:3 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 libglib2.0-0 amd64 2.64.6-1~ubuntu20.04.4 [1 287 kB]
Пол:4 http://archive.ubuntu.com/ubuntu focal-updates/main i386 libglib2.0-0 i386 2.64.6-1~ubuntu20.04.4 [1 358 kB]
Получено 2 757 kB за 2с (1 350 kB/s)
(Чтение базы данных … на данный момент установлено 367176 файлов и каталогов.)
Подготовка к распаковке …/zlib1g_1%3a1.2.11.dfsg-2ubuntu1.5_amd64.deb …
Распаковывается zlib1g:amd64 (1:1.2.11.dfsg-2ubuntu1.5) на замену (1:1.2.11.dfsg-2ubuntu1.5) …
Подготовка к распаковке …/zlib1g_1%3a1.2.11.dfsg-2ubuntu1.5_i386.deb …
Распаковывается zlib1g:i386 (1:1.2.11.dfsg-2ubuntu1.5) на замену (1:1.2.11.dfsg-2ubuntu1.5) …
Настраивается пакет zlib1g:amd64 (1:1.2.11.dfsg-2ubuntu1.5) …
Подготовка к распаковке …/libglib2.0-0_2.64.6-1~ubuntu20.04.4_amd64.deb …...]
Распаковывается libglib2.0-0:amd64 (2.64.6-1~ubuntu20.04.4) на замену (2.64.6-1~ubuntu20.04.4) …
Подготовка к распаковке …/libglib2.0-0_2.64.6-1~ubuntu20.04.4_i386.deb …....]
Распаковывается libglib2.0-0:i386 (2.64.6-1~ubuntu20.04.4) на замену (2.64.6-1~ubuntu20.04.4) …
Настраивается пакет libglib2.0-0:amd64 (2.64.6-1~ubuntu20.04.4) …...........]
Настраивается пакет zlib1g:i386 (1:1.2.11.dfsg-2ubuntu1.5) …................]
Настраивается пакет nvidia-dkms-470 (470.161.03-0ubuntu0.20.04.1) ….........]
update-initramfs: deferring update (trigger activated)
INFO:Enable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
Removing old nvidia-470.161.03 DKMS files...
-------- Uninstall Beginning --------
Module: nvidia
Version: 470.161.03
Kernel: 5.19.8-xanmod1 (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
nvidia.ko:
- Uninstallation
- Deleting from: /lib/modules/5.19.8-xanmod1/kernel/drivers/char/drm/
- Original module
- No original module was found for this module on this kernel.
- Use the dkms install command to reinstall any previous module version.
nvidia-modeset.ko:
- Uninstallation
- Original module
nvidia-drm.ko:
- Uninstallation
- Original module
nvidia-uvm.ko:
- Uninstallation
- Original module
nvidia-peermem.ko:
- Uninstallation
- Original module
depmod............
DKMS: uninstall completed.
Deleting module version: 470.161.03
completely from the DKMS tree.
Done.
Loading new nvidia-470.161.03 DKMS files...
Building for 6.1.8-x64v1-xanmod1
Building for architecture x86_64
Building initial module for 6.1.8-x64v1-xanmod1
Error! Bad return status for module build on kernel: 6.1.8-x64v1-xanmod1 (x86_64)
Consult /var/lib/dkms/nvidia/470.161.03/build/make.log for more information.
dpkg: ошибка при обработке пакета nvidia-dkms-470 (--configure):
installed nvidia-dkms-470 package post-installation script subprocess returned error exit status 10
dpkg: зависимости пакетов не позволяют настроить пакет nvidia-driver-470:
nvidia-driver-470 зависит от nvidia-dkms-470 (<= 470.161.03-1), однако:
Пакет nvidia-dkms-470 пока не настроен.
nvidia-driver-470 зависит от nvidia-dkms-470 (>= 470.161.03), однако:
dpkg: ошибка при обработке пакета nvidia-driver-470 (--configure):
проблемы зависимостей — оставляем не настроенным
Настраивается пакет libglib2.0-0:i386 (2.64.6-1~ubuntu20.04.4) …
Обрабатываются триггеры для libc-bin (2.31-0ubuntu9.9) …
Обрабатываются триггеры для initramfs-tools (0.136ubuntu6.7) …
update-initramfs: Generating /boot/initrd.img-6.1.8-x64v1-xanmod1
W: Possible missing firmware /lib/firmware/i915/dg1_huc.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_huc.bin for module i915
W: Possible missing firmware /lib/firmware/i915/skl_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/bxt_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/kbl_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/glk_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/cml_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/icl_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/ehl_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/dg1_guc_70.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_guc_69.0.3.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_guc_70.bin for module i915
W: Possible missing firmware /lib/firmware/i915/adlp_guc_69.0.3.bin for module i915
W: Possible missing firmware /lib/firmware/i915/adlp_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/adlp_guc_70.bin for module i915
W: Possible missing firmware /lib/firmware/i915/dg2_guc_70.bin for module i915
W: Possible missing firmware /lib/firmware/i915/adlp_dmc_ver2_16.bin for module i915
W: Possible missing firmware /lib/firmware/i915/dg2_dmc_ver2_07.bin for module i915
nvidia-dkms-470
nvidia-driver-470
Далее сделал sudo apt dist-upgrade
libllvm12:i386 linux-headers-5.17.12-xanmod1 linux-image-5.17.12-xanmod1 linux-tools-5.4.0-125 linux-tools-5.4.0-125-generic
Обновлено 0 пакетов, установлено 0 новых пакетов, для удаления отмечено 0 пакетов, и 0 пакетов не обновлено.
INFO:Enable nvidia
Done.
nvidia-dkms-470
nvidia-driver-470
28 янв 2023, 07:57
_Pokoi_ писал(а):
28 янв 2023, 01:31
6.1.8-x64v1-xanmod1
А тут дрова немолодой нвидии не хотят твое кастомное ядро распоследних версий. dkms валится на сборке модуля
Нафига здесь xanmod-6.1 на skylake?
Если очень уж хочется новья - лучше юзать не LTS дистрибутивы, чтоб не таскать основные системные компоненты с улицы и удвляться что ось разъехалась :tux:
_Pokoi_
Решено: 6
28 янв 2023, 15:11
28 янв 2023, 07:57
_Pokoi_ писал(а):
28 янв 2023, 01:31
6.1.8-x64v1-xanmod1
Мне даунгреднуть xanmod ?или просто стандартное ядро установить минтовское ?
28 янв 2023, 21:58
Разумеется лучше довести до ума на компонентах базовой поставки, а затем при наличиии обоснованной необходимости заносить кастом, вдумчиво и последовательно)
Вернуться в «Xfce»
