Как поменять цвет рамки окна с белого на черный в XFCE?
_Pokoi_
Решено: 6
Благодарил (а): 9 раз
25 янв 2023, 21:21
Как поменять цвет рамки она с белого на черный в XFCE?
inxi -Fxz:
Kernel: 5.19.8-xanmod1 x86_64 bits: 64 compiler: N/A Desktop: Gnome 3.36.9
Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Type: Laptop System: Acer product: Extensa 2520G v: V1.15 serial: <filter>
Mobo: Acer model: BA50_SL v: V1.15 serial: <filter> UEFI [Legacy]: Insyde
v: 1.15 date: 05/13/2016
ID-1: BAT1 charge: 29.7 Wh condition: 29.7/37.0 Wh (80%)
model: SANYO AL15A32 status: Full
Topology: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP
arch: Skylake rev: 3 L2 cache: 3072 KiB
bogomips: 38400
Speed: 800 MHz min/max: 400/2301 MHz Core speeds (MHz): 1: 833 2: 1477
3: 1019 4: 995
Device-1: Intel Skylake GT2 [HD Graphics 520]
Device-2: NVIDIA GK208BM [GeForce 920M] vendor: Acer Incorporated ALI
driver: nvidia v: 470.141.03 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.13 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa resolution: 1366x768~60Hz
OpenGL: renderer: NVIDIA GeForce 920M/PCIe/SSE2 v: 4.6.0 NVIDIA 470.141.03
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Acer Incorporated ALI
Sound Server: ALSA v: k5.19.8-xanmod1
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus ID: 02:00.0
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel port: 3000 bus ID: 03:00.0
Device-3: Lite-On Qualcomm Atheros Bluetooth type: USB driver: btusb
bus ID: 1-5:6
Local Storage: total: 465.76 GiB used: 125.86 GiB (27.0%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB
ID-1: / size: 456.88 GiB used: 125.86 GiB (27.5%) fs: ext4 dev: /dev/sda5
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 48 C
Processes: 247 Uptime: 49m Memory: 7.64 GiB used: 3.32 GiB (43.4%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
Решение Gelo7 » 25 янв 2023, 21:32
_Pokoi_ писал(а):
25 янв 2023, 21:21
В диспетчере окон выбрать стиль который понравится.
Gelo7
Благодарил (а): 3 раза
25 янв 2023, 21:32
_Pokoi_ писал(а):
25 янв 2023, 21:21
Вернуться в «Xfce»
