После upgrade Mint 19.3 x64 до Mint 20 x64 пропал звук.
pacmd list-sinks
* index: 0
driver: <module-null-sink.c>
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1000
volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 0,00 ms
max request: 344 KiB
max rewind: 344 KiB
monitor source: 0
sample spec: s16le 2-канальный 4410
channel map: front-left,front-right
Стерео
used by: 0
linked by: 0
configured latency: 0,00 ms; range is 0,50 .. 2000,00 ms
module: 11
properties:
device.description = "Фиктивный выход"
device.class = "abstract"
device.icon_name = "audio-card"
Спасибо)
