Дублирование значков в системном трее
volp
09 янв 2023, 10:23
Добрый день.
Kernel: 5.15.0-57-generic x86_64 bits: 64 compiler: N/A
Desktop: MATE 1.26.0 Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Type: Desktop Mobo: KLLISRE model: X79 v: V1.2 serial: <filter>
UEFI: American Megatrends v: 4.6.5 date: 11/15/2021
Topology: 8-Core model: Intel Xeon E5-2650L 0 bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 L2 cache: 20.0 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57596
Speed: 1309 MHz min/max: 1200/2300 MHz Core speeds (MHz): 1: 1203 2: 1310
3: 1200 4: 1207 5: 1217 6: 1200 7: 1200 8: 1200 9: 1200 10: 1248 11: 1385
12: 1200 13: 1200 14: 1215 15: 1200 16: 1200
Device-1: AMD RV730 XT [Radeon HD 4670] vendor: Micro-Star MSI
driver: radeon v: kernel bus ID: 03:00.0
Display: x11 server: X.Org 1.20.13 driver: ati,radeon
unloaded: fbdev,modesetting,vesa tty: N/A
OpenGL: renderer: AMD RV730 (DRM 2.50.0 / 5.15.0-57-generic LLVM 12.0.0)
v: 3.3 Mesa 21.2.6 direct render: Yes
Device-1: Intel C600/X79 series High Definition Audio
Device-2: AMD RV710/730 HDMI Audio [Radeon HD 4000 series]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 03:00.1
Sound Server: ALSA v: k5.15.0-57-generic
driver: r8169 v: kernel port: d000 bus ID: 07:00.0
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
IF-ID-2: virbr0-nic state: down mac: <filter>
Local Storage: total: 816.03 GiB used: 360.86 GiB (44.2%)
ID-1: /dev/nvme0n1 model: KLLISRE 256GB size: 238.47 GiB
ID-2: /dev/sda vendor: Western Digital model: WD5000AAKX-001CA0
ID-3: /dev/sdb model: KSQ120 size: 111.79 GiB
ID-1: / size: 50.99 GiB used: 24.24 GiB (47.5%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /home size: 182.28 GiB used: 48.08 GiB (26.4%) fs: ext4
dev: /dev/nvme0n1p3
System Temperatures: cpu: 127.5 C mobo: N/A gpu: radeon temp: 39 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1498 fan-3: 0 fan-4: 0 fan-5: 0
Voltages: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 3.30
Processes: 351 Uptime: 19m Memory: 15.56 GiB used: 2.29 GiB (14.7%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
Иногда при запуске системы , в системном трее дублируются значки сети и звука
Иногда только звука. Закономерности я не выявил. На работу не влияет, но нервирует. Можно это пофиксить ?
yarichin
09 янв 2023, 10:28
volp писал(а):
09 янв 2023, 10:23
Аналогично. Просто плюнул.
Сотрудник
09 янв 2023, 13:33
volp, Надо завершить сеанс пользователя, потом снова зайти в профиль пользователя. Ещё помогает перезагрузка ОС.
sheridan
Решено: 14
Благодарил (а): 900 раз
09 янв 2023, 13:39
Сотрудник, Я думаю что TS это знает :smile:
13 янв 2023, 15:00
А они находятся в одной секции? Если провести курсором...не проявятся ли другие?
volp
13 янв 2023, 16:16
Dja, Нет, не проявляются другие при проведении курсором, находятся в одной секции . можете сравнить с нормальным видом ( кстати вот уже пару дней этот глюк не проявлялся)
demonlibra
Благодарил (а): 29 раз
13 янв 2023, 17:27
Если нажать Ctrl + Alt + Esc
Контекстное меню Nemo
abulaev2008
Благодарил (а): 24 раза
13 янв 2023, 20:57
где то в настройках стоит лишняя галочка
abulaev2008
13 янв 2023, 21:01
программа включена(запущена)?
volp
13 янв 2023, 21:04
demonlibra писал(а):
13 янв 2023, 17:27
также и как после ребута - может нормально трей загрузиться, а может и с дублированием сети и звука.
abulaev2008
13 янв 2023, 21:05
И где-то есть галка: показывать в системном трее.
Как завершаешь программу - пропадает?
volp
13 янв 2023, 21:09
abulaev2008 писал(а):
13 янв 2023, 21:01
Вроде по русски писал - системный трей , индикаторы звука и сети. Какая программа ?
Вернуться в «Mate»
