Странная работа WOL
Странная работа WOL
07 янв 2023, 16:49
Какая-то содомия происходит с Wake On Lan...
Какбе всё хорошо:
Settings for enp2s0:
	Supported ports: [ TP	 MII ]
	Supported link modes:   10baseT/Half 10baseT/Full
	                        100baseT/Half 100baseT/Full
	                        1000baseT/Full
	Supported pause frame use: Symmetric Receive-only
	Supports auto-negotiation: Yes
	Supported FEC modes: Not reported
	Advertised link modes:  10baseT/Half 10baseT/Full
	                        1000baseT/Full
	Advertised pause frame use: Symmetric Receive-only
	Advertised auto-negotiation: Yes
	Advertised FEC modes: Not reported
	Link partner advertised link modes:  10baseT/Half 10baseT/Full
	                                     1000baseT/Full
	Link partner advertised pause frame use: Symmetric
	Link partner advertised auto-negotiation: Yes
	Link partner advertised FEC modes: Not reported
	Speed: 1000Mb/s
	Duplex: Full
	Auto-negotiation: on
	master-slave cfg: preferred slave
	master-slave status: slave
	Port: Twisted Pair
	PHYAD: 0
	Transceiver: external
	MDI-X: Unknown
	Supports Wake-on: pumbg
	Wake-on: g
	Link detected: yes
Но работает оч интересно. Если послать магический пакет, комп не не включается. А вот если отправить его в жущий режим, пробудить магическим пакетом, а потом выключить, то после этих действий срабатывает.
Подопытный:
  Kernel: 5.15.0-57-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
    Desktop: GNOME 42.5 Distro: Ubuntu 22.04.1 LTS (Jammy Jellyfish)
  Type: Desktop Mobo: AIO model: H87H3-TI v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: 4.6.5 date: 07/01/2014
  Info: dual core model: Intel Core i3-4370T bits: 64 type: MT MCP
    arch: Haswell rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 4 MiB
  Speed (MHz): avg: 2176 high: 2395 min/max: 800/3300 cores: 1: 2395
    2: 2390 3: 2395 4: 1525 bogomips: 26339
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
    vendor: Elite Systems driver: i915 v: kernel bus-ID: 00:02.0
  Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
    unloaded: fbdev,vesa gpu: i915 resolution: 2560x1440~60Hz
  OpenGL: renderer: Mesa Intel HD Graphics 4600 (HSW GT2)
    v: 4.6 Mesa 22.0.5 direct render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    vendor: Elite Systems driver: snd_hda_intel v: kernel bus-ID: 00:03.0
  Device-2: Intel 8 Series/C220 Series High Definition Audio
    vendor: Elite Systems driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  Sound Server-1: ALSA v: k5.15.0-57-generic running: yes
    vendor: Elite Systems driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 223.57 GiB used: 63.89 GiB (28.6%)
  ID-1: /dev/sda vendor: Western Digital model: WDS240G1G0B-00RC30
  ID-1: / size: 93.13 GiB used: 62.98 GiB (67.6%) fs: btrfs dev: /dev/sda2
  ID-2: /boot/efi size: 284.4 MiB used: 5.2 MiB (1.8%) fs: vfat
    dev: /dev/sda1
  ID-3: /home size: 93.13 GiB used: 62.98 GiB (67.6%) fs: btrfs
    dev: /dev/sda2
Swap:
  ID-1: swap-1 type: partition size: 9.09 GiB used: 0 KiB (0.0%)
    dev: /dev/sda3
  System Temperatures: cpu: 29.8 C mobo: 27.8 C
  Processes: 252 Uptime: 8m Memory: 7.19 GiB used: 2.24 GiB (31.1%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2270 Shell: Zsh
  v: 5.8.1 inxi: 3.3.13
Странная работа WOL
07 янв 2023, 17:36
di_mok писал(а):
07 янв 2023, 16:49
Думал, у меня одного такая "дурость" имеет место или я вообще полный нуб.
Странная работа WOL
07 янв 2023, 17:43
От кривизны рук программистов конкретной прошивки зависит. Я разного навидался. Это еще не самое странное что может быть.
il180
Благодарил (а): 6 раз
Странная работа WOL
08 янв 2023, 02:13
Прошу простить мою серость и невежество), но я всегда думал, что WOL никак не завязан с ОС...
Странная работа WOL
08 янв 2023, 05:03
il180 писал(а):
08 янв 2023, 02:13
Непосредственно - не завязан. Но косвенно OS влиять может, т.к. у нее есть доступ к некоторым настройкам современных прошивок. В том числе и регистрам хранящим состояния "выключения". В кавычках, т.к. со времен появления ATX, материнки уже не полностью выключаются и обесточиваются (если из розетки не выдернуть, или переключателем на самом БП не щелкнуть). Какие-то части их постоянно запитаны и работают. Просто очень экономично - как электронные часы в розетку воткнутые. И вот что и как там будет работать, а что не будет в таком состоянии - контролируется настройками BIOS/UEFI, а так же может быть в некоторых пределах задано со стороны OS, пока машина нормально работает.
Странная работа WOL
08 янв 2023, 18:17
Похоже, в моём случае проще всего будет отправлять в ждучку
Странная работа WOL
09 янв 2023, 19:45
Да ну их на фиг...
И ни каких магических пакетов [Побёг рыться в коробочках на шкафу]
Странная работа WOL
09 янв 2023, 20:49
di_mok, :thumbs: наш подход
Странная работа WOL
13 янв 2023, 14:55
di_mok, а кто это?
Странная работа WOL
13 янв 2023, 17:47
Это ESP8266 В двух словах - микроконтроллер с WiFi. Их любят все мамкины самоделкины для всякого рода контроля и автоматизации. Умный дом например
Странная работа WOL
14 янв 2023, 12:46
di_mok, то бишь будет тот же wol, но на другой интерфейс?
Странная работа WOL
14 янв 2023, 13:02
Нееее. Просто контроллер будет замыкать кнопку включения питания компьютера. Вот первый попавшийся пример http://psenyukov.ru/%D0%B2%D0%BA%D0%BB% ... %BC%D0%BE/
Странная работа WOL
14 янв 2023, 13:20
ух!!! Это не магический пакет. di_mok, Это целая магия!!!
Жаль для ноута так не сделаешь )
Странная работа WOL
14 янв 2023, 13:31
Dja писал(а):
14 янв 2023, 13:20
Это целая магия!!!
Шикарная штука. Я их дома везде напихал. Например, я не поднимая царственную задницу с дивана ору "Алиса, включи чайник", и иду на кухню после того как она скажет, что чайник вскипел))) Так же с освещением и телевизором
Странная работа WOL
14 янв 2023, 14:40
Я вот задумался... А как быть желающим устроить подобную систему, если у них уже есть жена или дочка с таким именем? Предусмотрена ли замена, или "Алиса" там намертво прошито в базах нейросетки во время обучения?..
У англоязычных первопроходцев данного направления с этим проще - ни Google, ни Siri с Cortana не являются достаточно распространенными реальными именами... :)
Странная работа WOL
14 янв 2023, 15:02
14 янв 2023, 14:40
Если ещё добавят и самообучаемость, то потом могут возникнуть проблемы. "Алиса, включи чайник!". А электронный девайс в ответ и послал ‒ обучился от домашних ... :-D
 ! Сообщение из: Dja
причем послал сам чайник :crazy: :magic:
Странная работа WOL
14 янв 2023, 15:58
14 янв 2023, 14:40
Там два варианта: Алиса или Яндекс
madesta писал(а):
14 янв 2023, 15:02
Ну это не проблема. У меня ЯС подвязаны к Home Assistant, который может заставить Алису проговаривать любые тексты. Например, когда у меня заряд мобильника ниже 20% и я нахожусь дома Алиса орёт, чтобы я поставил телефон на зарядку
Странная работа WOL
14 янв 2023, 19:26
di_mok писал(а):
14 янв 2023, 15:58
...в недалеком будущем...
Голос Алисы: di_mok, я поставила твой смарт на зарядку, постирала белье, повесила сушиться, вынесла мусор... :ku:
SHERI_FFF
Благодарил (а): 33 раза
Странная работа WOL
14 янв 2023, 20:06
Dja писал(а):
14 янв 2023, 19:26
А на хрена мне жена?
________________________
Команды могу только копировать :hoho:
Ноутбук Acer Aspire 5 с Manjaro inxi -Fxz
ПК с Manjaro inxi -Fxz
Странная работа WOL
14 янв 2023, 20:19
Dja писал(а):
14 янв 2023, 19:26
Голос Алисы: di_mok
Она меня Димочкой называет :blush:
SHERI_FFF писал(а):
14 янв 2023, 20:06
Ну... Какбе... Это... :blush:
