VERSION="21.1 (Vera)"
железо:
$ inxi -Fxz
Kernel: 5.15.0-56-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: KDE Plasma 5.24.7 Distro: Linux Mint 21.1 Vera
base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP Laptop 15s-eq1xxx v: N/A
serial: <superuser required>
Mobo: HP model: 8706 v: 99.42 serial: <superuser required> UEFI: AMI
v: F.53 date: 10/15/2021
ID-1: BAT0 charge: 41.7 Wh (100.0%) condition: 41.7/41.7 Wh (100.0%)
volts: 12.7 min: 11.3 model: Hewlett-Packard Primary status: Full
Info: dual core model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 192 KiB
L2: 1024 KiB L3: 4 MiB
Speed (MHz): avg: 2716 high: 2719 min/max: 1400/2600 boost: enabled
cores: 1: 2716 2: 2712 3: 2719 4: 2718 bogomips: 20761
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 04:00.0
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5.2:6
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon Vega 3 Graphics (raven2 LLVM 13.0.1 DRM 3.42
5.15.0-56-generic)
v: 4.6 Mesa 22.0.5 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.1
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.6
Sound Server-1: ALSA v: k5.15.0-56-generic running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: f000
bus-ID: 02:00.0
Bluetooth:
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-4:4
Report: hciconfig ID: hci0 rfk-id: 3 state: up address: <filter>
bt-v: 2.1 lmp-v: 4.2
Local Storage: total: 238.47 GiB used: 117.06 GiB (49.1%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC711 HFM256GD3JX013N
size: 238.47 GiB temp: 26.9 C
ID-1: / size: 29.36 GiB used: 19.13 GiB (65.2%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.8 MiB used: 6.1 MiB (2.0%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 195.98 GiB used: 97.34 GiB (49.7%) fs: ext4
dev: /dev/nvme0n1p4
Swap:
ID-1: swap-1 type: partition size: 8 GiB used: 601.8 MiB (7.3%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 55.0 C mobo: N/A gpu: amdgpu temp: 69.0 C
Processes: 246 Uptime: 15h 51m Memory: 5.71 GiB used: 2.72 GiB (47.7%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 3146 Shell: Bash
v: 5.1.16 inxi: 3.3.13
bus-ID: 1-5.2:6
5.15.0-56-generic)
bus-ID: 02:00.0
Bluetooth:
bus-ID: 1-4:4
dev: /dev/nvme0n1p2
dev: /dev/nvme0n1p1
dev: /dev/nvme0n1p4
Swap:
dev: /dev/nvme0n1p3
W: http://ppa.launchpad.net/atareao/atareao/ubuntu/dists/jammy/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
W: http://ppa.launchpad.net/cinelerra-ppa/ppa/ubuntu/dists/jammy/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
W: http://ppa.launchpad.net/kubuntu-ppa/backports/ubuntu/dists/jammy/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
W: http://ppa.launchpad.net/nrbrtx/xorg-hotkeys/ubuntu/dists/jammy/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
Посоветуйте, как выйти из ситуации?
