Система не видит видеокарту ноутбука.
vik_rock
23 дек 2022, 21:19
Доброго времени суток. LM 21.1 x64. Не получается установить драйвер видеокарты.
Система не видит видеокарту ноутбука 1650TI.
Kernel: 5.15.0-56-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: Cinnamon 5.6.5 Distro: Linux Mint 21.1 Vera
base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec2xxx v: N/A
serial: <superuser required>
Mobo: HP model: 88DD v: 96.31 serial: <superuser required> UEFI: AMI
v: F.15 date: 08/18/2021
ID-1: BAT0 charge: 45.1 Wh (99.8%) condition: 45.2/45.2 Wh (100.0%)
volts: 12.5 min: 11.6 model: HP Primary status: N/A
Info: 6-core model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 2905 high: 3511 min/max: 400/4280 boost: enabled cores:
1: 3263 2: 3263 3: 2681 4: 2816 5: 2615 6: 2738 7: 2615 8: 2630 9: 3511
10: 3464 11: 2618 12: 2656 bogomips: 79050
Device-1: NVIDIA TU117M vendor: Hewlett-Packard driver: nouveau v: kernel
bus-ID: 01:00.0
Device-2: AMD Cezanne vendor: Hewlett-Packard driver: amdgpu v: kernel
bus-ID: 05:00.0
Device-3: Luxvisions Innotech HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 3-3:3
Display: x11 server: X.Org v: 1.21.1.3 driver: X:
loaded: amdgpu,ati,modesetting unloaded: fbdev,vesa gpu: amdgpu
resolution: 1920x1080~144Hz
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.42 5.15.0-56-generic)
v: 4.6 Mesa 22.0.5 direct render: Yes
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
vendor: Hewlett-Packard driver: N/A bus-ID: 05:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 05:00.6
Sound Server-1: ALSA v: k5.15.0-56-generic running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
IF: eno1 state: down mac: <filter>
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_8852ae v: N/A port: d000
bus-ID: 03:00.0
Bluetooth:
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:2
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter>
bt-v: 3.0 lmp-v: 5.2
Local Storage: total: 476.94 GiB used: 206.53 GiB (43.3%)
ID-1: /dev/nvme0n1 vendor: Kingston model: OM8SBP3512K-AH
size: 476.94 GiB temp: 33.9 C
ID-1: / size: 467.89 GiB used: 206.49 GiB (44.1%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 46.4 MiB (9.1%) fs: vfat
dev: /dev/nvme0n1p1
Swap:
System Temperatures: cpu: 54.0 C mobo: N/A
GPU: device: nouveau temp: 45.0 C device: amdgpu temp: 53.0 C
Processes: 356 Uptime: 35m Memory: 14.98 GiB used: 3.07 GiB (20.5%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2679 Shell: Bash
v: 5.1.16 inxi: 3.3.13
lspci |grep -E "VGA|3D"
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M (rev a1)
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne (rev c6)
Пробовал разные версии драйвера и ядра 5.4, 5.8 . Стоковый работает, а nvidia нет.
23 дек 2022, 21:37
vik_rock писал(а):
23 дек 2022, 21:19
Вот твоя карта nvidia
vik_rock
23 дек 2022, 22:01
По другим форумам искал, там прям модель отображалась.
Драйвер то наверное для неё только на ядре 5 будет работать?
23 дек 2022, 22:37
vik_rock писал(а):
23 дек 2022, 22:01
Так у тебя и так
vik_rock писал(а):
23 дек 2022, 21:19
Драйвер у тебя используется
vik_rock писал(а):
23 дек 2022, 21:19
nouveau
У тебя тут гибрид со встройкой от красных и дискреткой от зеленых.
Драйвер на дискретку мы поставить сможем, но вот будет ли работать переключение хз.
Для установки драйвера
sudo apt install nvidia-driver-525 nvidia-dkms-525
vik_rock
23 дек 2022, 23:08
Спасибо, добрый человек. Драйвер установился, второй монитор включился. Nvidia-settings работает. Переключения нету, но это уже совсем другая история (требующая нервов).
Speed (MHz): avg: 2966 high: 3302 min/max: 400/4280 boost: enabled cores:
1: 3076 2: 2705 3: 2955 4: 3268 5: 2614 6: 2649 7: 3267 8: 3268 9: 2614
10: 2616 11: 3302 12: 3269 bogomips: 79050
Device-1: NVIDIA TU117M vendor: Hewlett-Packard driver: nvidia v: 525.60.13
bus-ID: 01:00.0
bus-ID: 05:00.0
loaded: amdgpu,ati,nvidia unloaded: fbdev,modesetting,vesa gpu: amdgpu
resolution: 1: 1920x1080~60Hz 2: 1920x1080~144Hz
bus-ID: 01:00.1
bus-ID: 03:00.0
Bluetooth:
bus-ID: 1-4:2
Local Storage: total: 476.94 GiB used: 227.22 GiB (47.6%)
size: 476.94 GiB temp: 35.9 C
ID-1: / size: 467.89 GiB used: 227.17 GiB (48.6%) fs: ext4
dev: /dev/nvme0n1p2
dev: /dev/nvme0n1p1
Swap:
System Temperatures: cpu: 56.0 C mobo: N/A gpu: amdgpu temp: 47.0 C
Processes: 366 Uptime: 4m Memory: 14.98 GiB used: 2.39 GiB (15.9%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2711 Shell: Bash
Вернуться в «Видеокарты»
