Как избавиться от Cinnamona?
1o4ka
Благодарил (а): 23 раза
22 ноя 2022, 16:02
LM 21x64
Cinnamon, KDE
Модель ноутбука: HP Laptop 15s-eq 1426ur.
Железо:
$ inxi -Fxz
Kernel: 5.15.0-53-generic x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: KDE Plasma 5.24.7 Distro: Linux Mint 21 Vanessa
base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP Laptop 15s-eq1xxx v: N/A
serial: <superuser required>
Mobo: HP model: 8706 v: 99.42 serial: <superuser required> UEFI: AMI
v: F.53 date: 10/15/2021
ID-1: BAT0 charge: 41.7 Wh (100.0%) condition: 41.7/41.7 Wh (100.0%)
volts: 12.1 min: 11.3 model: Hewlett-Packard Primary status: Full
Info: dual core model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 192 KiB
L2: 1024 KiB L3: 4 MiB
Speed (MHz): avg: 1762 high: 2361 min/max: 1400/2600 boost: enabled
cores: 1: 2270 2: 2361 3: 1208 4: 1212 bogomips: 20760
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 04:00.0
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5.2:5
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon Vega 3 Graphics (raven2 LLVM 13.0.1 DRM 3.42
5.15.0-53-generic)
v: 4.6 Mesa 22.0.5 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.1
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.6
Sound Server-1: ALSA v: k5.15.0-53-generic running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: f000
bus-ID: 02:00.0
Bluetooth:
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-4:3
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter>
bt-v: 2.1 lmp-v: 4.2
Local Storage: total: 238.47 GiB used: 69.17 GiB (29.0%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC711 HFM256GD3JX013N
size: 238.47 GiB temp: 25.9 C
ID-1: / size: 29.36 GiB used: 15.83 GiB (53.9%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.8 MiB used: 6.1 MiB (2.0%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 195.98 GiB used: 53.34 GiB (27.2%) fs: ext4
dev: /dev/nvme0n1p4
Swap:
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 63.0 C
Processes: 247 Uptime: 5m Memory: 5.71 GiB used: 1.96 GiB (34.3%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2809 Shell: Bash
v: 5.1.16 inxi: 3.3.13
На ноутбуке установлены две DE: Cinnamon и KDE.
Вопрос: Как избавиться от Cinnamona малой кровью, либо вообще без потерь?
Помогите, плз.
Решение sheridan » 22 ноя 2022, 16:10
загрузится в DE KDE
sudo apt purge cinnamon
sudo apt autoremove
sudo reboot
...bis dat qui cito dat
sheridan
Решено: 14
Благодарил (а): 900 раз
22 ноя 2022, 16:10
загрузится в DE KDE
sudo apt autoremove
sudo reboot
1o4ka
22 ноя 2022, 16:31
Так просто. Всё. Спасибо. Вопрос закрыт.
Благодарил (а): 794 раза
22 ноя 2022, 16:32
:close:
