Нет звука. Нет аналогового выхода
ZaMosvkorechye
02 ноя 2022, 15:18
День добрый! Вот такая история с моим ноутбуком и Linux Mint 21 из коробки:
Вроде бы звуковая карта имеется
$ lspci
00:00.0 Host bridge: Intel Corporation Device 9a04 (rev 01)
00:02.0 VGA compatible controller: Intel Corporation Device 9a78 (rev 01)
00:04.0 Signal processing controller: Intel Corporation TigerLake-LP Dynamic Tuning Processor Participant (rev 01)
00:07.0 PCI bridge: Intel Corporation Tiger Lake-LP Thunderbolt 4 PCI Express Root Port #0 (rev 01)
00:07.1 PCI bridge: Intel Corporation Tiger Lake-LP Thunderbolt 4 PCI Express Root Port #1 (rev 01)
00:07.2 PCI bridge: Intel Corporation Tiger Lake-LP Thunderbolt 4 PCI Express Root Port #2 (rev 01)
00:07.3 PCI bridge: Intel Corporation Tiger Lake-LP Thunderbolt 4 PCI Express Root Port #3 (rev 01)
00:08.0 System peripheral: Intel Corporation GNA Scoring Accelerator module (rev 01)
00:0a.0 Signal processing controller: Intel Corporation Tigerlake Telemetry Aggregator Driver (rev 01)
00:0d.0 USB controller: Intel Corporation Tiger Lake-LP Thunderbolt 4 USB Controller (rev 01)
00:0d.2 USB controller: Intel Corporation Tiger Lake-LP Thunderbolt 4 NHI #0 (rev 01)
00:0d.3 USB controller: Intel Corporation Tiger Lake-LP Thunderbolt 4 NHI #1 (rev 01)
00:14.0 USB controller: Intel Corporation Tiger Lake-LP USB 3.2 Gen 2x1 xHCI Host Controller (rev 20)
00:14.2 RAM memory: Intel Corporation Tiger Lake-LP Shared SRAM (rev 20)
00:14.3 Network controller: Intel Corporation Wi-Fi 6 AX201 (rev 20)
00:15.0 Serial bus controller: Intel Corporation Tiger Lake-LP Serial IO I2C Controller #0 (rev 20)
00:15.1 Serial bus controller: Intel Corporation Tiger Lake-LP Serial IO I2C Controller #1 (rev 20)
00:15.2 Serial bus controller: Intel Corporation Tiger Lake-LP Serial IO I2C Controller #2 (rev 20)
00:15.3 Serial bus controller: Intel Corporation Tiger Lake-LP Serial IO I2C Controller #3 (rev 20)
00:16.0 Communication controller: Intel Corporation Tiger Lake-LP Management Engine Interface (rev 20)
00:17.0 SATA controller: Intel Corporation Device a0d3 (rev 20)
00:19.0 Serial bus controller: Intel Corporation Tiger Lake-LP Serial IO I2C Controller #4 (rev 20)
00:19.1 Serial bus controller: Intel Corporation Tiger Lake-LP Serial IO I2C Controller #5 (rev 20)
00:1c.0 PCI bridge: Intel Corporation Device a0bc (rev 20)
00:1e.0 Communication controller: Intel Corporation Tiger Lake-LP Serial IO UART Controller #0 (rev 20)
00:1e.3 Serial bus controller: Intel Corporation Tiger Lake-LP Serial IO SPI Controller #1 (rev 20)
00:1f.0 ISA bridge: Intel Corporation Tiger Lake-LP LPC Controller (rev 20)
00:1f.3 Multimedia audio controller: Intel Corporation Tiger Lake-LP Smart Sound Technology Audio Controller (rev 20)
00:1f.4 SMBus: Intel Corporation Tiger Lake-LP SMBus Controller (rev 20)
00:1f.5 Serial bus controller: Intel Corporation Tiger Lake-LP SPI Controller (rev 20)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (13) I219-V (rev 20)
e5:00.0 Non-Volatile memory controller: Realtek Semiconductor Co., Ltd. Device 5763 (rev 01)
И драйвер для неё установлен: snd_hda_intel
$ inxi -A
  Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.15.0-52-generic running: yes
Однако в устройствах вывода видно только выходы из HDMI. И никаких признаков встроенных колонок / аналогового сигнала
$ aplay -l
**** Список PLAYBACK устройств ****
карта 0: PCH [HDA Intel PCH], устройство 3: HDMI 0 [HDMI 0]
  Подустройства: 1/1
  Подустройство №0: subdevice #0
карта 0: PCH [HDA Intel PCH], устройство 7: HDMI 1 [HDMI 1]
  Подустройства: 1/1
карта 0: PCH [HDA Intel PCH], устройство 8: HDMI 2 [HDMI 2]
  Подустройства: 1/1
карта 0: PCH [HDA Intel PCH], устройство 9: HDMI 3 [HDMI 3]
  Подустройства: 1/1
карта 0: PCH [HDA Intel PCH], устройство 10: HDMI 4 [HDMI 4]
  Подустройства: 1/1
карта 0: PCH [HDA Intel PCH], устройство 11: HDMI 5 [HDMI 5]
  Подустройства: 1/1
карта 0: PCH [HDA Intel PCH], устройство 12: HDMI 6 [HDMI 6]
  Подустройства: 1/1
карта 0: PCH [HDA Intel PCH], устройство 13: HDMI 7 [HDMI 7]
  Подустройства: 1/1
карта 0: PCH [HDA Intel PCH], устройство 14: HDMI 8 [HDMI 8]
  Подустройства: 1/1
карта 0: PCH [HDA Intel PCH], устройство 15: HDMI 9 [HDMI 9]
  Подустройства: 1/1
карта 0: PCH [HDA Intel PCH], устройство 16: HDMI 10 [HDMI 10]
  Подустройства: 1/1
карта 0: PCH [HDA Intel PCH], устройство 17: HDMI 11 [HDMI 11]
  Подустройства: 1/1
Абсолютно такая же история в alsamixer - видны только под HDMI. На F6 при выборе карты больше ничего не доступно. В PulseAudio тоже только выводы под HDMI. Где взять звук? Куда копать?
02 ноя 2022, 15:36
ZaMosvkorechye писал(а):
02 ноя 2022, 15:18
Вроде бы
Где? Я наблюдаю в списке только контроллер.
Моё
02 ноя 2022, 15:43
Возможно, что ядро ничего не знает о твоем железе.
Попробуй live-cd Fedora
02 ноя 2022, 16:21
02 ноя 2022, 15:18
HDMI воткнут?
Вернуться в «Звуковые карты»
