Не запускается карточный пасьянс pysolfc
1o4ka
Благодарил (а): 23 раза
30 окт 2022, 06:55
LM 21x64
cinnamon, KDE
Железо:
$ inxi -Fxz
Kernel: 5.15.0-52-generic x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: Cinnamon 5.4.12 Distro: Linux Mint 21 Vanessa
base: Ubuntu 22.04 jammy
Type: Desktop Mobo: Gigabyte model: H81M-S2PV serial: <superuser required>
UEFI: American Megatrends v: F9 date: 08/11/2015
Info: dual core model: Intel Pentium G3420 bits: 64 type: MCP arch: Haswell
rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 2642 high: 3191 min/max: 800/3200 cores: 1: 2094
2: 3191 bogomips: 12770
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM107 [GeForce GTX 750] vendor: Palit Microsystems
driver: nouveau v: kernel bus-ID: 01:00.0
Device-3: Sunplus Innovation HD 720P webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-4:3
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: nouveau resolution: 1920x1080~60Hz
OpenGL: renderer: NV117 v: 4.3 Mesa 22.0.5 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-3: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: Palit Microsystems driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-4: Sunplus Innovation HD 720P webcam type: USB
Sound Server-1: ALSA v: k5.15.0-52-generic running: yes
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 3-1:2
IF: wlx1cbfcef72bfe state: up mac: <filter>
Local Storage: total: 1.35 TiB used: 52.69 GiB (3.8%)
ID-1: /dev/sda vendor: Patriot model: Burst Elite 480GB size: 447.13 GiB
ID-2: /dev/sdb vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-3: /dev/sdc vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-4: /dev/sdd type: USB model: USB DISK 2.0 size: 7.22 GiB
ID-1: / size: 97.97 GiB used: 12.02 GiB (12.3%) fs: ext4 dev: /dev/sda5
ID-2: /boot/efi size: 96 MiB used: 30.3 MiB (31.5%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 245.44 GiB used: 40.56 GiB (16.5%) fs: ext4
dev: /dev/sda7
Swap:
ID-1: swap-1 type: partition size: 16.6 GiB used: 0 KiB (0.0%)
dev: /dev/sda6
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%)
dev: /dev/sdb5
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 40.0 C
Processes: 223 Uptime: 23h 29m Memory: 15.52 GiB used: 3.56 GiB (22.9%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2719 Shell: Bash
v: 5.1.16 inxi: 3.3.13
После установки из Менеджера программ, не запускается Pysolfc. Поиски по сети дали следующий результат: https://bugs.gentoo.org/489646 . В общем-то, это - баг.
Что можно предпринять в создавшейся ситуации?
...bis dat qui cito dat
30 окт 2022, 10:14
Покажи ошибку. ссылаться на второй python в 21-м минте уже бы не должно, его там нет)
1o4ka
30 окт 2022, 10:51
30 окт 2022, 10:14
$ pysolfc
Traceback (most recent call last):
File "/usr/games/pysolfc", line 36, in <module>
from pysollib.main import main # noqa: E402,I202
File "/usr/share/games/pysolfc/pysollib/main.py", line 30, in <module>
from pysollib.app import Application
File "/usr/share/games/pysolfc/pysollib/app.py", line 32, in <module>
from pysollib.images import Images, SubsampledImages
File "/usr/share/games/pysolfc/pysollib/images.py", line 28, in <module>
from pysollib.pysoltk import copyImage, createBottom, createImage, loadImage
File "/usr/share/games/pysolfc/pysollib/pysoltk.py", line 35, in <module>
from pysollib.tile.tkhtml import * # noqa: F401,F403
File "/usr/share/games/pysolfc/pysollib/tile/tkhtml.py", line 29, in <module>
from pysollib.ui.tktile.tkhtml import Base_HTMLViewer
File "/usr/share/games/pysolfc/pysollib/ui/tktile/tkhtml.py", line 24, in <module>
import formatter
ModuleNotFoundError: No module named 'formatter'
Error in sys.excepthook:
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 153, in apport_excepthook
with os.fdopen(os.open(pr_filename,
FileNotFoundError: [Errno 2] No such file or directory: '/var/crash/_usr_share_games_pysolfc_pysol.py.1000.crash'
Original exception was:
import formatter
