ui@ui-X79:~$ inxi -Fxz
Kernel: 5.15.0-48-generic x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: Xfce 4.16.0 Distro: Linux Mint 21 Vanessa base: Ubuntu 22.04 jammy
Type: Desktop System: Intel product: X79 v: N/A
serial: <superuser required>
Mobo: Intel model: X79Turbo v: V1.x serial: <superuser required>
UEFI: American Megatrends v: X79QN003 date: 05/28/2021
Info: 8-core model: Intel Xeon E5-2689 0 bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 cache: L1: 512 KiB L2: 2 MiB L3: 20 MiB
Speed (MHz): avg: 1352 high: 1544 min/max: 1200/2601 boost: enabled
cores: 1: 1367 2: 1330 3: 1544 4: 1480 5: 1320 6: 1536 7: 1373 8: 1318
9: 1259 10: 1249 11: 1383 12: 1311 13: 1268 14: 1274 15: 1303 16: 1319
bogomips: 83003
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
driver: amdgpu v: kernel bus-ID: 03:00.0
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080
OpenGL: renderer: AMD Radeon RX 550 / 550 Series (polaris12 LLVM 14.0.0
DRM 3.42 5.15.0-48-generic)
v: 4.6 Mesa 22.2.0 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
driver: snd_hda_intel v: kernel bus-ID: 03:00.1
Sound Server-1: ALSA v: k5.15.0-48-generic running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
v: kernel port: d000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 238.47 GiB used: 41.14 GiB (17.3%)
ID-1: /dev/sda vendor: Samsung model: P3-256 size: 238.47 GiB
ID-1: / size: 9.31 GiB used: 8.91 GiB (95.6%) fs: btrfs dev: /dev/sda1
ID-2: /boot/efi size: 285.4 MiB used: 5.2 MiB (1.8%) fs: vfat
dev: /dev/sda3
ID-3: /home size: 65.19 GiB used: 32.23 GiB (49.4%) fs: btrfs
dev: /dev/sda2
Swap:
ID-1: swap-1 type: partition size: 30.52 GiB used: 0 KiB (0.0%)
dev: /dev/sda4
System Temperatures: cpu: 35.0 C mobo: N/A gpu: amdgpu temp: 37.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1754
Processes: 392 Uptime: 3m Memory: 15.55 GiB used: 2.24 GiB (14.4%)
Init: systemd runlevel: 5 Compilers: gcc: 11.2.0 Packages: 2309 Shell: Bash
v: 5.1.16 inxi: 3.3.13
bogomips: 83003
dev: /dev/sda3
dev: /dev/sda2
Swap:
dev: /dev/sda4
