Подключение wi-fi адаптера tp-link archer t2u nano
DarHaz
Сообщение DarHaz » 19 сен 2022, 17:05
Всем привет. Как и многие столкнулся с проблемой подключения wi-fi адаптера tp-link archer t2u nano на линукс. ОС LMDE 5
Cinnamon Edition 64-bit.
Kernel: 5.10.0-18-amd64 x86_64 bits: 64 compiler: gcc v: 10.2.1
Desktop: Cinnamon 5.4.12 Distro: LMDE 5 Elsie base: Debian 11.2 bullseye
Type: Laptop System: LENOVO product: IdeaPad U310 v: Lenovo U310
serial: <filter>
Mobo: LENOVO model: Lenovo v: 31900004WIN8 STD SGL serial: <filter>
UEFI: Phoenix v: 65CN90WW date: 09/25/2012
ID-1: BAT1 charge: 34.1 Wh condition: 34.2/46.1 Wh (74%)
model: SMP LNV-L11M3P01 status: Unknown
Info: Dual Core model: Intel Core i3-3217U bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 L2 cache: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 14366
Speed: 798 MHz min/max: 800/1800 MHz Core speeds (MHz): 1: 798 2: 798
3: 798 4: 798
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting
unloaded: fbdev,vesa resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.3.5 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
Sound Server: ALSA v: k5.10.0-18-amd64
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 2000 bus ID: 02:00.0
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Lenovo
driver: ath9k v: kernel port: 2000 bus ID: 03:00.0
Device-3: TP-Link AC600 wireless Realtek RTL8811AU [Archer T2U Nano]
type: USB driver: usb-network bus ID: 3-2:5
Device-4: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb
bus ID: 3-4:4
Bluetooth:
Device-1: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus ID: 3-4:4
Report: ID: hci0 state: up running bt-v: 2.1 lmp-v: 4.0 address: <filter>
Local Storage: total: 245.94 GiB used: 26.81 GiB (10.9%)
ID-1: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB
ID-2: /dev/sdb vendor: Ramaxel model: RDM-II XM020C024G size: 22.37 GiB
ID-1: / size: 214.87 GiB used: 26.28 GiB (12.2%) fs: ext4 dev: /dev/sda3
ID-2: /boot/efi size: 285.4 MiB used: 3.4 MiB (1.2%) fs: vfat
dev: /dev/sda1
Swap:
ID-1: swap-1 type: partition size: 3.91 GiB used: 537.2 MiB (13.4%)
dev: /dev/sda2
System Temperatures: cpu: 69.0 C mobo: N/A
Processes: 232 Uptime: 1h 23m Memory: 3.7 GiB used: 2.67 GiB (72.3%)
Init: systemd runlevel: 5 Compilers: gcc: 10.2.1 Packages: 2072
Shell: Bash v: 5.1.4 inxi: 3.3.01
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 003: ID 058f:6366 Alcor Micro Corp. Multi Flash Reader
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 0cf3:3004 Qualcomm Atheros Communications AR3012 Bluetooth 4.0
Bus 003 Device 005: ID 2357:011e TP-Link AC600 wireless Realtek RTL8811AU [Archer T2U Nano]
Bus 003 Device 002: ID 09da:9090 A4Tech Co., Ltd. XL-730K / XL-750BK / XL-755BK Mice
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Нагуглил установку драйвера rtl8812au, и по шагам проделал:
git clone https://github.com/aircrack-ng/rtl8812au.git
cd rtl8812au
sudo make dkms_install
dkms status выдает следующее (я там несколько раз что-то пытался установить из различных гайдов)
8812au, 5.6.4.2_35491.20191025, 5.10.0-18-amd64, x86_64: installed
rtl8812au, 5.3.4: added
rtl8821au, 5.12.5.2, 5.10.0-18-amd64, x86_64: installed
Все это не привело к успеху, адаптер виден системой, но не работает.
В линуксе я совсем новичок, поэтому если можно, то подробную инструкцию как быть)
Благодарил (а): 55 раз
Сообщение slant » 19 сен 2022, 17:31
DarHaz писал(а):
19 сен 2022, 17:05
В данном случае единственная простая и подробная инструкция:
1. Сдать адаптер откуда взяли.
2. Не связываться с продукцией TP-Link.
Все остальное с ним простым не будет.
Адрес то дров верный - https://github.com/aircrack-ng/rtl8812au - открыть и вдумчиво действовать по инструкции самих авторов. Без гарантии что заведется. Ибо TP-Link.
Благодарил (а): 802 раза
Сообщение rogoznik » 19 сен 2022, 18:15
DarHaz писал(а):
19 сен 2022, 17:05
На этом драйвере у меня завелся Tenda U12(тоже на rtl8812au). Правда это было на Manjaro. Но в данном случае не думаю что это играет какую-то роль.
Так что либо что-то не то сделал, либо, как было сказано выше, это TP-Link
Сотрудник
Сообщение Сотрудник » 20 сен 2022, 08:40
У меня маршрутизатор TP_LINK TL-MR3420, нет проблем с подключением, подключается даже с флешки (предварительно настроил в браузере), подключён к ноуту по проводу LAN, неужели всё так плохо с этой компанией :sad:
Сообщение slant » 20 сен 2022, 09:26
Сотрудник писал(а):
20 сен 2022, 08:40
Отвратительно. Они производят максимально закрытые устройства, которые не обслуживаются и не настраиваются толком. Даже прошить роутер в случае слета прошивки стало проблемой (не говоря уже о установке кастома). По большому счету там сейчас так: не заработало сразу как нужно - только выкинуть. Ибо донастроить под свои нужды не получится. А качество железа - тот же D-Link, но деленный как минимум на 2.
Taciturn
Сообщение Taciturn » 03 ноя 2023, 10:11
У меня завелся... Смортри ТУТ
Благодарил (а): 1378 раз
Сообщение Dja » 03 ноя 2023, 10:13
Taciturn,
Taciturn писал(а):
19 июн 2019, 14:14
Distro: Linux Mint 19.1
DarHaz писал(а):
19 сен 2022, 17:05
Distro: LMDE 5
:ku:
