Прерывание звука. Аудиокарта Behringer u-phoria umc404hd/Linux Mint 20.3 UnaХ64
inbloom
11 сен 2022, 23:14
Дано: Сзади подключены колонки через main out\спереди наушники.
При воспроизведении любого медиафайла звук пропадает каждые 5-7 секунд
inxi -F
Host: inbloom-A320MH Kernel: 5.4.0-125-generic x86_64 bits: 64
Desktop: Cinnamon 5.2.7 Distro: Linux Mint 20.3 Una
Type: Desktop Mobo: BIOSTAR model: A320MH
serial: <superuser/root required> UEFI: American Megatrends v: 5.14
date: 09/25/2019
Topology: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP
L2 cache: 3072 KiB
Speed: 1374 MHz min/max: 1550/3400 MHz Core speeds (MHz): 1: 1375 2: 1375
3: 2787 4: 1326 5: 1374 6: 1327 7: 2406 8: 1328 9: 1374 10: 1374 11: 1375
12: 1330
Device-1: NVIDIA driver: nvidia v: 515.65.01
Display: x11 server: X.Org 1.20.13 driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa resolution: 1680x1050~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 515.65.01
Device-1: NVIDIA TU106 High Definition Audio driver: snd_hda_intel
Device-2: BEHRINGER UMC404HD 192k type: USB driver: snd-usb-audio
Sound Server: ALSA v: k5.4.0-125-generic
driver: r8169
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: f4:b5:20:2a:6e:97
Local Storage: total: 1.38 TiB used: 88.42 GiB (6.3%)
ID-1: /dev/sda model: Neo Forza NFS011SA351-6007000 size: 476.94 GiB
ID-2: /dev/sdb vendor: Seagate model: ST500DM002-1BD142 size: 465.76 GiB
ID-3: /dev/sdc type: USB vendor: Toshiba model: MQ01ABD050
ID-1: / size: 48.47 GiB used: 14.45 GiB (29.8%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 33.6 C mobo: N/A gpu: nvidia temp: 34 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Processes: 329 Uptime: 23m Memory: 15.64 GiB used: 2.24 GiB (14.3%)
Shell: bash inxi: 3.0.38
Ввожу от обычного юзверя pacmd list-cardsкоманду (я так понял показывает че есть ваще)
2 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 7
properties:
alsa.card = "0"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xf7080000 irq 78"
alsa.driver_name = "snd_hda_intel"
device.bus_path = "pci-0000:07:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "10f9"
device.product.name = "TU106 High Definition Audio Controller"
device.string = "0"
device.description = "TU106 High Definition Audio Controller"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) выход (priority 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) выход (priority 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) выход (priority 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) выход (priority 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) выход (priority 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) выход (priority 600, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) выход (priority 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) выход (priority 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) выход (priority 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) выход (priority 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) выход (priority 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) выход (priority 600, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) выход (priority 5700, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) выход (priority 600, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) выход (priority 600, available: no)
output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) выход (priority 5700, available: no)
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) выход (priority 600, available: no)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) выход (priority 600, available: no)
off: Выключено (priority 0, available: unknown)
active profile: <off>
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
device.icon_name = "video-display"
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
hdmi-output-5: HDMI / DisplayPort 6 (priority 5400, latency offset 0 usec, available: no)
properties:
index: 1
owner module: 8
properties:
alsa.card = "1"
alsa.card_name = "UMC404HD 192k"
alsa.long_card_name = "BEHRINGER UMC404HD 192k at usb-0000:08:00.3-2, high speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:08:00.3-usb-0:2:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:07.1/0000:08:00.3/usb3/3-2/3-2:1.0/sound/card1"
udev.id = "usb-BEHRINGER_UMC404HD_192k-00"
device.bus = "usb"
device.vendor.id = "1397"
device.vendor.name = "BEHRINGER International GmbH"
device.product.id = "0509"
device.product.name = "UMC404HD 192k"
device.serial = "BEHRINGER_UMC404HD_192k"
device.string = "1"
device.description = "UMC404HD 192k"
device.icon_name = "audio-card-usb"
profiles:
input:multichannel-input: Многоканальный вход (priority 1, available: unknown)
output:analog-surround-40: Аналоговый объёмный 4.0 выход (priority 1200, available: unknown)
output:analog-surround-40+input:multichannel-input: Аналоговый объёмный 4.0 выход + Многоканальный вход (priority 1201, available: unknown)
active profile: <output:analog-surround-40+input:multichannel-input>
sinks:
alsa_output.usb-BEHRINGER_UMC404HD_192k-00.analog-surround-40/#0: UMC404HD 192k Аналоговый объёмный 4.0
sources:
alsa_output.usb-BEHRINGER_UMC404HD_192k-00.analog-surround-40.monitor/#0: Monitor of UMC404HD 192k Аналоговый объёмный 4.0
alsa_input.usb-BEHRINGER_UMC404HD_192k-00.multichannel-input/#1: UMC404HD 192k Многоканальный
ports:
multichannel-input: Многоканальный вход (priority 0, latency offset 0 usec, available: unknown)
properties:
analog-output: Аналоговый выход (priority 9900, latency offset 0 usec, available: unknown)
properties:
Далее так же от юзера ввожу pacmd list-sinks (эту, как сказали, надо тестить с включенным музлом, видео, микро, что бы показать что активно)
1 sink(s) available.
* index: 0
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: RUNNING
suspend cause: (none)
priority: 9049
volume: front-left: 27525 / 42% / -22,61 dB, front-right: 27525 / 42% / -22,61 dB, rear-left: 27525 / 42% / -22,61 dB, rear-right: 27525 / 42% / -22,61 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 58,21 ms
max request: 56 KiB
max rewind: 56 KiB
monitor source: 0
sample spec: s32le 4-канальный 4800
channel map: front-left,front-right,rear-left,rear-right
Объёмный 4.0
used by: 1
linked by: 1
configured latency: 75,00 ms; range is 0,50 .. 1365,33 ms
card: 1 <alsa_card.usb-BEHRINGER_UMC404HD_192k-00>
module: 8
properties:
alsa.resolution_bits = "32"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "USB Audio"
alsa.id = "USB Audio"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "1"
device.bus = "usb"
device.string = "surround40:1"
device.buffering.buffer_size = "1048576"
device.buffering.fragment_size = "524288"
device.access_mode = "mmap+timer"
device.profile.name = "analog-surround-40"
device.profile.description = "Аналоговый объёмный 4.0"
device.description = "UMC404HD 192k Аналоговый объёмный 4.0"
ports:
properties:
active port: <analog-output>
Инфа из отчётов системы
System: Kernel: 5.4.0-125-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
Desktop: Cinnamon 5.2.7 wm: muffin dm: LightDM Distro: Linux Mint 20.3 Una
base: Ubuntu 20.04 focal
Machine: Type: Desktop Mobo: BIOSTAR model: A320MH serial: <filter> UEFI: American Megatrends
v: 5.14 date: 09/25/2019
CPU: Topology: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ rev: 2
L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 81436
Speed: 1556 MHz min/max: 1550/3400 MHz Core speeds (MHz): 1: 1556 2: 3890 3: 1375
4: 1375 5: 1556 6: 1375 7: 1375 8: 1375 9: 1557 10: 3892 11: 1556 12: 1375
Graphics: Device-1: NVIDIA driver: nvidia v: 515.65.01 bus ID: 07:00.0 chip ID: 10de:1f0a
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA 515.65.01
Audio: Device-1: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel
bus ID: 07:00.1 chip ID: 10de:10f9
Device-2: BEHRINGER UMC404HD 192k type: USB driver: snd-usb-audio bus ID: 3-2:3
chip ID: 1397:0509
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Biostar Microtech Intl Corp driver: r8169 v: kernel port: f000 bus ID: 03:00.0
chip ID: 10ec:8168
Drives: Local Storage: total: 1.38 TiB used: 88.43 GiB (6.3%)
ID-1: /dev/sda model: Neo Forza NFS011SA351-6007000 size: 476.94 GiB speed: 6.0 Gb/s
serial: <filter>
speed: 6.0 Gb/s serial: <filter>
ID-3: /dev/sdc type: USB vendor: Toshiba model: MQ01ABD050 size: 465.76 GiB
serial: <filter>
Partition: ID-1: / size: 48.47 GiB used: 14.45 GiB (29.8%) fs: ext4 dev: /dev/sda2
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0 chip ID: 1d6b:0002
Device-1: 1-5:2 info: Microsoft Wheel Mouse Optical type: Mouse
driver: hid-generic,usbhid rev: 1.1 chip ID: 045e:0040
Hub: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 3.1 chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 chip ID: 1d6b:0002
Device-2: 3-1:2 info: China Resource Semico USB Keyboard type: Keyboard,HID
driver: hid-generic,usbhid rev: 1.1 chip ID: 1a2c:4094
Device-3: 3-2:3 info: BEHRINGER UMC404HD 192k type: Audio driver: snd-usb-audio
rev: 2.0 chip ID: 1397:0509
Device-4: 3-3:4 info: Verbatim Portable Harddrive type: Mass Storage
driver: usb-storage rev: 2.1 chip ID: 18a5:0237
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 35 C
Repos: No active apt repos in: /etc/apt/sources.list
1: deb http: //packages.linuxmint.com una main upstream import backport #id:linuxmint_main
2: deb http: //archive.ubuntu.com/ubuntu focal main restricted universe multiverse
3: deb http: //archive.ubuntu.com/ubuntu focal-updates main restricted universe multiverse
4: deb http: //archive.ubuntu.com/ubuntu focal-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
6: deb http: //archive.canonical.com/ubuntu/ focal partner
Info: Processes: 351 Uptime: 1h 10m Memory: 15.64 GiB used: 2.50 GiB (16.0%) Init: systemd
v: 245 runlevel: 5 Compilers: gcc: 9.4.0 alt: 9 Client: Unknown python3.8 client
inxi: 3.0.38
lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) I/O Memory Management Unit
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 59)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 7
01:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 43bc (rev 02)
01:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] Device 43b8 (rev 02)
01:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43b3 (rev 02)
02:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
02:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
02:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
02:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
07:00.0 VGA compatible controller: NVIDIA Corporation Device 1f0a (rev a1)
07:00.1 Audio device: NVIDIA Corporation TU106 High Definition Audio Controller (rev a1)
08:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Zeppelin/Raven/Raven2 PCIe Dummy Function
08:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor
08:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Zeppelin USB 3.0 Host controller
09:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Zeppelin/Renoir PCIe Dummy Function
09:00.2 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
КТЩ ЗНАЕТ ЧТО ДЕЛАТЬ? ПОМОГИТЕ И РАЗЖУЙТЕ ПОЖАЛУЙСТА!
12 сен 2022, 00:54
inbloom писал(а):
11 сен 2022, 23:14
Судя по inxi - вы снесли pulseaudio и pipewire (возможно прочитали такую рекомендацию как средство улучшения звука в каком то старом руководстве?) Без них микширование нормально работать не будет, а программы будут "драться" за право вывода звука между собой. Ставьте обратно pipewire, и pipewire-pulse.
12 сен 2022, 07:16
А еще не забыть поставить пакет wireplumber
inbloom
13 сен 2022, 12:16
12 сен 2022, 00:54
inbloom писал(а):
11 сен 2022, 23:14
Не помогло. Прочитал, что надо сделать дефолтной нужную карту. Сделал. В alsa.conf изменил значения с 0 на 1:
defaults.ctl.card 1
defaults.pcm.card 1 При перезагрузке сисемы вообще звука нет! Лечится sudo alsa force-reload Но всё равно звук с прерываниями.
Если надо какие отчёты - прикреплю
sheridan
Решено: 14
Благодарил (а): 900 раз
13 сен 2022, 13:05
inbloom, А почему не по пробовать Вам другой дистрибутив например Ubuntu studio, который изначально заточен под такие устройства ( BEHRINGER UMC404HD 192k), где сразу можно подключить Jack,
судя по inxi у Вас кроме Alsa ничего не установлено.
inbloom
13 сен 2022, 13:48
sheridan писал(а):
13 сен 2022, 13:05
Я пробовал. Судя по всему это карта такая
В Виндвс отлично работает
Вернуться в «Звуковые карты»
