Не видит SD-карту
Автор темы - Сообщения: 12
Не видит SD-карту
Добрый день, значит хотел отфармотировать сд, вставил в картридер. Звук подключения был, а система не увидела
Не видит SD-карту
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT fd0 2:0 1 4K 0 disk loop0 7:0 0 8K 1 loop /snap/anbox-installer/24 loop1 7:1 0 4K 1 loop /snap/bare/5 loop2 7:2 0 55,5M 1 loop /snap/core18/2409 loop3 7:3 0 111,7M 1 loop /snap/core/13250 loop4 7:4 0 113,9M 1 loop /snap/core/13308 loop5 7:5 0 61,9M 1 loop /snap/core20/1494 loop6 7:6 0 61,9M 1 loop /snap/core20/1518 loop7 7:7 0 55,1M 1 loop /snap/cups/760 loop8 7:8 0 55,1M 1 loop /snap/cups/766 loop9 7:9 0 254,1M 1 loop /snap/gnome-3-38-2004/106 loop10 7:10 0 248,8M 1 loop /snap/gnome-3-38-2004/99 loop11 7:11 0 81,3M 1 loop /snap/gtk-common-themes/1534 loop12 7:12 0 5,7M 1 loop /snap/ngrok/53 loop13 7:13 0 683,1M 1 loop /snap/onlyoffice-desktopeditors/114 loop14 7:14 0 683,1M 1 loop /snap/onlyoffice-desktopeditors/115 loop15 7:15 0 20,6M 1 loop /snap/ubuntu-make/851 loop16 7:16 0 189,4M 1 loop /snap/guiscrcpy/256 sda 8:0 0 76,3G 0 disk ├─sda1 8:1 0 512M 0 part ├─sda2 8:2 0 513M 0 part /boot/efi ├─sda3 8:3 0 1K 0 part └─sda5 8:5 0 75,3G 0 part / sdb 8:16 0 931,5G 0 disk ├─sdb1 8:17 0 762,7G 0 part ├─sdb2 8:18 0 512M 0 part ├─sdb3 8:19 0 86G 0 part └─sdb4 8:20 0 82,4G 0 part sdg 8:96 1 57,8G 0 disk ├─sdg1 8:97 1 17,8G 0 part /media/minakrut7916/LINUX MINT └─sdg2 8:98 1 40G 0 part /media/minakrut7916/casper-rw
[24925.999006] Code: 41 54 55 53 48 83 ec 38 4c 8b 2f 48 8b 1e 64 48 8b 04 25 28 00 00 00 48 89 44 24 28 31 c0 49 39 dd 0f 84 17 01 00 00 49 89 fc <49> 8b 7d 28 48 8b 43 28 48 89 f5 48 85 ff 74 6c 48 85 c0 74 3f 48 [24960.641962] [UFW BLOCK] IN=wlx00179a779b0c OUT= MAC=00:17:9a:77:9b:0c:c4:44:7d:21:32:bd:08:00 SRC=176.50.67.20 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=197 PROTO=2 [24966.997464] appimagelaunche[41831]: segfault at 100010028 ip 00007fbda980b5d4 sp 00007fffb8535b50 error 4 in libQt5Core.so.5.12.8[7fbda96de000+2e0000] [24966.997489] Code: 41 54 55 53 48 83 ec 38 4c 8b 2f 48 8b 1e 64 48 8b 04 25 28 00 00 00 48 89 44 24 28 31 c0 49 39 dd 0f 84 17 01 00 00 49 89 fc <49> 8b 7d 28 48 8b 43 28 48 89 f5 48 85 ff 74 6c 48 85 c0 74 3f 48 [24974.941134] nouveau 0000:05:00.0: Direct firmware load for nouveau/nvd9_fuc084 failed with error -2 [24974.941168] nouveau 0000:05:00.0: Direct firmware load for nouveau/nvd9_fuc084d failed with error -2 [24974.941171] nouveau 0000:05:00.0: msvld: unable to load firmware data [24974.941179] nouveau 0000:05:00.0: msvld: init failed, -19 [24995.882624] ieee80211 phy0: rt2x00usb_watchdog_tx_dma: Warning - TX queue 2 DMA timed out, invoke forced forced reset [24997.322619] ieee80211 phy0: rt2x00usb_watchdog_tx_dma: Warning - TX queue 2 DMA timed out, invoke forced forced reset [24998.762623] ieee80211 phy0: rt2x00usb_watchdog_tx_dma: Warning - TX queue 2 DMA timed out, invoke forced forced reset [25000.234614] ieee80211 phy0: rt2x00usb_watchdog_tx_dma: Warning - TX queue 2 DMA timed out, invoke forced forced reset [25001.674611] ieee80211 phy0: rt2x00usb_watchdog_tx_dma: Warning - TX queue 2 DMA timed out, invoke forced forced reset [25003.146626] ieee80211 phy0: rt2x00usb_watchdog_tx_dma: Warning - TX queue 2 DMA timed out, invoke forced forced reset [25004.650620] ieee80211 phy0: rt2x00usb_watchdog_tx_dma: Warning - TX queue 2 DMA timed out, invoke forced forced reset [25006.058608] ieee80211 phy0: rt2x00usb_watchdog_tx_dma: Warning - TX queue 2 DMA timed out, invoke forced forced reset [25007.434609] ieee80211 phy0: rt2x00usb_watchdog_tx_dma: Warning - TX queue 2 DMA timed out, invoke forced forced reset [25008.938832] ieee80211 phy0: rt2x00usb_watchdog_tx_dma: Warning - TX queue 2 DMA timed out, invoke forced forced reset [25008.997489] appimagelaunche[41941]: segfault at 100010028 ip 00007fef613775d4 sp 00007ffc4850c190 error 4 in libQt5Core.so.5.12.8[7fef6124a000+2e0000] [25008.997519] Code: 41 54 55 53 48 83 ec 38 4c 8b 2f 48 8b 1e 64 48 8b 04 25 28 00 00 00 48 89 44 24 28 31 c0 49 39 dd 0f 84 17 01 00 00 49 89 fc <49> 8b 7d 28 48 8b 43 28 48 89 f5 48 85 ff 74 6c 48 85 c0 74 3f 48 [25010.378673] ieee80211 phy0: rt2x00usb_watchdog_tx_dma: Warning - TX queue 2 DMA timed out, invoke forced forced reset [25011.026673] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 0 failed to flush [25011.754643] ieee80211 phy0: rt2x00usb_watchdog_tx_dma: Warning - TX queue 2 DMA timed out, invoke forced forced reset [25049.997145] appimagelaunche[43037]: segfault at 100010028 ip 00007f2d08c095d4 sp 00007ffc14bef7b0 error 4 in libQt5Core.so.5.12.8[7f2d08adc000+2e0000] [25049.997171] Code: 41 54 55 53 48 83 ec 38 4c 8b 2f 48 8b 1e 64 48 8b 04 25 28 00 00 00 48 89 44 24 28 31 c0 49 39 dd 0f 84 17 01 00 00 49 89 fc <49> 8b 7d 28 48 8b 43 28 48 89 f5 48 85 ff 74 6c 48 85 c0 74 3f 48 [25083.142730] [UFW BLOCK] IN=wlx00179a779b0c OUT= MAC=00:17:9a:77:9b:0c:4a:80:9d:8e:5b:08:08:00 SRC=192.168.100.97 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=10153 PROTO=2 [25085.575192] [UFW BLOCK] IN=wlx00179a779b0c OUT= MAC=00:17:9a:77:9b:0c:c4:44:7d:21:32:bd:08:00 SRC=176.50.67.20 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=198 PROTO=2 [25088.129174] [UFW BLOCK] IN=wlx00179a779b0c OUT= MAC=00:17:9a:77:9b:0c:4a:80:9d:8e:5b:08:08:00 SRC=192.168.100.97 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=15021 PROTO=2 [25090.996786] appimagelaunche[43124]: segfault at 100010028 ip 00007f949c5585d4 sp 00007ffec2cbd3e0 error 4 in libQt5Core.so.5.12.8[7f949c42b000+2e0000] [25090.996811] Code: 41 54 55 53 48 83 ec 38 4c 8b 2f 48 8b 1e 64 48 8b 04 25 28 00 00 00 48 89 44 24 28 31 c0 49 39 dd 0f 84 17 01 00 00 49 89 fc <49> 8b 7d 28 48 8b 43 28 48 89 f5 48 85 ff 74 6c 48 85 c0 74 3f 48 [25131.997477] appimagelaunche[43157]: segfault at 100010028 ip 00007f15114745d4 sp 00007ffd4e892cd0 error 4 in libQt5Core.so.5.12.8[7f1511347000+2e0000] [25131.997502] Code: 41 54 55 53 48 83 ec 38 4c 8b 2f 48 8b 1e 64 48 8b 04 25 28 00 00 00 48 89 44 24 28 31 c0 49 39 dd 0f 84 17 01 00 00 49 89 fc <49> 8b 7d 28 48 8b 43 28 48 89 f5 48 85 ff 74 6c 48 85 c0 74 3f 48 [25169.054963] [UFW BLOCK] IN=wlx00179a779b0c OUT= MAC=00:17:9a:77:9b:0c:4a:80:9d:8e:5b:08:08:00 SRC=192.168.100.97 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=35823 PROTO=2 [25172.997683] appimagelaunche[43195]: segfault at 100010028 ip 00007fee692f05d4 sp 00007ffcf837a220 error 4 in libQt5Core.so.5.12.8[7fee691c3000+2e0000] [25172.997708] Code: 41 54 55 53 48 83 ec 38 4c 8b 2f 48 8b 1e 64 48 8b 04 25 28 00 00 00 48 89 44 24 28 31 c0 49 39 dd 0f 84 17 01 00 00 49 89 fc <49> 8b 7d 28 48 8b 43 28 48 89 f5 48 85 ff 74 6c 48 85 c0 74 3f 48 [25210.600974] [UFW BLOCK] IN=wlx00179a779b0c OUT= MAC=00:17:9a:77:9b:0c:c4:44:7d:21:32:bd:08:00 SRC=176.50.67.20 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=199 PROTO=2 [25213.997522] appimagelaunche[43231]: segfault at 100010028 ip 00007fc10ea0d5d4 sp 00007ffea43b9500 error 4 in libQt5Core.so.5.12.8[7fc10e8e0000+2e0000] [25213.997540] Code: 41 54 55 53 48 83 ec 38 4c 8b 2f 48 8b 1e 64 48 8b 04 25 28 00 00 00 48 89 44 24 28 31 c0 49 39 dd 0f 84 17 01 00 00 49 89 fc <49> 8b 7d 28 48 8b 43 28 48 89 f5 48 85 ff 74 6c 48 85 c0 74 3f 48 [25254.997767] appimagelaunche[43269]: segfault at 100010028 ip 00007f3915ad95d4 sp 00007ffe872ffde0 error 4 in libQt5Core.so.5.12.8[7f39159ac000+2e0000] [25254.997793] Code: 41 54 55 53 48 83 ec 38 4c 8b 2f 48 8b 1e 64 48 8b 04 25 28 00 00 00 48 89 44 24 28 31 c0 49 39 dd 0f 84 17 01 00 00 49 89 fc <49> 8b 7d 28 48 8b 43 28 48 89 f5 48 85 ff 74 6c 48 85 c0 74 3f 48 [25296.000520] appimagelaunche[43306]: segfault at 100010028 ip 00007fdde29515d4 sp 00007ffde5073eb0 error 4 in libQt5Core.so.5.12.8[7fdde2824000+2e0000] [25296.000546] Code: 41 54 55 53 48 83 ec 38 4c 8b 2f 48 8b 1e 64 48 8b 04 25 28 00 00 00 48 89 44 24 28 31 c0 49 39 dd 0f 84 17 01 00 00 49 89 fc <49> 8b 7d 28 48 8b 43 28 48 89 f5 48 85 ff 74 6c 48 85 c0 74 3f 48 [25335.723822] [UFW BLOCK] IN=wlx00179a779b0c OUT= MAC=00:17:9a:77:9b:0c:c4:44:7d:21:32:bd:08:00 SRC=176.50.67.20 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=200 PROTO=2 [25336.997689] appimagelaunche[43345]: segfault at 100010028 ip 00007fb45520a5d4 sp 00007fff2ba44ee0 error 4 in libQt5Core.so.5.12.8[7fb4550dd000+2e0000] [25336.997715] Code: 41 54 55 53 48 83 ec 38 4c 8b 2f 48 8b 1e 64 48 8b 04 25 28 00 00 00 48 89 44 24 28 31 c0 49 39 dd 0f 84 17 01 00 00 49 89 fc <49> 8b 7d 28 48 8b 43 28 48 89 f5 48 85 ff 74 6c 48 85 c0 74 3f 48 [25377.997467] appimagelaunche[43389]: segfault at 100010028 ip 00007f51c1e185d4 sp 00007ffc8ae4efc0 error 4 in libQt5Core.so.5.12.8[7f51c1ceb000+2e0000] [25377.997494] Code: 41 54 55 53 48 83 ec 38 4c 8b 2f 48 8b 1e 64 48 8b 04 25 28 00 00 00 48 89 44 24 28 31 c0 49 39 dd 0f 84 17 01 00 00 49 89 fc <49> 8b 7d 28 48 8b 43 28 48 89 f5 48 85 ff 74 6c 48 85 c0 74 3f 48 [25399.532219] [UFW BLOCK] IN=wlx00179a779b0c OUT= MAC=00:17:9a:77:9b:0c:4a:80:9d:8e:5b:08:08:00 SRC=192.168.100.97 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=48044 PROTO=2 [25418.997272] appimagelaunche[43424]: segfault at 100010028 ip 00007fac5c7075d4 sp 00007ffea7ce7b10 error 4 in libQt5Core.so.5.12.8[7fac5c5da000+2e0000] [25418.997298] Code: 41 54 55 53 48 83 ec 38 4c 8b 2f 48 8b 1e 64 48 8b 04 25 28 00 00 00 48 89 44 24 28 31 c0 49 39 dd 0f 84 17 01 00 00 49 89 fc <49> 8b 7d 28 48 8b 43 28 48 89 f5 48 85 ff 74 6c 48 85 c0 74 3f 48
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 17
Причина: форматирование
Не видит SD-карту
Minakrut7916, установите графические программы GPerted или gnome-disks - Disks (Диски) и попробуйте форматировать в этих программах. Увидеть все устройства и разделы можно в терминале при помощи команд fdisk и parted, вывод справки по ключам команд "--help"
Не видит SD-карту
Система Linux Mint 20.3 Cinnamon, ядро 5.13.0-52-generic.
Такая же ситуёвина! SD карта 16 Gb через встроенный в ноутбук картридер ни в какую ни хочет работать. После перезагрузки в терминале командой lsblk видно sdcard, распознается как mmcblk0. При монтировать не удается.
Программа fdisk вроде видит и читает раздел, но по факту только делает вид. Программа gparted также не может сделать ни чего с sd картой.
Этот же ноут на винде отлично работает с sd картами через встроенный картридер.
Через внешний картридер карты работают но скорость чтения записи 1-5 mb/c, форматируется карта на такой скорости 4,5 часа
Я с этой проблемой борюсь уже 2 года, а воз и ныне там.
Похоже драйвер сильно кривой, ногами в валенках написанный.
Ну не ужели нет решения этой проблеме. Ну очень не удобно, для того чтобы скинуть фотки с фотика приходится постоянна диск с виндой покидывать
Не видит SD-карту
Александр Семенов, Намек ясен? Что там за кардридер такой, шаманы должны угадывать?- Давайте подарим ему на день рождения книгу!
- Не... Книга у него уже есть...
(с) Анекдот.
