Kaspersky Security Center (KSC13)
Я_Максим
25 май 2022, 15:50
Добрый день, какой день бьюсь с установкой KSC13, Установлена Debian 11, база 10.5.15-MariaDB-0+deb11u1, отредактирован /etc/mysql/my.cnf как указано в мануале касперского
установлен пакет KSC_13.0.11247.deb при запуске скрипта /opt/kaspersky/ksc64/lib/bin/setup/postinstall.pl, прописываю параметры
Enter Administration Server DNS-name or static IP-address:
localhost
Please enter Administration Server port number [14000]:
14000
Enter Administration Server SSL port number [13000]:
13000
Define the approximate number of devices that you intend to manage:
1) 1 to 100 networked devices
2) 101 to 1 000 networked devices
3) More than 1 000 networked devices
Enter the range number (1, 2, or 3) [1]:
2
Enter the security group name for services:
kladmins
Enter the account name to start the Administration Server service. The
account must be a member of the entered security group:
ksc
Enter the account name to start other services. The account must be a
ksc
Enter the database address:
127.0.0.1
Enter the database port:
3306
Please enter the database name:
KSC
Enter the database login:
admin
Enter the database password:
11111111
Add service klnagent_srv...
Fatal error: Server registration failed with code '3': 'Registering
kladminserver.
Fatal error: Setup script failed with code 2, signal 0.
Installation failed.
при проверке запущенных служб выдает
● klnagent_srv.service - Kaspersky Network Agent.
Loaded: loaded (/lib/systemd/system/klnagent_srv.service; enabled; vendor >
Active: active (running) since Wed 2022-05-25 13:55:22 +05; 1h 14min ago
Process: 502 ExecStart=/opt/kaspersky/ksc64/sbin/klnagent (code=exited, sta>
Main PID: 524 (klnagent)
Tasks: 18 (limit: 7075)
Memory: 26.9M
CPU: 59.192s
CGroup: /system.slice/klnagent_srv.service
├─524 /opt/kaspersky/ksc64/sbin/klnagent
├─525 /bin/sh /var/opt/kaspersky/klnagent_srv/tmp/klsc-4EE67F6C320>
└─526 /opt/kaspersky/ksc64/sbin/klnagent -d -from_wd
мая 25 13:55:17 DebianServ systemd[1]: Starting Kaspersky Network Agent....
мая 25 13:55:22 DebianServ systemd[1]: Started Kaspersky Network Agent..
мая 25 13:55:39 DebianServ klnagent_srv_srv[526]: Агент администрирования 13.0.>
lines 1-16/16 (END)
Loaded: loaded (/lib/systemd/system/klnagent_srv.service; enabled; vendor p>
Process: 502 ExecStart=/opt/kaspersky/ksc64/sbin/klnagent (code=exited, stat>
Memory: 26.9M
CPU: 59.192s
├─525 /bin/sh /var/opt/kaspersky/klnagent_srv/tmp/klsc-4EE67F6C320C>
мая 25 13:55:39 DebianServ klnagent_srv_srv[526]: Агент администрирования 13.0.0>
lines 1-16/16 (END)...skipping...
Loaded: loaded (/lib/systemd/system/klnagent_srv.service; enabled; vendor pr>
Process: 502 ExecStart=/opt/kaspersky/ksc64/sbin/klnagent (code=exited, statu>
Memory: 26.9M
CPU: 59.192s
├─525 /bin/sh /var/opt/kaspersky/klnagent_srv/tmp/klsc-4EE67F6C320CE>
мая 25 13:55:39 DebianServ klnagent_srv_srv[526]: Агент администрирования 13.0.0.>
Loaded: loaded (/lib/systemd/system/klnagent_srv.service; enabled; vendor pres>
Process: 502 ExecStart=/opt/kaspersky/ksc64/sbin/klnagent (code=exited, status=>
Memory: 26.9M
CPU: 59.192s
├─525 /bin/sh /var/opt/kaspersky/klnagent_srv/tmp/klsc-4EE67F6C320CEEF>
мая 25 13:55:39 DebianServ klnagent_srv_srv[526]: Агент администрирования 13.0.0.11>
Loaded: loaded (/lib/systemd/system/klnagent_srv.service; enabled; vendor preset>
Process: 502 ExecStart=/opt/kaspersky/ksc64/sbin/klnagent (code=exited, status=0/>
Memory: 26.9M
CPU: 59.192s
├─525 /bin/sh /var/opt/kaspersky/klnagent_srv/tmp/klsc-4EE67F6C320CEEFA/>
мая 25 13:55:39 DebianServ klnagent_srv_srv[526]: Агент администрирования 13.0.0.1124>
root@DebianServ:~# systemctl status kladminserver_srv.service
● kladminserver_srv.service - Kaspersky Security Center.
Loaded: loaded (/lib/systemd/system/kladminserver_srv.service; enabled; vendor p>
Active: failed (Result: signal) since Wed 2022-05-25 13:55:23 +05; 1h 15min ago
Process: 501 ExecStart=/opt/kaspersky/ksc64/sbin/klserver (code=killed, signal=TR>
CPU: 333ms
мая 25 13:55:17 DebianServ systemd[1]: Starting Kaspersky Security Center....
мая 25 13:55:23 DebianServ systemd[1]: kladminserver_srv.service: Control process exi>
мая 25 13:55:23 DebianServ systemd[1]: kladminserver_srv.service: Failed with result >
мая 25 13:55:23 DebianServ systemd[1]: Failed to start Kaspersky Security Center..
lines 1-10/10 (END)...skipping...
Loaded: loaded (/lib/systemd/system/kladminserver_srv.service; enabled; vendor preset: enabled)
Process: 501 ExecStart=/opt/kaspersky/ksc64/sbin/klserver (code=killed, signal=TRAP)
CPU: 333ms
мая 25 13:55:23 DebianServ systemd[1]: kladminserver_srv.service: Control process exited, code=killed, status=5/TRAP
мая 25 13:55:23 DebianServ systemd[1]: kladminserver_srv.service: Failed with result 'signal'.
root@DebianServ:~# systemctl status klactprx_srv.service
● klactprx_srv.service - Service allowing Network Agent to access activation servers to activate recently installed applications..
Loaded: loaded (/lib/systemd/system/klactprx_srv.service; enabled; vendor preset: enabled)
Active: failed (Result: signal) since Wed 2022-05-25 13:55:21 +05; 1h 16min ago
Process: 500 ExecStart=/opt/kaspersky/ksc64/sbin/klactprx (code=killed, signal=TRAP)
CPU: 163ms
мая 25 13:55:17 DebianServ systemd[1]: Starting Service allowing Network Agent to access activation servers to activate recently installed >
мая 25 13:55:21 DebianServ systemd[1]: klactprx_srv.service: Control process exited, code=killed, status=5/TRAP
мая 25 13:55:21 DebianServ systemd[1]: klactprx_srv.service: Failed with result 'signal'.
мая 25 13:55:21 DebianServ systemd[1]: Failed to start Service allowing Network Agent to access activation servers to activate recently ins>
root@DebianServ:~# systemctl status klwebsrv_srv.service
● klwebsrv_srv.service - Kaspersky Web Server..
Loaded: loaded (/lib/systemd/system/klwebsrv_srv.service; enabled; vendor preset: enabled)
Active: failed (Result: signal) since Wed 2022-05-25 13:55:21 +05; 1h 17min ago
Process: 503 ExecStart=/opt/kaspersky/ksc64/sbin/klcsweb (code=killed, signal=TRAP)
CPU: 151ms
мая 25 13:55:17 DebianServ systemd[1]: Starting Kaspersky Web Server.....
мая 25 13:55:21 DebianServ systemd[1]: klwebsrv_srv.service: Control process exited, code=killed, status=5/TRAP
мая 25 13:55:21 DebianServ systemd[1]: klwebsrv_srv.service: Failed with result 'signal'.
мая 25 13:55:21 DebianServ systemd[1]: Failed to start Kaspersky Web Server...
FX-8350 тащит
Whowka
Благодарил (а): 777 раз
25 май 2022, 17:06
Я_Максим, А в тех. поддержку Касперского не пробовал обращаться? А к Debian 11 KSC13 адаптирована?
Лёгкое гугление показало,что только к 10-ке и 9-ке. Источник
Я_Максим
25 май 2022, 17:14
Whowka, В тех поддержку обращался долго отвечают, да я в курсе поддержки!
FX-8350 тащит
Nickolas
Благодарил (а): 174 раза
25 май 2022, 19:13
Техподдержка у них отвратительная.
Сам сталкивался.
А Dr.Web почему не хотите поставить?
Я_Максим
25 май 2022, 19:39
Nickolas, каспер уже закуплеен)
FX-8350 тащит
melik2k3
22 май 2023, 11:34
Подскажите, вы разобрались с ошибкой:
" Add service klnagent_srv...
kladminserver.
Installation failed."
Если да , то прошу поделитесь решением, пожалуйста.
22 май 2023, 13:41
Я_Максим писал(а):
25 май 2022, 15:50
localhost
М.б. надо не localhost, а действительный статический IP или имя компьютера в виде компьютер.домен (если IP разрешается через сервер DNS в ЛВС)?
melik2k3
22 май 2023, 16:12
пробовал имя пк и статический ип
ошибка не уходит :sad:
27 окт 2023, 17:57
Интересно, а в итоге то вышло? :hoho:
