Kernel: 5.14.0-1033-oem x86_64 bits: 64 compiler: N/A Desktop: Xfce 4.16.0
Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Type: Laptop System: Dell product: Latitude 3420 v: N/A serial: <filter>
Mobo: Dell model: 0MKCWX v: A00 serial: <filter> UEFI: Dell v: 1.14.1
date: 12/15/2021
ID-1: BAT0 charge: 54.0 Wh condition: 54.0/54.0 Wh (100%)
model: BYD DELL WV3K817 status: Full
Topology: Quad Core model: 11th Gen Intel Core i5-1135G7 bits: 64
type: MT MCP arch: Tiger Lake rev: 1 L2 cache: 8192 KiB
bogomips: 22118
Speed: 920 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 1082 2: 1226
3: 1214 4: 1088 5: 1003 6: 952 7: 1155 8: 1128
Device-1: Intel vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.20.13 driver: modesetting
unloaded: fbdev,vesa resolution: 1920x1080~60Hz, 1920x1080~60Hz
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.2.6
Device-1: Intel vendor: Dell driver: sof-audio-pci-intel-tgl
bus ID: 00:1f.3
Sound Server: ALSA v: k5.14.0-1033-oem
Device-1: Intel driver: iwlwifi v: kernel port: 4000 bus ID: 00:14.3
IF: wlp0s20f3 state: down mac: <filter>
vendor: Dell driver: r8169 v: kernel port: 3000 bus ID: 2c:00.0
IF: enp44s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 238.47 GiB used: 23.19 GiB (9.7%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC711 NVMe 256GB
ID-1: / size: 31.83 GiB used: 19.63 GiB (61.7%) fs: ext4
dev: /dev/nvme0n1p5
ID-2: /home size: 42.02 GiB used: 3.48 GiB (8.3%) fs: ext4
dev: /dev/nvme0n1p7
ID-3: swap-1 size: 7.75 GiB used: 11.5 MiB (0.1%) fs: swap
dev: /dev/nvme0n1p6
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 329 Uptime: 3h 46m Memory: 7.52 GiB used: 4.47 GiB (59.4%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
date: 12/15/2021
bogomips: 22118
bus ID: 00:1f.3
dev: /dev/nvme0n1p5
dev: /dev/nvme0n1p7
dev: /dev/nvme0n1p6
inxi: 3.0.38
