Не работает перезагрузка системы
freefire78
27 мар 2022, 11:16
Здравствуйте. Не работает перезагрузка системы. Пробовал разные версии ОС, но везде одинаково.
Kernel: 5.4.0-105-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
Desktop: Cinnamon 5.2.7 Distro: Linux Mint 20.3 Una
base: Ubuntu 20.04 focal
Type: Laptop System: HP product: HP Laptop 15-da0xxx
v: Type1ProductConfigId serial: <filter>
Mobo: HP model: 84A7 v: 80.43 serial: <filter> UEFI [Legacy]: Insyde
v: F.23 date: 11/29/2019
ID-1: BAT1 charge: 33.8 Wh condition: 33.8/41.0 Wh (82%)
model: Hewlett-Packard PABAS0241231 status: Full
Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake rev: A L2 cache: 6144 KiB
bogomips: 28800
Speed: 620 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 627 2: 700
3: 700 4: 700 5: 700 6: 700 7: 700 8: 700
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0
Device-2: NVIDIA GM108M [GeForce MX110] vendor: Hewlett-Packard
driver: nvidia v: 470.103.01 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.13 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.6
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
Sound Server: ALSA v: k5.4.0-105-generic
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus ID: 02:00.0
IF: eno1 state: down mac: <filter>
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
vendor: Hewlett-Packard driver: rtw_pci v: N/A port: 3000 bus ID: 03:00.0
Device-3: Realtek 802.11n WLAN Adapter type: USB driver: btusb
bus ID: 1-6:3
Local Storage: total: 2.29 TiB used: 821.94 GiB (35.1%)
ID-1: /dev/nvme0n1 vendor: Addlink model: M.2 PCIE G3x4 NVMe
ID-2: /dev/sda vendor: Western Digital model: WD10SPZX-60Z10T0
ID-3: /dev/sdb type: USB vendor: Seagate model: ST1000LM035-1RK172
RAID:
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 bus ID: 00:17.0
ID-1: / size: 36.42 GiB used: 11.25 GiB (30.9%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /home size: 145.67 GiB used: 590.9 MiB (0.4%) fs: ext4
dev: /dev/nvme0n1p4
System Temperatures: cpu: 48.5 C mobo: 29.8 C
Processes: 275 Uptime: 6m Memory: 7.68 GiB used: 1.49 GiB (19.5%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
Mar 27 12:51:32 andrey-HP org.cinnamon.CalendarServer[2119]: SET TIME: from 2022-02-27T00:00:00+05 to 2022-04-09T23:59:59+05
Mar 27 12:51:33 andrey-HP systemd[1]: systemd-timedated.service: Succeeded.
Mar 27 12:51:41 andrey-HP cinnamon-session[1465]: WARNING: t+31.33333s: Detected that screensaver has left the bus
Mar 27 12:52:09 andrey-HP dbus-daemon[1473]: [session uid=1000 pid=1473] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.146' (uid=1000 pid=2429 comm="/usr/bin/gnome-terminal.real " label="unconfined")
Mar 27 12:52:09 andrey-HP systemd[1446]: Created slice apps.slice.
Mar 27 12:52:09 andrey-HP systemd[1446]: Created slice apps-org.gnome.Terminal.slice.
Mar 27 12:52:09 andrey-HP systemd[1446]: Starting GNOME Terminal Server...
Mar 27 12:52:09 andrey-HP dbus-daemon[1473]: [session uid=1000 pid=1473] Successfully activated service 'org.gnome.Terminal'
Mar 27 12:52:09 andrey-HP systemd[1446]: Started GNOME Terminal Server.
Mar 27 12:52:09 andrey-HP systemd[1446]: Started VTE child process 2440 launched by gnome-terminal-server process 2432.
Mar 27 12:52:13 andrey-HP systemd[1]: Stopping Session c2 of user andrey.
Mar 27 12:52:13 andrey-HP systemd[1]: Removed slice system-modprobe.slice.
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped target Bluetooth.
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped target Graphical Interface.
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped target Multi-User System.
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped target Login Prompts.
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped target Sound Card.
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped target Timers.
Mar 27 12:52:13 andrey-HP systemd[1]: anacron.timer: Succeeded.
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped Trigger anacron every hour.
Mar 27 12:52:13 andrey-HP systemd[1]: apt-daily-upgrade.timer: Succeeded.
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped Daily apt upgrade and clean activities.
Mar 27 12:52:13 andrey-HP systemd[1]: apt-daily.timer: Succeeded.
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped Daily apt download activities.
Mar 27 12:52:13 andrey-HP systemd[1]: e2scrub_all.timer: Succeeded.
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped Periodic ext4 Online Metadata Check for All Filesystems.
Mar 27 12:52:13 andrey-HP systemd[1]: fstrim.timer: Succeeded.
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped Discard unused blocks once a week.
Mar 27 12:52:13 andrey-HP cinnamon-session[1465]: WARNING: t+63.64972s: Application 'cinnamon-settings-daemon-screensaver-proxy.desktop' killed by signal 15
Mar 27 12:52:13 andrey-HP systemd[1]: fwupd-refresh.timer: Succeeded.
Mar 27 12:52:13 andrey-HP cinnamon-session[1465]: WARNING: t+63.64979s: Application 'cinnamon-settings-daemon-wacom.desktop' killed by signal 15
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped Refresh fwupd metadata regularly.
Mar 27 12:52:13 andrey-HP cinnamon-session[1465]: WARNING: t+63.64992s: Application 'cinnamon-settings-daemon-print-notifications.desktop' killed by signal 15
Mar 27 12:52:13 andrey-HP systemd[1]: logrotate.timer: Succeeded.
Mar 27 12:52:13 andrey-HP cinnamon-session[1465]: WARNING: t+63.64995s: Application 'cinnamon-settings-daemon-a11y-settings.desktop' killed by signal 15
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped Daily rotation of log files.
Mar 27 12:52:13 andrey-HP cinnamon-session[1465]: WARNING: t+63.64999s: Application 'cinnamon-settings-daemon-orientation.desktop' killed by signal 15
Mar 27 12:52:13 andrey-HP systemd[1]: man-db.timer: Succeeded.
Mar 27 12:52:13 andrey-HP cinnamon-session[1465]: WARNING: t+63.65001s: Application 'xapp-sn-watcher.desktop' killed by signal 15
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped Daily man-db regeneration.
Mar 27 12:52:13 andrey-HP systemd[1]: motd-news.timer: Succeeded.
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped Message of the Day.
Mar 27 12:52:13 andrey-HP systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
Mar 27 12:52:13 andrey-HP systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Mar 27 12:52:13 andrey-HP systemd[1]: lvm2-lvmpolld.socket: Succeeded.
Mar 27 12:52:13 andrey-HP systemd[1]: Closed LVM2 poll daemon socket.
Mar 27 12:52:13 andrey-HP systemd[1]: systemd-rfkill.socket: Succeeded.
Mar 27 12:52:13 andrey-HP systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Mar 27 12:52:13 andrey-HP systemd[1]: Stopping Modem Manager...
Mar 27 12:52:13 andrey-HP systemd[1]: Stopping Accounts Service...
Mar 27 12:52:13 andrey-HP systemd[1]: Stopping ACPI event daemon...
Mar 27 12:52:13 andrey-HP ModemManager[1054]: <info> caught signal, shutting down...
Mar 27 12:52:13 andrey-HP systemd[1]: Stopping Save/Restore Sound Card State...
Mar 27 12:52:13 andrey-HP systemd[1]: Stopping Availability of block devices...
Mar 27 12:52:13 andrey-HP bluetoothd[911]: Terminating
Mar 27 12:52:13 andrey-HP systemd[1]: Stopping Bluetooth service...
Mar 27 12:52:13 andrey-HP cinnamon-session[1465]: WARNING: t+63.65616s: Application 'cinnamon-settings-daemon-clipboard.desktop' killed by signal 15
Mar 27 12:52:13 andrey-HP systemd[1]: Stopping Manage, Install and Generate Color Profiles...
Mar 27 12:52:13 andrey-HP cinnamon-session[1465]: WARNING: t+63.65632s: Application 'cinnamon-settings-daemon-background.desktop' killed by signal 15
Mar 27 12:52:13 andrey-HP systemd[1]: Stopping Regular background program processing daemon...
Mar 27 12:52:13 andrey-HP cinnamon-session[1465]: WARNING: t+63.65635s: Application 'cinnamon-settings-daemon-color.desktop' killed by signal 15
Mar 27 12:52:13 andrey-HP systemd[1]: Stopping Make remote CUPS printers available locally...
Mar 27 12:52:13 andrey-HP cinnamon-session[1465]: WARNING: t+63.65637s: Application 'cinnamon-settings-daemon-keyboard.desktop' killed by signal 15
Я вижу, что система пытается остановить устройства. Но что делать дальше? Иногда перезагрузка нормально проходит. Обычно после установки каких-то обнов. Сейчас система свежая, кроме телеграма и вивальди ничего не установлено, но и без них было так же.
sheridan
Решено: 14
Благодарил (а): 900 раз
27 мар 2022, 11:28
freefire78, а если в консоли?
sudo reboot
freefire78
27 мар 2022, 11:32
Так это и было с консоли
systemctl reboot & tail -f /var/log/syslog | tee ~/reboot_attempt.log
С кнопки тоже самое происходит, а в системных логах пишет тоже самое.
sheridan
Решено: 14
27 мар 2022, 11:36
freefire78, Очень похоже что демон cinnamon-settings-daemon не может корректно завершить работу сервисов, а вот в чём причина мне сложно сказать (железо софт)
freefire78
27 мар 2022, 11:37
Есть методика точной диагностики?
sheridan
Решено: 14
27 мар 2022, 11:44
freefire78, для лаптопа не знаю, если системник начал бы с блока питаниия, затем память и.т.д
По софту я бы попробывал другую ОС (Manjaro, MXlinux), чтобы понят как железо ведёт себя на других осях.
freefire78
27 мар 2022, 11:49
Я пробовал LUBUNTU и Xbuntu там было тоже самое плюс бешенный жор аккума.
sheridan
Решено: 14
27 мар 2022, 11:56
freefire78, тогда есть проблема с железом
А безопасную загрузку в биосе отключил?
freefire78
27 мар 2022, 12:00
Погуглил похожие ошибки. Не нашел, то что подходило бы мне.
sheridan писал(а):
27 мар 2022, 11:59
freefire78, А безопастную загрузку в биосе отключил?
Вроде нет такого.
sheridan
Решено: 14
27 мар 2022, 12:01
freefire78, disable Secure Boot
freefire78
27 мар 2022, 12:06
У меня режим Legacy включен. Этот пункт не активен. Но светится Disable
sheridan
Решено: 14
27 мар 2022, 12:12
freefire78, покажи sudo fdisk -l
или лучше gparted
примерно так:
sheridan
Решено: 14
27 мар 2022, 12:24
freefire78, попробуй включить режим только UEFI и если в этом режиме не загрузится, не меняя параметра попробуй поставь начисто,
только подключи /boot/efi можно без форматирования
freefire78
27 мар 2022, 12:32
Попробовал. Тогда система не видит мой SSD. И флешку загрузочную тоже. Флешку делал через Unetbootin.
Последний раз редактировалось пользователем 1 freefire78; всего редактировалось раз: 27
sheridan
Решено: 14
27 мар 2022, 12:35
freefire78, похоже в этом проблема надо оставить режим только UEFI и ставить всё с чистого листа.
freefire78
27 мар 2022, 12:42
Так флешку не видит загрузочную в таком режиме.
это флешка
sheridan
Решено: 14
27 мар 2022, 12:43
freefire78, так ты наверное флешку не правильно создал.
freefire78
27 мар 2022, 12:46
freefire78 писал(а):
27 мар 2022, 12:32
Другого способа не знаю ))
Вернее не получилось по-другому
sheridan
Решено: 14
27 мар 2022, 13:02
freefire78, если винда то rufus, если linux то gnome-disk-utility, и.т.д
я использую ventoy не нужно каждый раз создавать флешку, только закидуешь образ и работаешь
