Ноутбук зависает из-за pulseaudio (но это не точно)
qwertyuiop123
22 мар 2022, 20:38
Всем привет. ОС: Linux Mint 20 Ulyana 64-битная. Вот что выводит
System: Kernel: 5.4.0-104-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Cinnamon 4.6.7
Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Machine: Type: Laptop System: HP product: HP Laptop 15-ra0xx v: Type1ProductConfigId serial: <filter>
Mobo: HP model: 832C v: 25.53 serial: <filter> UEFI: Insyde v: F.52 date: 03/04/2019
Battery: ID-1: BAT1 charge: 4.8 Wh condition: 5.3/31.1 Wh (17%) model: COMPAL PABAS0241231 status: Unknown
CPU: Topology: Dual Core model: Intel Celeron N3060 bits: 64 type: MCP arch: Airmont rev: 4 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 6400
Speed: 1262 MHz min/max: 480/2480 MHz Core speeds (MHz): 1: 1105 2: 1929
Graphics: Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics vendor: Hewlett-Packard
Display: x11 server: X.Org 1.20.13 driver: modesetting unloaded: fbdev,vesa resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 400 (BSW) v: 4.6 Mesa 21.2.6 direct render: Yes
Audio: Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.4.0-104-generic
Network: Device-1: Realtek RTL8723DE 802.11b/g/n PCIe Adapter vendor: Hewlett-Packard driver: rtw_pci v: N/A port: 2000
bus ID: 02:00.0
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: 1000 bus ID: 03:00.0
IF: eno1 state: down mac: <filter>
Device-3: Realtek Wireless Receiver type: USB driver: btusb bus ID: 1-5.3:5
Drives: Local Storage: total: 465.76 GiB used: 156.40 GiB (33.6%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB temp: 36 C
Partition: ID-1: / size: 456.96 GiB used: 156.39 GiB (34.2%) fs: ext4 dev: /dev/sda2
Sensors: System Temperatures: cpu: 44.0 C mobo: 27.8 C
Info: Processes: 203 Uptime: 52m Memory: 3.75 GiB used: 1.83 GiB (48.8%) Init: systemd runlevel: 5 Compilers: gcc: 9.4.0
clang: 10.0.0-4ubuntu1 Shell: bash v: 5.0.17 inxi: 3.0.38
А вот что выводят журналы:
22 мар 2022, 21:12
Расшифруйте, что значит "зависает"?
Если полностью виснет не реагируя ни на что, и даже курсор на мышь/тачпад не реагирует - в 95% случаев это признак аппаратной проблемы, и система вообще ни при чем.
P.S. Звук при этом может войти в "заикание" - будет циклически повторяться маленький фрагмент того, что воспроизводилось.
qwertyuiop123
23 мар 2022, 17:30
Ну да т.е. зависает все намертво: нет возможности сделать ничего. Вроде бы с windows такого не было. Если я не ошибаюсь то звук начинает повторяться циклически если при зависании смотрел шел звук. Почему-то такое происходит когда я сижу в браузере. Я попробовал обновить pulseaudio, но кажется стало только хуже.
23 мар 2022, 17:35
qwertyuiop123, в каком браузере? в firefox можно попробовать отключить аппаратное ускорение
23 мар 2022, 18:11
qwertyuiop123 писал(а):
23 мар 2022, 17:30
pulseaudio
оно тут не при делах
Вернуться в «Мультимедиа»
