бюджетный системник 2013 года и LM20.x
s681
Благодарил (а): 71 раз
23 фев 2022, 16:01
Всем доброго времени суток! Есть ли прирост в в отклике системы, быстродействии, экономии ресурсов от перехода на новую версию LM? Или нет смысла напрягать старушку?
System:    Host: serg-H81M-DS2 Kernel: 4.15.0-141-generic x86_64 bits: 64 compiler: gcc v: 7.5.0
           Desktop: Cinnamon 4.2.4 wm: muffin dm: LightDM Distro: Linux Mint 19.2 Tina
           base: Ubuntu 18.04 bionic
Machine:   Type: Desktop System: Gigabyte product: H81M-DS2 v: N/A serial: <filter> Chassis:
           type: 3 serial: <filter>
           Mobo: Gigabyte model: H81M-DS2 v: x.x serial: <filter> BIOS: American Megatrends v: F7
           date: 08/12/2015
Battery:   Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K330 serial: <filter>
           charge: 55% status: Discharging
           Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M215 2nd Gen serial: <filter>
           charge: 100% status: Discharging
CPU:       Topology: Dual Core model: Intel Pentium G3220 bits: 64 type: MCP arch: Haswell rev: 3
           L2 cache: 3072 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 11973
           Speed: 2993 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 2993 2: 2993
Graphics:  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
           vendor: Gigabyte driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0402
           Device-2: NVIDIA GK107 [GeForce GT 640] vendor: Micro-Star MSI driver: nvidia
           v: 470.103.01 bus ID: 01:00.0 chip ID: 10de:0fc1
           Display: x11 server: X.Org 1.19.6 driver: nvidia resolution: 1920x1080~60Hz
           OpenGL: renderer: NVIDIA GeForce GT 640/PCIe/SSE2 v: 4.6.0 NVIDIA 470.103.01
Audio:     Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio driver: snd_hda_intel
           v: kernel bus ID: 00:03.0 chip ID: 8086:0c0c
           Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte
           driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
           Device-3: NVIDIA GK107 HDMI Audio vendor: Micro-Star MSI driver: snd_hda_intel
           v: kernel bus ID: 01:00.1 chip ID: 10de:0e1b
           Sound Server: ALSA v: k4.15.0-141-generic
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
           driver: r8169 v: 2.3LK-NAPI port: d000 bus ID: 03:00.0 chip ID: 10ec:8168
Drives:    Local Storage: total: 2.05 TiB used: 1.53 TiB (74.5%)
           ID-1: /dev/sda model: SSDPR-CX400-256-G2 size: 238.47 GiB speed: 3.0 Gb/s
           serial: <filter>
           ID-2: /dev/sdb vendor: Western Digital model: WD20EZRX-00D8PB0 size: 1.82 TiB
           speed: 3.0 Gb/s serial: <filter>
Partition: ID-1: / size: 223.93 GiB used: 150.00 GiB (67.0%) fs: ext4 dev: /dev/sda1
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
           Hub: 1-1:2 info: Intel ports: 4 rev: 2.0 chip ID: 8087:8008
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
           Hub: 2-1:2 info: Intel ports: 6 rev: 2.0 chip ID: 8087:8000
           Hub: 3-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 chip ID: 1d6b:0002
           Hub: 3-7:2 info: Super Top ports: 4 rev: 2.0 chip ID: 14cd:8601
           Device-1: 3-7.3:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
           driver: logitech-djreceiver,usbhid rev: 2.0 chip ID: 046d:c52b
           Device-2: 3-8:3 info: Super Top type: Mass Storage driver: usb-storage rev: 2.0
           chip ID: 14cd:168a
           Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 chip ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 37 C
           Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Repos:     No active apt repos in: /etc/apt/sources.list
           Active apt repos in: /etc/apt/sources.list.d/astroncia-iptv-bionic.list
           1: deb http: //ppa.launchpad.net/astroncia/iptv/ubuntu bionic main
           1: deb http: //packages.linuxmint.com tina main upstream import backport #id:linuxmint_main
           2: deb http: //archive.ubuntu.com/ubuntu bionic main restricted universe multiverse
           3: deb http: //archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
           4: deb http: //archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse
           5: deb http: //security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
           6: deb http: //archive.canonical.com/ubuntu/ bionic partner
Info:      Processes: 213 Uptime: 7h 03m Memory: 5.72 GiB used: 1.68 GiB (29.4%) Init: systemd
           v: 237 runlevel: 5 Compilers: gcc: 7.5.0 alt: 7 Client: Unknown python3.6 client
           inxi: 3.0.32
Whowka
Благодарил (а): 777 раз
23 фев 2022, 16:17
s681, Примерно одинаково, на глаз незаметно, ежели тока на сеундомере с тысячными не замерять. :smile:
s681
24 фев 2022, 15:40
А вот каждая новая версия Винды дает прирост производительности и добавляет функциональности системе :joke:
ilikethat
Решено: 10
Благодарил (а): 129 раз
24 фев 2022, 15:54
s681, тогда, с учетом того, сколько версий винды вышло с момента создания Вашего проца, он должен был попасть в Top500 суперкомпьютеров! :-D
s681
24 фев 2022, 15:56
Это была шутка
