systemd-analyze
Startup finished in 7.389s (kernel) + 3.084s (userspace) = 10.474s
graphical.target reached after 3.078s in userspace
Фрагмент вывода dmesg
1.754272] sd 5:0:0:0: Attached scsi generic sg2 type 0
[ 1.754419] sd 4:0:0:0: [sda] Attached SCSI disk
[ 1.758700] [drm] Cannot find any crtc or sizes
[ 1.820011] tsc: Refined TSC clocksource calibration: 2993.069 MHz
[ 1.820015] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b24b1963f3, max_idle_ns: 440795227598 ns
[ 2.080103] input: Logitech K330 as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.2/0003:046D:C52B.0003/0003:046D:4016.0005/input/input6
[ 2.080147] logitech-hidpp-device 0003:046D:4016.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech K330] on usb-0000:00:14.0-1:2
[ 2.384829] sdb: sdb1 sdb2 sdb3
[ 2.385273] sd 5:0:0:0: [sdb] Attached SCSI disk
[ 2.587413] random: fast init done
[ 2.588603] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 2.588626] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 2.588701] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 2.844142] clocksource: Switched to clocksource tsc
[ 6.779971] raid6: sse2x1 gen() 10363 MB/s
[ 6.827968] raid6: sse2x1 xor() 7251 MB/s
[ 6.875974] raid6: sse2x2 gen() 12183 MB/s
[ 6.923968] raid6: sse2x2 xor() 7955 MB/s
systemd-analyze
Startup finished in 3.720s (kernel) + 4.062s (userspace) = 7.783s
graphical.target reached after 3.918s in userspace
dmesg
1.735518] sd 4:0:0:0: [sda] Attached SCSI disk
[ 1.739840] [drm] Cannot find any crtc or sizes
[ 1.820009] tsc: Refined TSC clocksource calibration: 2993.069 MHz
[ 1.820013] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b24b1963f3, max_idle_ns: 440795227598 ns
[ 2.363819] sdb: sdb1 sdb2 sdb3
[ 2.364065] sd 5:0:0:0: [sdb] Attached SCSI disk
[ 2.715273] random: fast init done
[ 2.716209] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 2.716217] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 2.716226] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 2.844145] clocksource: Switched to clocksource tsc
[ 3.103983] raid6: sse2x1 gen() 10355 MB/s
[ 3.151983] raid6: sse2x1 xor() 7211 MB/s
[ 3.199979] raid6: sse2x2 gen() 12443 MB/s
[ 3.247981] raid6: sse2x2 xor() 7886 MB/s
Есть относительно простой способ решить нюанс или забить?
система
System: Host: serg-H81M-DS2 Kernel: 4.15.0-141-generic x86_64 bits: 64 compiler: gcc v: 7.5.0
Desktop: Cinnamon 4.2.4 wm: muffin dm: LightDM Distro: Linux Mint 19.2 Tina
base: Ubuntu 18.04 bionic
Machine: Type: Desktop System: Gigabyte product: H81M-DS2 v: N/A serial: <filter> Chassis:
type: 3 serial: <filter>
Mobo: Gigabyte model: H81M-DS2 v: x.x serial: <filter> BIOS: American Megatrends v: F7
date: 08/12/2015
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M215 2nd Gen serial: <filter>
charge: 100% status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K330 serial: <filter>
charge: 55% status: Discharging
CPU: Topology: Dual Core model: Intel Pentium G3220 bits: 64 type: MCP arch: Haswell rev: 3
L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 11972
Speed: 2993 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 2944 2: 2897
Graphics: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0402
Device-2: NVIDIA GK107 [GeForce GT 640] vendor: Micro-Star MSI driver: nvidia v: 470.86
bus ID: 01:00.0 chip ID: 10de:0fc1
Display: x11 server: X.Org 1.19.6 driver: nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GT 640/PCIe/SSE2 v: 4.6.0 NVIDIA 470.86
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
Device-3: NVIDIA GK107 HDMI Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:0e1b
Sound Server: ALSA v: k4.15.0-141-generic
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
driver: r8169 v: 2.3LK-NAPI port: d000 bus ID: 03:00.0 chip ID: 10ec:8168
Drives: Local Storage: total: 2.05 TiB used: 1.55 TiB (75.3%)
ID-1: /dev/sda model: SSDPR-CX400-256-G2 size: 238.47 GiB speed: 3.0 Gb/s
serial: <filter>
ID-2: /dev/sdb vendor: Western Digital model: WD20EZRX-00D8PB0 size: 1.82 TiB
speed: 3.0 Gb/s serial: <filter>
Partition: ID-1: / size: 223.93 GiB used: 133.51 GiB (59.6%) fs: ext4 dev: /dev/sda1
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel ports: 4 rev: 2.0 chip ID: 8087:8008
Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
Hub: 2-1:2 info: Intel ports: 6 rev: 2.0 chip ID: 8087:8000
Hub: 3-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 chip ID: 1d6b:0002
Device-1: 3-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
driver: logitech-djreceiver,usbhid rev: 2.0 chip ID: 046d:c52b
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Repos: No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/astroncia-iptv-bionic.list
1: deb http: //ppa.launchpad.net/astroncia/iptv/ubuntu bionic main
1: deb http: //packages.linuxmint.com tina main upstream import backport #id:linuxmint_main
2: deb http: //archive.ubuntu.com/ubuntu bionic main restricted universe multiverse
3: deb http: //archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
4: deb http: //archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
6: deb http: //archive.canonical.com/ubuntu/ bionic partner
Info: Processes: 191 Uptime: 27m Memory: 5.72 GiB used: 1.47 GiB (25.7%) Init: systemd v: 237
runlevel: 5 Compilers: gcc: 7.5.0 alt: 7 Client: Unknown python3.6 client inxi: 3.0.32
date: 08/12/2015
L2 cache: 3072 KiB
serial: <filter>
