Ошибка обновления 19 Tara
r33
Благодарил (а): 15 раз
09 янв 2022, 20:25
LM19Tara x64
Пробу показать не могу( в подписи не актуальная, железо другое сейчас)-пишет команда не найдена. Ошибка в обновлении. Также пишет кэш apt повреждён.
Подскажите, пожалуйста, что можно сделать?
System: Host: rmd-HP-EliteBook-745-G2 Kernel: 4.15.0-166-generic x86_64
bits: 64 gcc: 7.5.0
Desktop: MATE 1.20.1 (Gtk 3.22.30-1ubuntu4)
Distro: Linux Mint 19 Tara
Machine: Device: laptop System: Hewlett-Packard product: HP EliteBook 745 G2 v: A3009DD10303 serial: N/A
Mobo: Hewlett-Packard model: 221C v: KBC Version 63.19 serial: N/A
UEFI: Hewlett-Packard v: M84 Ver. 01.48 date: 07/30/2018
Battery BAT0: charge: 34.8 Wh 96.5% condition: 36.1/36.1 Wh (100%)
model: Hewlett-Packard Primary status: Charging
CPU: Quad core AMD A8 PRO-7150B R5 10 Compute Cores 4C+6G (-MCP-)
arch: Steamroller rev.1 cache: 8192 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 15170
clock speeds: max: 1900 MHz 1: 1494 MHz 2: 1392 MHz 3: 1492 MHz
4: 1491 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Kaveri [Radeon R6 Graphics]
bus-ID: 00:01.0
drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
Resolution: 1600x900@60.01hz
OpenGL: renderer: AMD KAVERI (DRM 2.50.0, 4.15.0-166-generic, LLVM 10.0.0)
version: 4.5 Mesa 20.0.8 Direct Render: Yes
Audio: Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller
Card-2 Advanced Micro Devices [AMD/ATI] Kaveri HDMI/DP Audio Controller
driver: snd_hda_intel bus-ID: 00:01.1
Sound: Advanced Linux Sound Architecture v: k4.15.0-166-generic
Network: Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
driver: r8169 v: 2.3LK-NAPI port: 4000 bus-ID: 01:00.0
IF: enp1s0f0 state: down mac: <filter>
Card-2: Broadcom and subsidiaries BCM4352 802.11ac Wireless Network Adapter
driver: wl bus-ID: 02:00.0
Drives: HDD Total Size: 128.0GB (10.0% used)
ID-1: /dev/sda model: SAMSUNG_MZ7TE128 size: 128.0GB temp: 0C
Partition: ID-1: / size: 46G used: 7.1G (17%) fs: ext4 dev: /dev/sda6
ID-2: /home size: 9.2G used: 3.1G (36%) fs: ext4 dev: /dev/sda7
ID-3: swap-1 size: 2.00GB used: 0.00GB (0%)
fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 65.0C mobo: 0.0C gpu: 67.0
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 210 Uptime: 5:21 Memory: 2244.2/6978.6MB
Init: systemd runlevel: 5 Gcc sys: 7.5.0
Client: Shell (bash 4.4.201) inxi: 2.3.56
LM 21.1 MATE x64
HW probe
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
09 янв 2022, 20:41
Дистрибутив - Тара (19 просто), а на скрине ошибки - Tricia (19.3)
Что команда cat /etc/apt/sources.list.d/official-package-repositories.list кажет, если не секрет?
r33
09 янв 2022, 21:14
Ара Магеддон писал(а):
09 янв 2022, 20:41
у меня 19, на 19.3 предлагается обновиться
deb http://packages.linuxmint.com tricia main upstream import backport #id:linuxmint_main
deb http://archive.ubuntu.com/ubuntu bionic main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
deb http://archive.canonical.com/ubuntu/ bionic partner
ещё в источнике приложений зеркала слетают.
LM 21.1 MATE x64
HW probe
Ара Магеддон
Решено: 18
09 янв 2022, 21:24
Значит, что-то пошло не так в процессе обновления.
В общем, можно открыть sudo nano /etc/apt/sources.list.d/official-package-repositories.list и поменять там "tricia" на "tara". Сохранить изменения. После чего sudo apt update и sudo apt upgrade.
Должно помочь. Но если не поможет - то будем дальше разбираться))
09 янв 2022, 22:02
Если действительно поврежден кеш apt - это в морг. Т.е. только переустанавливать. Там база данных в которой хранится текущее состояние системы (какие пакеты установлены, какие у них зависимости, и т.д.), без которой apt нормально работать не может. И простым удалением битых файлов тут ничего не решить.
r33
09 янв 2022, 22:14
09 янв 2022, 22:02
О-о, это печально, а как узнать наверняка?
LM 21.1 MATE x64
HW probe
09 янв 2022, 22:36
r33 писал(а):
09 янв 2022, 22:14
узнать наверняка
Сперва отчисти то, чем ты набил архив.
cd /var/cache/apt/archives
sudo rm -rf *.deb
Потом поменяй свой sources.list на нормальный
Ну а после всего
sudo apt update
sudo apt install --fix-broken
sudo apt install --fix-missing
И только после этого(с дрожащей рукой) делаешь
sudo apt update && sudo apt upgrade
09 янв 2022, 22:45
А позднее не пробовали проверить обновления? Впечатление складывается, что или packages.linuxmint.com перегружен запросами (все кинулись обновляться?) или с вашим интернет какие-то временные проблемы. На мой взгляд, не очень хорошей идеей было отказаться с своё время от переключения на ближайшие региональные репозитории.
r33
10 янв 2022, 08:03
madesta писал(а):
09 янв 2022, 22:45
да,иногда проверка проходит успешно, без ошибок
vir0id писал(а):
09 янв 2022, 22:36
у меня вот такой
madesta писал(а):
09 янв 2022, 22:45
да, вот проблема при обновлении
интернет мобильный
LM 21.1 MATE x64
HW probe
10 янв 2022, 13:01
r33 писал(а):
10 янв 2022, 08:03
проблема
Ну вроде тот самый. Только я бы не брал яндекс, а мировой. Насколько яя помню, т.е сталкивался, что яндекс временами глючил.
Vaspet
Благодарил (а): 31 раз
10 янв 2022, 14:37
У меня МТС (как и другие) блокирует торренты. Два дня получал обновление LM20.3, периодически получая похожие сообщения: "сервер сообщает об ошибке подключения, попробуйте подключиться попозже". И вчера все же обновился при этом сообщении. Может и здесь такое?
Мигрант От win10 к Linux Mint 21.1
r33
10 янв 2022, 16:36
vir0id писал(а):
10 янв 2022, 13:01
яндекс
Пробовал другие российские, также белорусский. Проблема остаётся. Ещё после попытки обновления, слетают установленные зеркала в источниках приложений, на US/GB.
LM 21.1 MATE x64
HW probe
