Не видит второй второй монитор
vicctor
22 дек 2021, 17:41
Подключил к ноутбуку по HDMI второй монитор, но почему-то Linux Mint его не видит.
  Kernel: 5.13.0-22-generic x86_64 bits: 64 compiler: N/A
  Desktop: Cinnamon 5.0.7 Distro: Linux Mint 20.2 Uma
  base: Ubuntu 20.04 focal
  Type: Laptop System: Razer
  product: Blade 15 Base Model (Early 2021) - RZ09-0369 v: 6.04
  serial: <filter>
  Mobo: Razer model: DA560 v: 4 serial: <filter> UEFI: Razer v: 1.00
  date: 01/04/2021
  ID-1: BAT0 charge: 64.8 Wh condition: 64.8/65.0 Wh (100%)
  model: Razer Blade status: Full
  Topology: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP
  arch: N/A L2 cache: 12.0 MiB
  bogomips: 62399
  Speed: 900 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 900 2: 899
  3: 1599 4: 1757 5: 3306 6: 3965 7: 2442 8: 1986 9: 1859 10: 2870 11: 1534
  12: 1827
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Razer USA
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
  vendor: Razer USA driver: N/A bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.13 driver: modesetting
  unloaded: fbdev,vesa resolution: 1920x1080~144Hz
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.0.3
  Device-1: Intel Comet Lake PCH cAVS vendor: Razer USA
  Device-2: NVIDIA vendor: Razer USA driver: snd_hda_intel v: kernel
  bus ID: 01:00.1
  Sound Server: ALSA v: k5.13.0-22-generic
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
  port: 5000 bus ID: 00:14.3
  vendor: Razer USA driver: r8169 v: kernel port: 3000 bus ID: 02:00.0
  Device-3: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
  bus ID: 2-1:2
  IF: enx74da38ffc537 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
  Local Storage: total: 476.94 GiB used: 188.70 GiB (39.6%)
  ID-1: /dev/nvme0n1 model: NVMe CA5-8D512 size: 476.94 GiB
  ID-1: / size: 466.30 GiB used: 94.29 GiB (20.2%) fs: ext4 dev: /dev/dm-1
  ID-2: /boot size: 704.5 MiB used: 122.9 MiB (17.4%) fs: ext4
  dev: /dev/nvme0n1p2
  ID-3: swap-1 size: 980.0 MiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-2
  System Temperatures: cpu: 53.0 C mobo: N/A
  Processes: 421 Uptime: 4h 06m Memory: 15.49 GiB used: 5.73 GiB (37.0%)
  inxi: 3.0.38
Благодарил (а): 1736 раз
22 дек 2021, 17:44
ну так Fn+Монитор наверное надо тыкнуть
vicctor
23 дек 2021, 10:41
22 дек 2021, 17:44
Мне знакома клавиша Fn, но формулировка "+Монитор" вводит меня в недоумение)
23 дек 2021, 10:44
vicctor, изображение монитора... хз как её обозвать по другому :) переключает на буках выход на основной экран, на внешний, на основной+внешний
Благодарил (а): 794 раза
23 дек 2021, 11:23
vicctor, в твоем случае, если не ошибаюсь, это кнопка F4
vicctor
24 дек 2021, 10:19
23 дек 2021, 11:23
Не помогло, к сожалению. На мониторе "Нет сигнала".
24 дек 2021, 10:43
Некоторые hdmi кабели, особенно китайские, фигово себя ведут под нагрузкой. Может попробуй кабель подкинуть получше?
24 дек 2021, 11:15
Есть вероятность, что для вывод на внешний монитор нужно активировать дискретную видяху.
А у тебя даже драйвер на нее не установлен
vicctor писал(а):
22 дек 2021, 17:41
volp
24 дек 2021, 11:42
24 дек 2021, 11:15
Стало интересно, так как имею ноут с неработающей, а соответственно отключенной дискреткой Radeon на LM20 . Результаты эксперимента - телевизор подключение опознает , выбор данного канала HDMI активен, а изображения нет , как будто девайс с той стороны кабеля выключен. Ну и на ноуте Fn+ монитор тоже ничего не включают.
