acer aspire A317 сетевой кабель не подключен
seregka
Благодарил (а): 2 раза
19 дек 2021, 04:50
Друзья доброго времени
Такая беда влючю сто процентов рабочий LAN а компу похер пишет не подключен:
00:00.0 Host bridge: Intel Corporation Gemini Lake Host Bridge (rev 06)
00:00.3 System peripheral: Intel Corporation Device 3190 (rev 06)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 605 (rev 06)
00:0e.0 Audio device: Intel Corporation Device 3198 (rev 06)
00:0f.0 Communication controller: Intel Corporation Celeron/Pentium Silver Processor Trusted Execution Engine Interface (rev 06)
00:12.0 SATA controller: Intel Corporation Device 31e3 (rev 06)
00:13.0 PCI bridge: Intel Corporation Gemini Lake PCI Express Root Port (rev f6)
00:13.3 PCI bridge: Intel Corporation Gemini Lake PCI Express Root Port (rev f6)
00:14.0 PCI bridge: Intel Corporation Gemini Lake PCI Express Root Port (rev f6)
00:15.0 USB controller: Intel Corporation Device 31a8 (rev 06)
00:16.0 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO I2C Host Controller (rev 06)
00:16.1 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO I2C Host Controller (rev 06)
00:16.2 Signal processing controller: Intel Corporation Device 31b0 (rev 06)
00:16.3 Signal processing controller: Intel Corporation Device 31b2 (rev 06)
00:17.0 Signal processing controller: Intel Corporation Device 31b4 (rev 06)
00:17.1 Signal processing controller: Intel Corporation Device 31b6 (rev 06)
00:17.2 Signal processing controller: Intel Corporation Device 31b8 (rev 06)
00:17.3 Signal processing controller: Intel Corporation Device 31ba (rev 06)
00:1f.0 ISA bridge: Intel Corporation Device 31e8 (rev 06)
00:1f.1 SMBus: Intel Corporation Celeron/Pentium Silver Processor Gaussian Mixture Model (rev 06)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
02:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
03:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. Device 5008 (rev 01)
*-network
описание: Ethernet interface
продукт: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
производитель: Realtek Semiconductor Co., Ltd.
физический ID: 0
сведения о шине: pci@0000:01:00.0
логическое имя: enp1s0
версия: 15
серийный №: 08:97:98:d9:9d:17
capacity: 1Gbit/s
разрядность: 64 bits
частота: 33MHz
возможности: pm msi pciexpress msix bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
конфигурация: autonegotiation=on broadcast=yes driver=r8168 driverversion=8.048.00-NAPI latency=0 link=no multicast=yes port=twisted pair
ресурсы: IRQ:127 ioport:2000(размер=256) память:a1304000-a1304fff память:a1300000-a1303fff
*-network
продукт: Wi-Fi 6 AX200
производитель: Intel Corporation
физический ID: 0
сведения о шине: pci@0000:02:00.0
логическое имя: wlp2s0
версия: 1a
серийный №: 10:51:07:4e:c5:aa
частота: 33MHz
конфигурация: broadcast=yes driver=iwlwifi driverversion=5.4.0-91-generic firmware=63.c04f3485.0 cc-a0-63.ucode ip=192.168.1.100 latency=0 link=yes multicast=yes
ресурсы: IRQ:21 память:a1200000-a1203fff
Я не исключаю и аппоратной поломки подскажите какой нибудь дистрибутив виндовс чтобы можно было проверить сетевую карту без устанвки виндовс
Решение slant » 23 дек 2021, 16:16
seregka писал(а):
23 дек 2021, 16:00
Кабель что включен что выключен выхлоп один и тот же
И, судя по выхлопу - карта его не опознает, т.е. физически линк отсутствует. Кроме перебитого кабеля, это может быть вызвано сдохшим портом на карте, либо недо/переобжатым коннектором на кабеле.
Поясняю последнее - если коннектор недообжат, то нож контактной площадки недостаточно вошел в жилу кабеля, и контакт плохой. Можно просто дожать обжимкой, в большинстве случаев. Если коннектор пережат - нож перерубает жилу полностью и тоже начинается плохой контакт. Здесь уже только срезать коннектор, и обжимать заново. Иногда, как вариант - просто слишком глубоко продавливается контактная площадка, и контакт в гнезде её не достает как следует. (В этом случае кабель даже может работать в одном гнезде, но в другом - нет.)
Будьте добрее к этому миру, даже если мир не добр к вам.
sheridan
Решено: 14
Благодарил (а): 900 раз
19 дек 2021, 09:25
seregka, WinPE
19 дек 2021, 10:11
seregka, а покажи вывод
lspci -knn | grep -A2 "Eth"
seregka
19 дек 2021, 12:26
19 дек 2021, 10:11
01:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
Subsystem: Acer Incorporated [ALI] RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [1025:1395]
Kernel driver in use: r8169
Kernel modules: r8169
19 дек 2021, 12:44
seregka писал(а):
19 дек 2021, 04:50
А в настройках NM что творится? DHCP автоматом выставлен?
И еще sudo ifconfig в студию
seregka
19 дек 2021, 13:40
вот sudo ifconfig
[sudo] пароль для seregka:
enp1s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 08:97:98:d9:9d:17 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Локальная петля (Loopback))
RX packets 33607 bytes 30208395 (30.2 MB)
TX packets 33607 bytes 30208395 (30.2 MB)
wlp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.100 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::9b04:8217:1d97:2c14 prefixlen 64 scopeid 0x20<link>
ether 10:51:07:4e:c5:aa txqueuelen 1000 (Ethernet)
RX packets 4366139 bytes 6511953924 (6.5 GB)
TX packets 1590169 bytes 158834479 (158.8 MB)
19 дек 2021, 14:35
Вообще-то здесь нужно несколько с другого начинать. Стоит посмотреть вывод команды sudo ethtool enp1s0
Правда я не помню стоит ли она в минте по умолчанию. Если не стоит - нужно доустановить пакет ethtool. Т.к. WiFi живое, с этим проблем быть не должно...
seregka
23 дек 2021, 16:00
sudo ethtool enp1s0
Settings for enp1s0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Speed: Unknown!
Duplex: Unknown! (255)
Port: MII
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: pumbg
Wake-on: d
Current message level: 0x00000033 (51)
drv probe ifdown ifup
Link detected: no
23 дек 2021, 16:16
seregka писал(а):
23 дек 2021, 16:00
23 дек 2021, 16:33
23 дек 2021, 16:16
Лично у меня наблюдались случаи периодического неконтакта: коннекторы в порядке, а вот в самом кабеле на расстоянии 50-60 см. от коннектора что-то внутри не совсем контачило. Причем на внешний осмотр никаких поверждений не наблюдалось. Обнаружено было совершенно случайно: чуть согнул кабель в том месте и контакт появился.
Последний раз редактировалось пользователем 1 madesta; всего редактировалось раз: 23
sheridan
Решено: 14
23 дек 2021, 16:53
В электричестве два основных вида неисправностей:
1-Отсутствие контакта там где он нужен
2-Хороший контакт там где он не нужен
:smile:
23 дек 2021, 17:48
sheridan писал(а):
23 дек 2021, 16:53
В электричестве - да.
А вот в электронике - увы все не так просто. Наводки полей, неправильная емкость, частота, сопротивление, и т.д. и т.п. :)
Whowka
Благодарил (а): 777 раз
23 дек 2021, 22:10
23 дек 2021, 17:48
sheridan писал(а):
23 дек 2021, 16:53
И в электронике это тоже основные( не все, но основные). Сгорел резистор, пробит транзистор. :-D
23 дек 2021, 23:04
Whowka писал(а):
23 дек 2021, 22:10
Ходил я в радиокружок в свое время. Не очень долго, т.к. дело было затратное (90-ые, детали за свой счет :) ). И вынес я оттуда в основном то, что "наука о контактах" - это именно электрика. А с электроникой - это совсем даже не основной набор неисправностей. Особенно, если речь идет о аналоговой части. :) Если у схемы уплыла частота, или параметры питания - работать оно будет в лучшем случае не так как задумывалось. А в худшем - не будет вообще. А уплыть оно может по куче причин, где полный выход из строя детали далеко не самое частое явление...
А уж как весело наводки искать... :)
sheridan
Решено: 14
24 дек 2021, 08:46
slant, А бывает всё сделал правильно а транзистор не в режиме греется и канал хрипит, без осцилографа не видно что там возбуд на частоте 3 мгц, добавил небольшую ёмкость и возбуд пропал.
24 дек 2021, 08:55
ТС не отписывается. Наверное, просто заменил кабель, и всё попёрло :-D А признаться стыдно :crazy:
24 дек 2021, 13:18
vir0id писал(а):
24 дек 2021, 08:55
По иронии судьбы, большинство всех кажущихся на первый взгляд очень сложных неисправностей имеют простую причину.
Например, долго искал дома причину не совсем приемлемого уровня Overal Tx CCQ. Оказалось, что на своём пути сигнал wifi проходит через системный блок стоящего рядом другого компьютера. Потом долго поражался своей ... :-D , потому что стоило только небольшим удлиннителем вывести втыкаемый в usb модем wifi в сторону, как по мановению волшебной палочки Overal Tx CCQ с 35-40% сразу же поднялся до 85-95%.
seregka
27 дек 2021, 19:34
Друзья причина была в порте спасибо мил человеку
