Скорость передачи по WiFi
volp
17 дек 2021, 22:40
Всем привет ! Имеем следующий
ifconfig
enp0s8: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 00:16:17:d3:b5:c4  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
enp0s9: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.100.4  netmask 255.255.255.0  broadcast 192.168.100.255
        inet6 fe80::1c78:d816:364c:223f  prefixlen 64  scopeid 0x20<link>
        ether 00:16:17:d8:15:13  txqueuelen 1000  (Ethernet)
        RX packets 144706  bytes 120349128 (120.3 MB)
        TX packets 189482  bytes 60994929 (60.9 MB)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Локальная петля (Loopback))
        RX packets 39186  bytes 2465719 (2.4 MB)
        TX packets 39186  bytes 2465719 (2.4 MB)
virbr0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 192.168.122.1  netmask 255.255.255.0  broadcast 192.168.122.255
        ether 52:54:00:94:3a:fc  txqueuelen 1000  (Ethernet)
wlp3s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.42.0.1  netmask 255.255.255.0  broadcast 10.42.0.255
        inet6 fe80::d56f:737c:4c78:70f1  prefixlen 64  scopeid 0x20<link>
        ether 64:70:02:dc:03:f5  txqueuelen 1000  (Ethernet)
        RX packets 18438  bytes 21429592 (21.4 MB)
        TX packets 27290  bytes 25262227 (25.2 MB)
wlx002e2d300fc4: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.42.1.1  netmask 255.255.255.0  broadcast 10.42.1.255
        inet6 fe80::a4c0:20bd:42e0:127e  prefixlen 64  scopeid 0x20<link>
        ether 00:2e:2d:30:0f:c4  txqueuelen 1000  (Ethernet)
        RX packets 34640  bytes 53249029 (53.2 MB)
        RX errors 0  dropped 16  overruns 0  frame 0
        TX packets 7210  bytes 773767 (773.7 KB)
        TX errors 0  dropped 277 overruns 0  carrier 0  collisions 0
То есть два WiFi модуля включены как AP. Первый , который wlp3s0 - PCI-E 300Mbps 2,4Ghz , второй wlx002e2d300fc4 - usb 433Mbps 5Ghz на чипе RTL8811. Основная задача - гонять файлы с и на Android. Тест дает такие цифры
iperf -s
Server listening on TCP port 5001
TCP window size:  128 KByte (default)
[  4] local 10.42.0.1 port 5001 connected with 10.42.0.51 port 41066
[ ID] Interval       Transfer     Bandwidth
[  4]  0.0-10.6 sec  18.9 MBytes  15.0 Mbits/sec
[  4] local 10.42.1.1 port 5001 connected with 10.42.1.228 port 44496
[  4]  0.0-10.3 sec  46.9 MBytes  38.3 Mbits/sec
Что касается реальной передачи файлов (пробовал и через ftp и через samba) , то в первом варианте 4.5Mb/s , во втором 7,5 Mb/s -максимальная скорость. Эти цифры примерно соотносятся с тем, что мне показывает speedtest с андроида . А что показывает мне iperf ?
17 дек 2021, 22:54
А что тебя не устраивает? Что ты тут крименального увидел? Все показатели говорят что 5Ghz быстрее. Я не понимаю что ты хочешь спросить
volp
17 дек 2021, 22:58
Transfer 46.9 MBytes Bandwidth - 38.3 Mbits/sec . Как это привязать к 7,5Mb/s
17 дек 2021, 23:01
volp писал(а):
17 дек 2021, 22:40
Ну умнож на 8. Получи примерную цифру
volp
17 дек 2021, 23:07
vir0id писал(а):
17 дек 2021, 23:01
Я знаю, в чем разница между байтом и битом .Умножаем 7,5 на 8 , никак не получаем 46,9 . Я бы понял , если бы у iperf цифры получились больше - ну там всякие потери , контрольные биты и т.п. Но тут меньше получается. Чем еще можно протестить с Androidа ?
Так стоп, а почему умножаем, там же указаны именно мегабайты
46.9 MBytes
Тогда вообще непонятно что показывает эта утилита.
Последний раз редактировалось пользователем 1 volp; всего редактировалось раз: 17
Whowka
Благодарил (а): 777 раз
17 дек 2021, 23:11
volp,
vir0id писал(а):
17 дек 2021, 22:54
:smile:
17 дек 2021, 23:13
volp писал(а):
17 дек 2021, 23:07
с Androidа
Каждая прога даёт свои показатели. Какая из них точнее - хз. Потести лучше свою точку доступа. Куда она трафик раскидывает - я х3
17 дек 2021, 23:14
volp писал(а):
17 дек 2021, 23:07
мегабайты
Мегабиты
17 дек 2021, 23:15
volp писал(а):
17 дек 2021, 22:40
биты с малкенькой буквы. А мегабайте с больгой
volp
17 дек 2021, 23:16
Тесты идут не с точки доступа а с клиента android .
volp
17 дек 2021, 23:18
vir0id писал(а):
17 дек 2021, 23:15
:dash2: Тогда все сходится :yahoo:
Вот только как же быть с такой записью
Все таки MBytes - это мегабайты :-D
17 дек 2021, 23:20
volp писал(а):
17 дек 2021, 23:18
Тогда все сходится
Ну и ладненько
17 дек 2021, 23:27
volp писал(а):
17 дек 2021, 23:18
Просто читается это так: "...передано 46.9 MBytes со (средней) скоростью 38.3 Mbits/sec".
Первая цифра - не скорость, а количество данных.
18 дек 2021, 09:40
vir0id писал(а):
17 дек 2021, 23:15
Это если разработчик утилиты/приложения задумался об этом и сделал чтоб было понятно пользователям, а то ведь мог ткнуть букву как захотелось
volp писал(а):
17 дек 2021, 23:18
Учиться правильно интерпретировать результаты, полученные от используемой утилиты/приложения
18 дек 2021, 10:08
18 дек 2021, 09:40
Ну как правила, стараются делать именно так. Мне другой вариант еще не попадался
Вернуться в «Работа с сетью»
