!osu в linux mint
lohh
!osu в linux mint
01 дек 2021, 20:04
Linux Mint Cinnamon 20.2 x64
Железо:
Kernel: 5.4.0-74-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 5.0.7 Distro: Linux Mint 20.2 Uma
base: Ubuntu 20.04 focal
Type: Laptop System: ASUSTeK product: K56CB v: 1.0 serial: <filter>
Mobo: ASUSTeK model: K56CB v: 1.0 serial: <filter>
UEFI: American Megatrends v: K56CB.205 date: 03/13/2013
ID-1: BAT0 charge: 2.4 Wh condition: 5.3/44.6 Wh (12%)
model: ASUSTeK K56--30 status: Charging
Topology: Dual Core model: Intel Core i3-3217U bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 14367
Speed: 798 MHz min/max: 800/1800 MHz Core speeds (MHz): 1: 802 2: 799
3: 807 4: 828
Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK
Device-2: NVIDIA GK107M [GeForce GT 740M] vendor: ASUSTeK driver: nouveau
v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.9 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.3.0 - kisak-mesa PPA direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
Device-2: NVIDIA GK107 HDMI Audio driver: snd_hda_intel v: kernel
bus ID: 01:00.1
Sound Server: ALSA v: k5.4.0-74-generic
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Lite-On
driver: ath9k v: kernel port: e000 bus ID: 03:00.0
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 04:00.2
IF: enp4s0f2 state: down mac: <filter>
Device-3: Lite-On Atheros Bluetooth type: USB driver: btusb
bus ID: 1-1.1:3
Local Storage: total: 465.76 GiB used: 14.89 GiB (3.2%)
ID-1: /dev/sda vendor: Western Digital model: WD5000LPVX-80V0TT0
size: 465.76 GiB temp: 43 C
ID-1: / size: 456.96 GiB used: 14.89 GiB (3.3%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 76.0 C mobo: N/A gpu: nouveau temp: 76 C
Fan Speeds (RPM): cpu: 3900
Processes: 233 Uptime: 2h 12m Memory: 3.72 GiB used: 1.25 GiB (33.7%)
inxi: 3.0.38
Такой вопрос. Хочу поиграть в !osu на своей системе, для этого установил portproton, однако вместо нормального запуска игры у меня каждый раз запускается установщик !osu, и только в таком режиме запускается игра. И по традиции, после закрытия никаких данных не сохраняется. Подскажите, как решить мою проблему
!osu в linux mint
01 дек 2021, 23:06
lohh, расскажи подробней что ставил и как запускаешь.
Например, если каждый раз дергать запуск установщика - будет открываться установщик :)
MrTowelie
Решено: 8
Благодарил (а): 18 раз
!osu в linux mint
02 дек 2021, 08:39
Ну судя по видео с ютуба, в PortProton либо надо создавать ярлык после установки, либо после установки находить файл запуска в папке, куда установилась игра. Так что, как написали выше, скорее всего вы заново нажимаете на установщик, вместо файла запуска игры.
В принципе как и в PlayOnLinux, через который у меня установлен osu!.
Конечно, osu! при неправильном префиксе может и в бесконечное обновление уйти, но вряд ли такое происходит на PortProton.
P.S.: Не знаю как в PortProton, но в PlayOnLinux через OpenGL у osu! автоматически включается вертикальная синхронизация при запуске, в меню настроек игры приходится её повторно включать и отключать.
Вернуться в «Игры»
