ata2.00: revalidation failed (errno=-5)
seregka
Благодарил (а): 2 раза
06 ноя 2021, 23:07
Друзья лм20.2 ноут Acer Aspire 3
железот
Kernel: 5.4.0-89-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 5.0.6 Distro: Linux Mint 20.2 Uma
base: Ubuntu 20.04 focal
Type: Laptop System: Acer product: Aspire A317-32 v: V1.06
serial: <filter>
Mobo: GLK model: Dopey_GL v: V1.06 serial: <filter> UEFI: Insyde v: 1.06
date: 06/19/2020
ID-1: BAT1 charge: 31.3 Wh condition: 31.3/37.0 Wh (84%)
model: Murata AP16M4J status: Full
Topology: Quad Core model: Intel Pentium Silver N5030 bits: 64 type: MCP
arch: Goldmont Plus rev: 8 L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8755
Speed: 917 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 961 2: 817
3: 933 4: 940
Device-1: Intel UHD Graphics 605 vendor: Acer Incorporated ALI
Display: x11 server: X.Org 1.20.11 driver: modesetting
unloaded: fbdev,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 605 (GLK 3)
v: 4.6 Mesa 22.0.0-devel (git-ae99ea6 2021-10-14 focal-oibaf-ppa)
Device-1: Intel vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus ID: 00:0e.0
Sound Server: ALSA v: k5.4.0-89-generic
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 2000
bus ID: 01:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000
bus ID: 02:00.0
Local Storage: total: 715.41 GiB used: 398.07 GiB (55.6%)
ID-1: /dev/nvme0n1 vendor: Kingston model: RBUSNS8154P3256GJ1
ID-2: /dev/sda vendor: Apacer model: AS350 512GB size: 476.94 GiB
ID-1: / size: 91.65 GiB used: 12.45 GiB (13.6%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /home size: 392.72 GiB used: 155.78 GiB (39.7%) fs: ext4
dev: /dev/sda1
ID-3: swap-1 size: 1.91 GiB used: 0 KiB (0.0%) fs: swap
dev: /dev/nvme0n1p3
System Temperatures: cpu: 46.0 C mobo: N/A
Processes: 242 Uptime: 6m Memory: 7.58 GiB used: 1.54 GiB (20.3%)
Init: systemd runlevel: 5 Compilers: gcc: 9.3.0 Shell: zsh v: 5.8
inxi: 3.0.38
на пустое место для dvd я через переходник на салазка установил ssd
так все работает только вот при загрузке на экране зеленая надпись "АСЕР" стала резко моргать и есть ошибки порой разные
типа ata2.00: revalidation failed (errno=-5) бывает раз-ные ошибки делает
такое дело подумал может переходник ерундит попробовал от другого таже песня но заметил слейдующее если жесткий втыкаешь первый раз загружается идиеально выключаешь включашь и началось
dmesg | grep ata2
[ 1.747118] ata2: SATA max UDMA/133 abar m2048@0xa1428000 port 0xa1428180 irq 126
[ 2.230201] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.230432] ata2.00: ATA-11: Apacer AS350 512GB, AP613PE0, max UDMA/133
[ 2.230434] ata2.00: 1000215216 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 2.230585] ata2.00: failed to IDENTIFY (I/O error, err_mask=0x100)
[ 2.230587] ata2.00: revalidation failed (errno=-5)
[ 7.862202] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 7.862579] ata2.00: configured for UDMA/133
[ 7.918234] ata2.00: exception Emask 0x50 SAct 0x8000000 SErr 0x280900 action 0x6 frozen
[ 7.918324] ata2.00: irq_stat 0x08000000, interface fatal error
[ 7.918378] ata2: SError: { UnrecovData HostInt 10B8B BadCRC }
[ 7.918433] ata2.00: failed command: READ FPDMA QUEUED
[ 7.918456] ata2.00: cmd 60/08:d8:00:00:00/00:00:00:00:00/40 tag 27 ncq dma 4096 in
[ 7.918514] ata2.00: status: { DRDY }
[ 7.918531] ata2: hard resetting link
[ 8.394197] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 8.394542] ata2.00: failed to IDENTIFY (I/O error, err_mask=0x100)
[ 8.394543] ata2.00: revalidation failed (errno=-5)
[ 13.526190] ata2: hard resetting link
[ 14.002200] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 14.002299] ata2.00: failed to IDENTIFY (I/O error, err_mask=0x100)
[ 14.002303] ata2.00: revalidation failed (errno=-5)
[ 14.002369] ata2: limiting SATA link speed to 3.0 Gbps
[ 19.158226] ata2: hard resetting link
[ 19.634199] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ 19.634627] ata2.00: configured for UDMA/133
[ 19.634638] ata2: EH complete
Будьте добрее к этому миру, даже если мир не добр к вам.
seregka
07 ноя 2021, 00:06
я вот нарыл вот какое решение не известно рабочее нет:
Отредактируйте свой /boot/grub/menu.lst файл как root и перейдите в следующий раздел:
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
## kopt_2_6_8=root=/dev/hdc1 ro
## kopt_2_6_8_2_686=root=/dev/hdc2 ro
# (some_options_already_here)
Рядом с той частью, которая имеет только один знак решетки '#'добавьте эти параметры в конец строки:
irqpoll all_generic_ide
Итак, раздел выглядит так:
# (some_options_already_here) irqpoll all_generic_ide
Вы не редактировать kernelстроки, которые находятся в остальной части файла, потому что, когда Ubuntu автоматически обновляет список ядра, он извлекает параметры из ранее упомянутого раздела и перезаписывает все kernelлиний.
но дело в том что у меня нет /boot/grub/menu.lst у меня efi
07 ноя 2021, 02:29
seregka писал(а):
07 ноя 2021, 00:06
Тут не поможет правка конфигов - это аппаратная проблема. Возможно действительно переходник чудит, а может и винт помирать собрался. smartctl -a для этого диска покажи.
seregka
07 ноя 2021, 10:58
Доброго времени спасибо что откликнулись дело в том что переходник менял на сто процентов рабочий все также
SSD абсолютно новый покупал три дня назад
вот вывод smartctl -a /dev/sda :
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.4.0-89-generic] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model: Apacer AS350 512GB
Serial Number: 11EF071410F000202698
LU WWN Device Id: 5 dc663a 1410317ca
Firmware Version: AP613PE0
User Capacity: 512 110 190 592 bytes [512 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sun Nov 7 12:54:48 2021 +05
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (65535) seconds.
capabilities: (0x79) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 30) minutes.
Conveyance self-test routine
recommended polling time: ( 6) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 45
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 84
163 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 2
164 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
166 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
167 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
168 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 10
171 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
172 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
175 Program_Fail_Count_Chip 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 13
194 Temperature_Celsius 0x0022 067 067 058 Old_age Always - 33 (Min/Max 33/33)
231 Temperature_Celsius 0x0012 100 100 000 Old_age Always - 100
241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 1938829192
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 4 -
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay
Благодарил (а): 1226 раз
07 ноя 2021, 13:40
seregka писал(а):
06 ноя 2021, 23:07
На пустое место вместо DVD лучше установить старый диск, который скорее всего HDD - под файлопомойку, а уже на его место установить SSD
07 ноя 2021, 13:49
seregka писал(а):
07 ноя 2021, 10:58
Возможно - несовместимость между конкретными девайсами. Как предложил hellonet, попробуйте поменять местами HDD и SSD.
seregka
07 ноя 2021, 15:38
увы не получится так как hdd в нем нет только ssd m2
07 ноя 2021, 15:52
seregka писал(а):
07 ноя 2021, 15:38
Тем более, если в ноуте стоит уже гораздо более скоростной твердотельный диск M.2, туда незачем ставить вторым диском относительно медленный SSD. Попробуй обычный HDD. Может заработает. А для SSD найди другое, более лучшее применение
seregka писал(а):
06 ноя 2021, 23:07
Acer Aspire 3
подскажи точную модель ноута. Что-то вообще не нахожу такой со встроенным DVD-RW приводом
seregka
07 ноя 2021, 16:07
А у него и небыло встроенного заместо него стояла заглушека
07 ноя 2021, 18:02
seregka писал(а):
07 ноя 2021, 16:07
Тогда может быть просто деффектный канал контроллера SATA. Т.е. переходник исправен, а ноут - нет.
seregka
07 ноя 2021, 20:22
А как проверить? А что если попробовать исправить вот там как предложили добавление вот этого irqpoll all_generic_ide куда то чего у меня нет
07 ноя 2021, 21:08
seregka писал(а):
07 ноя 2021, 20:22
А как проверить?
Не имея специальной аппаратуры и знаний - исключительно методом исключения. Заменяем одну деталь и смотрим - поменялось ли что-то. В вашем случае такие детали: ноутбук, переходник, диск.
seregka писал(а):
07 ноя 2021, 20:22
Добавлять вы можете что и куда хотите - лечить аппаратную проблему программными методами - занятие веселое, увлекательное. Если больше делать нечего.
А параметр который вы выкопали - вообще относится к больше к контроллерам IDE - у вас в ноутбуке его вообще нет. Как и десктопах, уже лет 5-10.
seregka
09 ноя 2021, 03:38
В общем методом исключения вывод беда в буке втыкал другой переходник и hdd тоже самое. Ноутбук то новый в чем дело не пойму
09 ноя 2021, 07:21
seregka писал(а):
09 ноя 2021, 03:38
Ноутбук то новый
Оформлять возврат через сервисный центр
seregka
09 ноя 2021, 07:27
Ох беда беда
Спасибо ребята что откликнулись
09 ноя 2021, 08:01
seregka писал(а):
06 ноя 2021, 23:07
Acer Aspire 3
А можно ссылку на именно этот ноутбук в магазине?
seregka
01 дек 2021, 01:06
Acer Aspire A317-32
В общем проблема в самом этом интерфейсе что на DVD шел он голову плавил так как видать что то там урезанно или биос корявый в общем диски что жесткие что ссд дают ошибки, привод двд все норм.
Решение простое оказывается там для доп диска есть куда подключить и место для установки, нужно только кабель я его купил за 400 рублей все полет нормальный.
